PROBLEM: Rubber in the star map / chapter select area is worn through.
SOLUTION: This is a lot of work and there's a lot that can go wrong, so be sure you're prepared...
1. Remove the Black Pearl (see other posts for this)
2. Block all the holes AND the rear orbit with shop towels. This is important!
3. Remove the 5 hex nuts that keep the plastic shield in place. Use a wrench under the plastic to hold the nut underneath when you remove the topside hex nut. Failure to do this will just cause the post to spin.
4. Once the plastic is free, lift up on the chest and rotate it clockwise to the metal bracket out of the way.
5. While everything is open, clean it! You won't get a better opportunity.
6. Replace the rubbers and reassemble in reverse order. Be aware the rubbers are different sizes as are the posts they ride on.
I failed to block the holes and I managed to lose a plastic post somewhere inside the bowels of the machine. I looked for it for over an hour, shook to listen for it, etc...never did find it. I happened to have the right post because I had spares from doing the star post mod so I eventually reassembled with one of those. Don't make the mistake I did!
