Quoted from Lermods:I tried searching, but not getting good results. Can someone please point me to the install instructions for the cliffys? Looks like the pop bumper has to come out for the mystery hole and the ship out for the map hole. Have two smaller cliffys, not sure where they go.
Thx
Rob,
The two parts you show are for the Back of The Map Hole and for the front edge of the Depths. The Depths you can snap in place.
For the Tortuga Hole; you don’t need to remove the pop number. You should Tortuga Tom (need a small Allen wrench) and then you can loosen up the Pop Bumper enough to lift up the skirt to get to the screws. Just be carefull of the two small nylon spacers after you take off Tortuga Tom.
For the MAP hole you need to remove the ship.
MicsirTuna has a great Buffalo Pinball Twitch video on removing the ship.
Here are my notes from his video;
Pirate Ship Removal and Replacement
1. Flip Playfield.
2. Disconnect 7 cables;
3. Label connectors: 1 and 2 are larger white connectors (9 and 12 Pin). Next is Ethernet lighting R45( J908), 3 is 2 Pin connector power to right, 5,6,7 all go to board on right; J2, J3, J4 (should have colored dots for connectors as they are not keyed connectors) but write J2,J3,J4
4. Feed through so they do not get tangled
5. Lower Playfield
6. Loosen up right ramp wire form at bottoms of wire form Don’t have to remove nuts
7. Remove right wire form and set aside
8. Loosen right ramp; screw or on right by short side. Don’t remove screw
9. Remove screws at bottoms of ramp by flaps.
10. Ship Removal: 1) Allen Bolt behind BP,- Loosen Screw and then use hand to twist and remove without dropping. 2)Remove Cotton Pin behind BackBoard and washer and connector from Post. Pull Post through slot towards Playfield
11. Pull ship back so it comes off horizontal post through front eyelet underneath ship. Then can pull front up. Then jiggle or pull ship forward so it comes off of back eyelet. Watch out for BP VUK on back right as you need to clear that when bringing out.
12. Pull ship up and bring wires through. Careful with underneath of ship. Rest ship on pillow etc ; top side of ship down on pillow.
1. Putting Ship Back gets tricky.
2. Hold Ship and feed cables back through the hole. Make sure they go through the hole.
3. Bring Playfield in. Will be tricky to get posts through the eyelets. Try back eyelet first slide back In then can slide forward over front eyelet. Slide forward to stay on
4. Get shoulder bolt back on . Hold ship forward. This is tricky Try not to drop screw
5. Put washer in against back wood. And put clip back in.
6. Reattach ramp with flap screws. Make sure leaf switch under ramp is not getting caught.
7. Put back wireform. Angle in from top.
