Quoted from PBMAN:Bye Bye Tom
Would this character work as a replacement? I would like to put him on but not sure with that jacket...
ebay.com link: Pirates of the Caribbean Davy Jones Dead Mans Chest Series 1 Figure NIP
You will definitely need to trim some of the coat and I am not sure if the hands/claws will clear the wire form. It might be some what tight over there. I had to trim a lot off my Jack figure and carefully maneuver the arms and implements to be sure that nothing would hit. Good luck with your project if you decide to go forward.
Quoted from Shapeshifter:All new games have issues - spent hours on Maiden getting it right.
It is frustrating.
That said, how does a topper not get centered on a new game??
Ah yes, my Maiden also took hours to dial in that loop shot for both plunge and auto-plunge.
Part of the NIB Experience™
Just a tip to all the 'newbies' that getting their first nib machine. After unpacking and setting it up, inspect it closely for any loose connectors and/or parts, especially 'orphan parts'. I have found that putting a coat of wax on the play field really helps my 72 year old eyes to spot things that I would miss. For example, I found this beneath the Endeavor. Probably was dropped during assembly of control panel in the back box. All of the screws are present so perhaps a bit of assembly carelessness; who knows. Obviously it could have caused some serious play field damage at a minimum if I had not found it before playing my first game. Hard to resist 'getting to the game' but it is worth taking the time to check it out first. Just my opinion.
Yelobird just received the two mods. Super quick shipping great quality. Feel like these came factory they work so well. That lockdown bar seems makes without something on it like Hobbit while the Canon really gets the point across that we all imagine is there is really there now.
btw - I bought my mirror blades from pinballsidemirrors.com (cointaker owned) - get the JJP WOZ/HOBBIT version.
Quoted from f3honda4me:What are you guys using to wax your playfields these days? Anyone adding mylar to any areas?
I added mylar to the chapter select area b/c those magnets move the ball around so much in a compressed space. There was also mylar that came with my game for what appears to be the ship area (in back) where the ball is dropped into play (behind the spinners).
By the way, I would suggest using clear vinyl instead of mylar as it's easier to get off if need be.
A lot of pinball part websites sell the pinhedz wax. I have used mothers carnuba, and also blitz. Both are fine, I kinda like the pinhedz as it is a little easier to apply / wipe off. Pure carnuba, while great, can leave little chunks of carnuba around.
http://pinballpro.net/shop/pinhedz-premium-complete-kit/
You don't have to buy the whole kit you can buy just the wax for ~$20
Quoted from NickBuffaloPinball:By the way, I would suggest using clear vinyl instead of mylar as it's easier to get off if need be.
Is this the type of vinyl that you used? If not, where did you get yours at?
With the new code update, I cannot lock balls in the chest after I have playing 3 chest multiballs. The Right lock target didn’t response.
Anyone else, I think it’s a bug ?!?
Quoted from pickleric:Is this the type of vinyl that you used? If not, where did you get yours at?
amazon.com link »
I would like to know as well. Plan on putting that on too.
Quoted from sirlonzelot:With the new code update, I cannot lock balls in the chest after I have playing 3 chest multiballs. The Right lock target didn’t response.
I think this may have been happening in the old code as well, but I never fully understood it. At some point during games I noticed I could never lock more balls...
Quoted from LTG:What I did on my game. Took lockdown bar off. Looked down at arm on switch. Centered it a little and bent up past the point on the switch body where the arm pushes the tiny knob into the switch. Put a blob of hot glue on the end of the button and shaped it a little when cooling so the part going down was a little wider and not sticking of the side of the arm on the switch.
Not sure I follow. I just hit mine this morning with a little WD40 and it now seems fine.
I’m having a clearance issue between the “A” and “P” map targets, resulting in the P sticking often and throwing errors on boot up.
I’ve tried pushing on them a bit and can’t seem to resolve this.
Any suggestions?
https://www.icloud.com/sharedalbum/#B115aDWbrM9Ost;339A983C-1C2C-4A16-914D-F424E99ABF11
Quoted from zaphX:Not sure I follow. I just hit mine this morning with a little WD40 and it now seems fine.
Probably okay, but may want to avoid using WD40 in the future on your pinball machines. It is technically not a true lubricant. It was designed for water displacement to prevent rust.
Quoted from zaphX:Now that my star map works (loose cable) - how do I use it? I really don’t understand what it’s trying to tell me.
Also - does everyone have one pale green “star” on their map in the lower left?
I don't think anyone understands this well except maybe Eric M and Keith J
Quoted from zaphX:I’m having a clearance issue between the “A” and “P” map targets, resulting in the P sticking often and throwing errors on boot up.
Any suggestions?
They look like they are catching on each other. Can you adjust the right one and move it more to the right so it doesn't bind on the middle one? Notice how the left one has a little space in between it and the middle one, you want that for the right one as well.
Quoted from NickBuffaloPinball:I added mylar to the chapter select area b/c those magnets move the ball around so much in a compressed space. There was also mylar that came with my game for what appears to be the ship area (in back) where the ball is dropped into play (behind the spinners).
Yes I noticed my PF has mylar in those same areas. Mine also has a strip by the depths kickout.
I have not had this issue, I had a game last night where I had two chest multiballs in the same game. Must be something else that also happens that is causing it? I'll pay more attention to subsequent games, as I'm curious now.
My star map has lights that are white and sort of yellow ish?
Quoted from zaphX:My monitor has a slight tilt. I’ve seen this on a couple JJP pins in the field also.
Is there a known fix?[quoted image]
Yes open up and ensure the monitor is secured properly. Sometimes it is not latched in all the way on one side or the other, and so it sags a bit. I can snap a pic later if you can't figure it out.
Quoted from pickleric:Probably okay, but may want to avoid using WD40 in the future on your pinball machines. It is technically not a true lubricant. It was designed for water displacement to prevent rust.
Yeah I considered this, but since it’s only the plastic button I figured worst case I buy a new button. I can report it was super effective with just a tiny blast administered to the shaft from the underside while the button is depressed.
Quoted from pickleric:I don't think anyone understands this well except maybe Eric M and Keith J
I have the same questions. In fact it's the only thing I don't understand
Quoted from pickleric:I think this may have been happening in the old code as well, but I never fully understood it. At some point during games I noticed I could never lock more balls...
I am sure that I didn’t have that with the old code. I played the game very much and never notice that before.
Quoted from pickleric:They look like they are catching on each other. Can you adjust the right one and move it more to the right so it doesn't bind on the middle one? Notice how the left one has a little space in between it and the middle one, you want that for the right one as well.
How do I adjust their physical position? The screws under the playfield simply move the switch, not the target, right? (or are they connected?)
Quoted from f3honda4me:Yes open up and ensure the monitor is secured properly. Sometimes it is not latched in all the way on one side or the other, and so it sags a bit. I can snap a pic later if you can't figure it out.
It wiggles a little on the right side but I don’t know what to adjust here.
My spinning disc sounds like a binding sawblade. Short of ordering a third party plastic disc, what are the fixes?
Quoted from zaphX:How do I adjust their physical position? The screws under the playfield simply move the switch, not the target, right? (or are they connected?)
They have to be connected.
Notice the spacing on mine.
Mine could possibly use some adjusting to level out, but are working fine.
Quoted from SheriffBarclay:My spinning disc sounds like a binding sawblade. Short of ordering a third party plastic disc, what are the fixes?
They all do. The Mod Couple sells a solution to quiet it some. Going to try that this weekend.
Quoted from pickleric:They have to be connected.
Thanks for this, it turned out to be just that easy. Loosened the screws underneath, moved the target over, and tightened back down. No more error!
Quoted from zaphX:It wiggles a little on the right side but I don’t know what to adjust here. [quoted image]
You can pull up on the flat part I circled here. That is the "release" for that side. Pull it up and you can "swing" the monitor away from the machine, the left side of the monitor will be like the swivel/hinge (like a door). Then pull that up again and push the monitor all the way back into place and then push it back down and that should secure it.
Quoted from pickleric:They all do. The Mod Couple sells a solution to quiet it some. Going to try that this weekend.
The mod they make works great for this.
Quoted from f3honda4me:You can pull up on the flat part I circled here. That is the "release" for that side. Pull it up and you can "swing" the monitor away from the machine, the left side of the monitor will be like the swivel/hinge (like a door). Then pull that up again and push the monitor all the way back into place and then push it back down and that should secure it.
Thanks! I guess that wooden block has to be removed first? It seems to impede the operation of the release.
I’m wondering if mine is as straight as it’s going to get - it is pretty close.
Just realized my standard doesn't include the starmap lightboard. Is this a part I can order and upgrade?
Quoted from WolfManCat:Just realized my standard doesn't include the starmap lightboard. Is this a part I can order and upgrade?
no, this is part of the Limited / Collector's edition package.
that being said, you are not left out. the playfield will "twinkle" in the area that you need to hit to complete the star map.
Quoted from zaphX:Thanks! I guess that wooden block has to be removed first? It seems to impede the operation of the release.
You just loosen the screw on the wood block and rotate it to the side and tighten the screw. you want to keep it in there so you can put it back for shipping / moving the game later.
Quoted from KingPinGames:no, this is part of the Limited / Collector's edition package.
You seem to understand how the starmap works. Care to explain?
Quoted from delt31:You seem to understand how the starmap works. Care to explain?
The star map will twinkle the next constellation that needs to be made. For example, if the 4x shot is the next contellation there will be 4 Xs on the star map. Not the easiest to see, but it can be made out. When the correct shot is made, a book opens up on the right side of the screen showing the constellation on the left page. This image shows the constellation for the O target in GOLD.
Regarding the star map it was actually well covered and illustrated by Eric, Joe, and Kieth in there JJP Pirates Documentary videos I thought we all watched while waiting for these amazing games to arrive. The star map is not an In Your Face map. Think of it as a secondary puzzle to solve trying to figure out the Hint the stars are trying to illustrate. IE, sometimes the stars will form an outline of a treasure chest, or an X etc. Again, NOT HD imagery meant to be Obvious but more of an added puzzle to solve. Kind of like the Compass in the apron that points to the thing you want most. Its just a Hint of what you would most benefit from and focus on. I think its an amazing addition though with my slap and pray pinball technique looking more than 3 inches from the flippers at this point is rough and non productive. I Strongly suggest reviewing some of the game play content the designers shared. Trust that they did these videos for Our benefit Not for an afternoon off playing pinball! lol Maybe they did...
Quoted from delt31:Would this character work as a replacement? I would like to put him on but not sure with that jacket...
ebay.com link » Pirates Of The Caribbean Davy Jones Dead Mans Chest Series 1 Figure Nip
Thats the one I am using for my game but I paid WAY less then that! As the Series 1 figures have long gone out of production you need to simply keep your eye out they do pop up cheap you just can't be in a hurry! Mine cost $18 and don't worry about the NIB variable as your going to throw away the box And over half of the figure anyway! lol
It is frustrating.
Maybe the same way someone misspells "reinforcement" on a playfield.
Quoted from Yelobird:Thats the one I am using for my game but I paid WAY less then that! As the Series 1 figures have long gone out of production you need to simply keep your eye out they do pop up cheap you just can't be in a hurry! Mine cost $18 and don't worry about the NIB variable as your going to throw away the box And over half of the figure anyway! lol
post a pic? Would like to see what it looks like
Quoted from delt31:post a pic? Would like to see what it looks like
Will do but my CE arrives Sunday so unless you want to see it spinning on my finger it will take a few days. Lol
Quoted from Yelobird:Will do but my CE arrives Sunday so unless you want to see it spinning on my finger it will take a few days. Lol
did you have to trim off the coat at all? Any info on how you did it would be appreciated.
Quoted from delt31:did you have to trim off the coat at all? Any info on how you did it would be appreciated.
You absolutely need to trim the coat or it will be sweeping the Playfield like a prom dress. It’s a removable soft rubber. A pair of scissors or a razor will cut it very easy.
Has anyone reported problems (and fixes) with The Depths VUK yet?
We’ve been playing a few hours and I noticed The Depths starting to struggle, taking 2-3 tries to eject the ball.
Quoted from zaphX:Has anyone reported problems (and fixes) with The Depths VUK yet?
Adjust the power for the coil. Every coil can be individually adjustable in the Coil Settings menu. Different power, pitch, environment, etc can affect the coils. We configure then best we can for average conditions, but you're welcomed to and encouraged to adjust for your unique setup.
Quoted from Hogbog:Adjust the power for the coil. Every coil can be individually adjustable in the Coil Settings menu. Different power, pitch, environment, etc can affect the coils. We configure then best we can for average conditions, but you're welcomed to and encouraged to adjust for your unique setup.
I’ll take a look. It was weird because it was 100% fine for hours and then seemed to struggle a couple of times later into gameplay.
While I have you - is there a way to adjust the contrast/brightness of the monitor? It looks a bit washed out by default to me, and I’d like to mess with it.
I haven’t found anything in the settings tree for this yet, but admittedly I haven’t spent much time in there. Too busy playing and learning the rules!
