(Topic ID: 200141)
JJP Pirates of the Caribbean Official Owners and Fan Club!
By goren1818
2 years ago
  • 13,000 posts
  • 476 Pinsiders participating
  • Latest reply 5 hours ago by PtownPin
  • Topic is favorited by 222 Pinsiders
There have been 2,277 images uploaded to this topic. (View topic image gallery).
20 key posts have been marked in this topic (Show topic index)
There are 13000 posts in this topic. You are on page 90 of 260.
#4451 8 months ago
Quoted from Yelobird:
Do not use WD40 products as they are not lubricants and Will in time make things gum up.
Doh! I did this on my first machine. Been ok so far but at least it’s a cheap part.
Thanks for the writeup! There are at least 3 different faults around this button that I know of so far:
1. The shaft itself binding in the sleeve
2. The button extending in between the switch and getting stuck, fixed by bending the switch
3. The button having a burr that binds in the button housing, which you have documented excellently
I’ve also been made aware of another fault with this button by imagamejunky - the button plunger has a flared end to keep it from popping out. This gets worn over time and the button starts riding higher and higher until it eventually pops out.
Honestly this button seems to be a crappy part in general. I’m thinking I will just find a replacement clear leaf button.
#4452 8 months ago
Quoted from zaphX:
The only contradiction I would make to that is IF the screw is in the end of the button it can't technically come out by design. The shaft pre-flare actually measures over .025" clearance which should never bind. I came to this solution as most would agree the issue is when the button is pressed it rarely returns back to the Up position. This fix should more then solve that. If you adjust the factory screw and switch to perfectly contact this should resolve it permanently. Or at least I hope so as this is pinball....lol
#4453 8 months ago
I am actually thinking of trying my button in Star Trek on potc. I like the spring action better on Star Trek. If it fits I will order one from PBL.
#4454 8 months ago
Ok, so this little screw that holds the lever arm to the plate on the chest eject fell off last night (of course while I have guests again). I can't find the screw, I'm hoping it's under the chest as I can't find it anywhere else. It seems I won't be able to screw this back in without removing the chest. How do I go about this? This looks like it's going to be a royal pain for a tiny little screw.
#4455 8 months ago
The fork for my chest stopped working. I look inside and find an assortment of parts. I can see what it’s supposed to do, but so far I’m missing the little metal tube that goes in the plastic tube that fits inside the washer (which is also missing).
Really questioning how some of these mechs are built. I still have shooter rod problems, even with adjustment, the top of the rubber clips the auto plunger fork. And the auto plunger seems to barely be able to get the ball around cleanly. Guess I’ll keep working on it instead of playing.
#4456 8 months ago
Installed my cliffies yesterday! Very happy with these.
B626AA65-E84D-4413-BE62-1D4654CFA66F (resized).jpeg1012EBE3-412F-4392-AED6-2B1CED95FDA1 (resized).jpegD7888EB4-8B79-4295-95D1-65E8A4F45E62 (resized).jpeg
#4457 8 months ago
Quoted from javagrind888:
Look at my post #2251
#4458 8 months ago
Big shoutout to yeobird aka mod couple. I installed my disc silencer mod today. All I can say is wow! I can’t hear that disc anymore. I actually like when the disc is running now. Before, it was SO LIUD and annoying. If you’re going to do any mod to your game, do this.
#4459 8 months ago
Quoted from NightTrain:
Well thanks for that much appreciated and glad it improved your game. It makes plundering easier in silence.....lol
#4460 8 months ago
Quoted from cbdarden:
Really questioning how some of these mechs are built. I still have shooter rod problems, even with adjustment, the top of the rubber clips the auto plunger fork. And the auto plunger seems to barely be able to get the ball around cleanly. Guess I’ll keep working on it instead of playing.[quoted image]
Below is the section for the fork ramp assembly from the manual, page C-30. Looks like the entire mech should drop out with 5 screws. Part, 17, 27, and 28 appear to those you found. There's 4 sets total for the mech, the others or any missing part could still be attached or laying somewhere on the assembly.
#4461 8 months ago
Looks like the entire chest mech can be removed with 2 screws? 1 on top and another under the playfield, can't tell for sure. From page C-60 of manual. Based on the manual picture screw 21 came lose and fell off, it's likely somewhere under the chest like you mentioned if it hasn't fallen into the cabinet. Those tiny screws can also get caught up in the wire hardness as well. With the mech removed I would remove both and thread back with some blue Loctite.
#4462 8 months ago
Quoted from PanzerFreak:
Yep, already fixed. I appreciate the help though. Just annoying. Hoping for no issues for awhile.
#4463 8 months ago
Cool. I'm considering purchasing a Pirates so figured I might as well see if some of these reported issues are major pains to fix lol. A lot of these issues seem quality control related. JJP should really be using blue Locktite on some of the screws for assemblies that are getting beat with a pinball. Thankfully JJP does an incredible job with their manuals.
#4464 8 months ago
Quoted from Tmezel:
Indeed that is my problem. Did you have to remove the chest for this fix? Also, did you have to remove the solenoid completely (desolder then solder it back?)
EDIT: Never mind, I got it out. Now I just need to find that screw...
#4465 8 months ago
So any further info on this rumored Tortuga replacement VUK part? Granted its a Pinside rumor and I haven't had any issue with it just wondering if there was something JJP identified that we missed?
#4466 8 months ago
I checked mine and sure enough I have already worn through the little plastic flare, and the screw is the only thing keeping it together. Since the only side effect is the button rides slightly higher than normal, I am fine with this.
#4467 8 months ago
Quoted from philsublime:
Rules question: Sometimes I have to requalify for chapters after a drain. Sometimes the qualified chapters stay lit. Why is that?
- if you lose a ball during a mode, when you next plunge there will be nothing qualified
- if you lose a ball between modes, the skulls you’ve already lit should remain lit on the next plunge, and if there were any lit then Chapter Start should be ready as well
#4468 8 months ago
Leaning towards ordering a Pirates LE this week but have some code related questions.
Do the 5 movie wizard modes in Pirates play like those in other Keith Johnson games such as LOTR, WOZ, and TH in the sense of them being two ball multiballs that work the entire playfield in interesting ways? Do some or all of the wizard modes have multiple stages? Sounds like none of them have a big set piece moment currently when they are completed? By set piece moment I mean the machine going nuts, flippers killed, etc when a wizard mode is completed. Hopefully that is added in a future code update.
Also, can the games multiballs be beat or do you just keep hitting jackpot shots until one ball remains?
I know there's gameplay videos out there of the wizard modes being played but I want to avoid seeing and reading details about them.
- the 5 movie wizard modes are single ball wizard modes. Though they are still early code, they are awesome wizard modes that work the playfield in different ways. I like the balance of single ball wizard modes, given the numerous Multiballs already in the game
- some have multiple stages but aren’t fully coded yet (I think movie 4 wizard mode, for example)
- no set piece moment as you describe that I have seen
- Multiballs cannot be ‘beat’. Though the value in getting as many super jackpots as you can is that it makes the wizard mode associated with that same Multiball pathway more valuable if you can get to it.
#4469 8 months ago
Chris was trying to get one for me. My VUK has never worked right.
#4470 8 months ago
I asked this question before and nobody responded. I was kind of hoping that Eric would comment since he's on this thread sometimes.
This game is a blast and I'm not saying that it isn't. However I think it's too easy to get multi balls. And I think I would enjoy the game more if it was more difficult to get multi balls. Is there a way to turn off stacking? I know I'm probably going to get flak for this and that's ok. I don't want to have a game with three four or five multiballs all going at once so frequently. How about a setting that allows you to play one chapter and stack one multiball?
Also I can't tell that installing a difficulty preset is making any difference in the settings. Are these presets even functioning on this game in the current code?
#4471 8 months ago
Ok, I feel dumb for this one, but is there an easy way to get the plastic back on the rubber nubs. I'm pushing, twisting, even tried using my fingernails to grip it. No dice
#4472 8 months ago
Never a dumb question we are all learning here. Dumb answer though, have you considered a bit of spit on the numb to coax it on? lol
#4473 8 months ago
I think help it get in the hole not on ...
#4474 8 months ago
Quoted from KevInBuffalo:
How long ago did you order those ? I'm still waiting..
I ordered jan 31.
#4475 8 months ago
Quoted from imagamejunky:
I was thinking about that too but I think the ruleset is designed to allow just about everything to stack. The multiball modes in Pirates all have their own unique shot(s) to score jackpots. When a second, third, etc multiball is stacked shots for jackpots do not overlap which is pretty cool due to each multiball having their own unique shots. Still, giving players the option to turn multiball stacking off would be nice.
#4476 8 months ago
I agree. The multi balls are a bit too much.
#4477 8 months ago
Tried spit. When that didn't work I tried a bit of cooking oil. Still no good.
#4478 8 months ago
It looks like the ends have been removed, I have used them in the past and they have little stems attached as you pull them through the hole it stretches them thinner to fit through the hole. They probably cut them off so they don't stick up. you may need new ones . but if its just holding t he plastic you could probably use some screws or something else.
#4479 8 months ago
I enlisted my wife's help for ideas and she used this tool to pull it through. It's a pore cleaner from the beauty isle.
#4480 8 months ago
Every now and then the wife can surprise you with a good idea
#4481 8 months ago
Did Lloyd or Butch make a video about taking the ship out yet? I need to adjust a flipper and a video would be helpful.
#4482 8 months ago
Not yet, but you can adjust both flippers without removing the Pearl with thre playfield in the last service position.
#4483 8 months ago
Butch has made all the JJP videos. Well done, nice quality. He's working on it, so I don't want to step on any toes.
The ones I've done have been for PPS/CGC remakes, and aren't of the same quality.
#4484 8 months ago
Quoted from zaphX:
Nice! I should be able to do it pretty easily then!
#4485 8 months ago
Quoted from phoenixpin:
Thanks. So it's basically just a bit more punishment if you loose the ball during a chapter.
Wouldn't it be better to have a thread about technical issues and a separate thread about rules questions? At the moment it's all mixed together here. But mostly it's technical stuff...
#4486 8 months ago
Owner's threads are usually general-purpose and cover about anything related to a game. There is at least one thread about PotC rules, though:
https://pinside.com/pinball/forum/topic/simple-explanations-of-basic-goals-in-jjp-s-pirates-of-the-caribbean
#4487 8 months ago
Quoted from tonycip:
I ordered jan 31.
I ordered in January sometime. Drop him another email as a reminder, that’s what worked for me.
#4488 8 months ago
The square multi ball indicators above the flippers have small rectangular lights above them. What do those represent?
#4489 8 months ago
Got ARRRR mb/frenzy last night but was unsure how. Is it from hitting the Tortuga hole several times during Tortuga mb?
#4490 8 months ago
Quoted from gliebig:
Pirate lane award
#4491 8 months ago
Quoted from heni1977:
Works like a champ, perfect fit and result...I tried this last nite.
Today I placed my order for an extra button via Pinball Life!
https://www.pinballlife.com/1-38-clear-pushbutton-for-stern-lockdown-bars.html
#4492 8 months ago
These are for the wizard modes. Not that I ever had one light up though...
#4493 8 months ago
Quoted from Pinzzz:
Cool, will get one on my next big order from them!
#4494 8 months ago
Quoted from Pinzzz:
So is the solution for sticking gold buttons?
If so I may just grab one as a preventative measure.
#4495 8 months ago
It should work, it also has a stronger spring in it, so the action is better (to me) any way! There are other ways to fix the one you have earlier in this thread. Those ways work as well if you don't want to purchase another button.
#4496 8 months ago
Quoted from GCS2000:
Yes, this is the solution for the POTC sticky gold/
action button!
Stern’s button is of better quality and feel, and works perfectly.
#4497 8 months ago
I installed that button on mine and went from constant sticking to NEVER sticking. It's a great cheap fix.
#4498 8 months ago
Excellent to hear I may grab one and swap out so I never have to worry price is cheap enough for sure.
#4499 8 months ago
Not sure if this is a problem but my ship seems to only be moving from center to the left. In test, it sways fully from right to left. Any tips would be greatly appreciated!
#4500 8 months ago
The five wizard modes looks like more There and back again The Hobbit's wizard mode.
Flagstaff, AZ
Pinball Photos
8,500 (Firm)
Santa Clarita, CA
Manchester Township, NJ
Pinball Mod Co.
