(Topic ID: 197289)
Jjp woz weak flipper
By Brinard
6 years ago
  • 8 posts
  • 6 Pinsiders participating
  • Latest reply 6 years ago by J_Striker
#1 6 years ago
Hey folks, just wondering if anyone has info on a jjp weak flipper.
It's the castle flipper. Upper left.
We had a coil lock on. Burning fuses and the coil was done. So I replaced the two transistors on the board correlating to the high and low voltage on that flipper. Then replaced the coil with an approved williams replacement.
Now we can flip the flipper bat but it is super weak.
Any suggestions? I verified continuity from the board connector to the coil on the hv line. Repinnes the connectors if they appeared worn. The coil was a brand new 11629.
The eos is normally open and verified it's not shorted at the switch.
Thanks for any help
Brian
#2 6 years ago
Sure you wired the coil correctly?
Checked the flipper in flipper test?
Resistance from coil to transistor?
#3 6 years ago
IN test mode it would do the low voltage hold, and on the high voltage test it just hummed or did nothing. The flipper wouldn't move. I took a picture and wired the replacement coil the same. As the old coil. Different brands. Would it need the high voltage line wired to an outer lug? It's on the center lug right now.
I did not measure resistance or know what to look for with transistors. I swapped out with irl540n as tech support advised. What are normal parameters ? What makes the resistance.
#4 6 years ago
Quoted from Brinard:
Just measure resistance from the lug on the flipper to the tab of the transistor. Should be pretty low as they're directly connected. At least that's how it works with TIPs. If it's high, you might have a burnt connector or wire.
#5 6 years ago
NEVER assume a replacement coil will terminate the wires to the same lugs.
Inspect both coils and determine which wire is which. Are there diodes? If so, which way are they facing?
Most (if not all) WMS coils I have seen have one of the outside lugs as the 50V "hot" connection. Connecting the supply voltage to the middle lug doesn't sound right to me.
Be very careful fiddling with this as you can cause a LOT of damage to the driver board by incorrectly connecting coils.
#6 6 years ago
I had an issue with the castle flipper being weak. I then noticed it didn't return fully after flipping it and found a broken return spring.
#7 6 years ago
Quoted from Spg101:
Ditto for me.
#8 6 years ago
Are you in weak flipper mode from the crystal ball?
Precision Pinball prod.
$ 49.99
$ 259.99
Stephenson, VA
$ 199.00
Pixels Arcade Games
$ 50.00
Duke Pinball
$ 85.99
9,300 (Firm)
Santa Maria, CA
$ 55.00
Pinball Mod Co.
$ 130.00
13,000
St. Clair Shores, MI
10,000 (Firm)
San Jose, CA
$ 91.00
$ 24.50
$ 45.00
Pinball Mod Co.
$ 40.00
Pinball Mod Co.
$ 395.00
Pinball Mod Co.
$ 16.95
$ 5.00
This page was printed from https://pinside.com/pinball/forum/topic/jjp-woz-weak-flipper and we tried optimising it for printing. Some page elements may have been deliberately hidden.
