Installed the Cliffy around the MAP hole today, requiring the Black Pearl to be removed. Removing the rear VUK first makes removing the BP MUCH simpler!!
As I was getting to the MAP hole I discovered the T-nut was protruding into my MAP hole a substantial amount. I then checked the balls I just pulled from the pin and sure enough they has substantial nicks in them. Had to remove the metal subway from underneatth the playfield. Marked the overhang amount of the T-Nut with a fine Sharpie and ground off that extra overhang at the workbench, Reinstalled it and now everything looks perfect.
Reinstalled the BP, hooked up the wires and tightened everything up. Everything tested perfect! Grabbed the playfield glass with gloves on, and without the glass touching a thing, only my hands, it did this:
I have handled playfield glass thousands of times, and now this.......Scheiße!!!!
