Quoted from Psw757:Anyone figure out why the cannon seems to be immeditaly qualified to load at times since update?
I have not experienced this myself, for what it's worth.
Today received the Mod Couple Mods and they are great and worth their money, thx.
Quoted from moTiv8:Also added some toys near the Pin
Wow with some lighting that ship would make an awesome topper!! Thanks for sharing looks great.
Quoted from VillaThrills:I just can’t get through my head the behavior. Do the JJP coils work like the old Bally ones? So button is pressed and high power coil kicks in and the flipper goes up. Hits the EOS, and adds in the low power coils. Either low power never engaged (short in the coil connection) or is not enough (poor solder joint). Flipper comes back down, releases EOS, bypasses low power coil and high power kicks it back up trips the EOS and somehow low power magically is enough now. Just don’t understand that.
My money is on the flipper button switch
So last night we played for five hours after the machine arrived and we were done with dinner etc. Tonight probably more of the same. I’ve never had this much fun on a pin! Whole family loves it.
Never really thought about it but you can buy the CE playfield?
Quoted from VillaThrills:Never really thought about it but you can buy the CE playfield?
You'd have to call them and ask Shannan or Frank.
To buy any parts just for CE, you'll have to own one and provide serial numbers, etc.
Quoted from f3honda4me:So last night we played for five hours after the machine arrived and we were done with dinner etc. Tonight probably more of the same. I’ve never had this much fun on a pin! Whole family loves it.
Sounds familiar. Definitely one of the funnest pins to come out recently and I'm not even a huge fan of the movies. In fact I'm pretty sure I only even bothered watching the last three sequals because of this pin. Its just a great pirate theme in general imo and the Disney license adds just the right amount of spice.
No you can't. Not unless you're a CE owner.
So I can qualify chapters but how do I actually get credit for chapters so I can combine with MB mode to get wizard? Do I need 5 or so to at least start?
Also - best way to tweak the tuga VUK? Sometimes mine shoots into the right inlane. It's really the only thing I've seen that doesn't play as expected and even that works 7 out of 10.
Quoted from delt31:So I can qualify chapters but how do I actually get credit for chapters so I can combine with MB mode to get wizard? Do I need 5 or so to at least start?
That is called bumpers VUK in settings. Turn it up or down depending.
I cannot remove the post on the upper PF (black pearl) in order to change its position. It seems like it should turn with a wrench but it doesn't budge. Is there a trick to it?
Quoted from f3honda4me:Is there a trick to it?
Long socket on top, wrench or nut driver on bolt below.
Quoted from moTiv8:Had the best Game since i have this Pin.
It was so amazing and intensive to play.
6666666 Multiball with Multiplier is the Key to very nice Points
I love this Pin.
THX JJP
Damn! Nice work
Quoted from moTiv8:Today received the Mod Couple Mods and they are great and worth their money, thx.[quoted image][quoted image][quoted image][quoted image][quoted image][quoted image][quoted image][quoted image][quoted image]
They really are great. Better than expected. Really nice additions. Specifically like the pop bumper cap with the glowing bottle. So good.
Quoted from Yelobird:Wow with some lighting that ship would make an awesome topper!! Thanks for sharing looks great.
Thinking about to do it and also to add lightning to the PF.
Quoted from check_switch_26:I'm just going to leave this here:
Yes you have an example of pirate spelt with a " y" , it was also spelt with an " I " but most importantly in THE MOVIES of Pirates Of The Caribbean they never spell pirate with a "y" . So to be true to the franchise they would spell piracy with an "i" not a "y" on a wanted poster . It just doesn't look right and the last thing I want to do while playing pinball is have a debate with mates over spelling . Just my 2 cents worth
Eesh, this game has had a lot of issues out of the box. My Black Pearl started throwing switch errors, so I knew I had the dreaded broken switch wires under the mini PF. I removed it and sure enough the wires were broken off on the left frontmost switch.
The zip ties were too tight on the harness and not routed ideally to give them slack as the ship rocks. The soldering on the wires was also pretty bad. I spent a few hours snipping zip ties, routing and resoldering the wires on the two left switches and cleaning/waxing the playfield, especially under the Pearl. Then cleaned and waxed the rest of the playfield and installed new mirror balls. All switches tested OK and the game plays perfectly now.
I played a few games and was able to get all five multiball modes going at once, Tortuga MB, Liars Dice and ended up with 1.3M on factory 3 ball settings. Didn’t reach any wizard modes tonight, but I’ll keep trying. This is one deep and difficult to beat game, like all JJPs.
I’m still on .96 code and will stay there until the next code release. There should be more callouts and mode integration with the Depths and Bayou shots as they don’t do much in the current code. Such a great pin with a lot more potential with further code development. The sounds and music in this pin are the best I’ve ever heard in a pinball machine. The music score and LED lighting changes during the different modes is incredible.
Oh, and yes the topper is off center. Looks odd, I’ll need to figure out how to center it.
Quoted from Charliew65:yes, action button stuck for 2 days not anymore, should fix itself. My problem is my auto shooter, shoots the ball into the left rubber. looks like my right wireform is not helping with this problem.
How do you fix this auto launch promblem?
Quoted from Pinballpal:How do you fix this auto launch promblem?
Check the alignment of the manual shooter, my autoshooter was hanging a little bit sometimes on the e-clip of the shooter rod. Adjust the alignment of the shooter rod a little bit and no more autoplunger hang ups.
Quoted from pickleric:Check the alignment of the manual shooter, my autoshooter was hanging a little bit sometimes on the e-clip of the shooter rod. Adjust the alignment of the shooter rod a little bit and no more autoplunger hang ups.
Mine just started doing this...will take a look tonight. Thanks for the note on how you resolved it.
Thanks but my manual plunger is not hitting the auto plunger. The problem is my auto launches do not launch the ball into play some times. The ball hits that post you use to save the ball from out lane drains.
so two items:
1) Gold button sometimes gets stuck a little after multiple presses - anyone experience this?
2) Bumper VUK sometimes hits sling. I know you can change power but it seems like it could be more than that. Anyone experience this and any thoughts to have it kick out clean 100%? Right now it's around 70%?
Quoted from delt31:so two items:
2) Bumper VUK sometimes hits sling. I know you can change power but it seems like it could be more than than. Anyone experience this and any thoughts to have it kick out clean 100%? Right now it's around 70%?
Thanks,
Brian
Take a look through the thread...lots of ways to fix 1). Mine included bending the switch the button hits on the receiver and then running very hot water over the button. Some are using white lithium, others are sanding. Take a look at the pictures of the thread, you will see ones with the button in question and you can jump to that post.
Quoted from VillaThrills:Mine just started doing this...will take a look tonight. Thanks for the note on how you resolved it.
In my case, the shooter rod is NOT center on the ball. Unfortunately centering it made it worse. It hits the ball pretty of center, but doesn't seem to matter because of the rails.
Quoted from Pinballpal:Thanks but my manual plunger is not hitting the auto plunger. The problem is my auto launches do not launch the ball into play some times. The ball hits that post you use to save the ball from out lane drains.
Check the two prongs of the auto launcher and see how they align on the ball when you push the auto launcher forward. May need to bend one or both to align so it shoot the ball right.
Quoted from VillaThrills:Take a look through the thread...lots of ways to fix 1). Mine included bending the switch the button hits on the receiver and then running very hot water over the button. Some are using white lithium, others are sanding. Take a look at the pictures of the thread, you will see ones with the button in question and you can jump to that post.
Could also try the Stern button that folks say doesn't bind:
https://www.marcospecialties.com/pinball-parts/515-7791-00
Quoted from PsychoPsonic:Could also try the Stern button that folks say doesn't bind:
Nice - I might do that too. Now for that bumper VUK.....I'll take a look through here.
Based upon the previous JJP games, does anyone have a list of recommended parts to keep on hand for wear and tear items? Maybe things like flipper rebuild kit, etc?
Quoted from delt31:Nice - I might do that too. Now for that bumper VUK.....I'll take a look through here.
it is just another coil that you can turn down. it should be listed as the pop bumper vuk (or something similiar)
Quoted from KingPinGames:it is just another coil that you can turn down. it should be listed as the pop bumper vuk (or something similiar)
Only thing on mine and several reported the same is that the scoop for the VUK wasn’t screwed in tight. May want to check that to even the launch out some.
Quoted from darkryder:Oh, and yes the topper is off center. Looks odd, I’ll need to figure out how to center it.
Seriously though - how did they f--k that one up?
Quoted from pipes:Seriously though - how did they f--k that one up?
No idea, maybe Santa's helpers were too busy rushing to assemble and ship games before Christmas and drunk on egg nog, lol.
I hope I don't have to redrill new holes in the top of the backbox to get it centered. Will take a look after the holiday madness subsides.
Quoted from darkryder:No idea, maybe Santa's helpers were too busy rushing to assemble and ship games before Christmas and drunk on egg nog, lol.
They certainly didn't have enough time to actually install a topper in the factory to see how it looks, lol.
I personally think the game looks better without it anyways since it's literally regurgitating exactly the same thing that's displayed 4 inches below it on the backglass.
Quoted from pipes:They certainly didn't have enough time to actually install a topper in the factory to see how it looks, lol.
Toppers are Defiantly a personal or acquired taste for sure. Some people hate all toppers, some can't own a game without one. While I would have loved a Wow over the top topper the one provided looks very nice and I like the torch flicker effect they added personally. Granted I did sell my LE to order a CE it was not because of the topper. Or was it......lol
The LE and CE toppers are nice, but they can't compete with the awesome Laseriffic or other aftermarket toppers out there. I'm hoping someone makes a more realistic and interactive pirate ship in a bottle topper for POTC at some point to replace the factory acrylic topper. I never used to like toppers, but now I have to put one on every pin. People always comment on the toppers as soon as they see the games. I think my favorites are BSD and Aerosmith and the Stern Aces High topper is coming for the Maiden LE.
So while I’m glad I got my pirates ce today It’s kind of useless. Jjp did not include leg levers or the screws to attach the topper. Seeing everyone else’s missing items and issues it’s concerning to me how rushed and lack of qc that has been employed to get these out.
Quoted from darkryder:The LE and CE toppers are nice, but they can't compete with the awesome Laseriffic or other aftermarket toppers out there. I'm hoping someone makes a more realistic and interactive pirate ship in a bottle topper for POTC at some point to replace the factory acrylic topper. I never used to like toppers, but now I have to put one on every pin. People always comment on the toppers as soon as they see the games. I think my favorites are BSD and Aerosmith and the Stern Aces High topper is coming for the Maiden LE.[quoted image][quoted image][quoted image][quoted image][quoted image][quoted image]
Honestly I think the CE topper blows every other topper out of the water as its very interactive. A majority toppers just reproduce an image that's already on the backglass or playfield which I think comes across as excessive.
Quoted from Ilushka85:So while I’m glad I got my pirates ce today It’s kind of useless. Jjp did not include leg levers or the screws to attach the topper. Seeing everyone else’s missing items and issues it’s concerning to me how rushed and lack of qc that has been employed to get these out.
While I love the game, it does give you the feeling that that these are not considered a premium product.
Quoted from pickleric:While I love the game, it does give you the feeling that that these are not considered a premium product.
Hence my hesitation to fork out $15k AUD for this! And not to mention the wear I’m seeing on a few machines throughout this thread. It’s kind of scary
Quoted from Audioenslaved:Hence my hesitation to fork out $15k AUD for this! And not to mention the wear I’m seeing on a few machines throughout this thread. It’s kind of scary
In saying this though I still want one!! It looks like a fun game!
Quoted from Audioenslaved:In saying this though I still want one!! It looks like a fun game!
Everyone has seen my issues and I am not minimizing those concerns in the least...however I can say without reservation, this is my favorite pinball machine ever. I really look forward to Eric’s next machine as this one is a masterpiece IMHO. I can’t wait for the next reveal.
Quoted from VillaThrills:Everyone has seen my issues and I am not minimizing those concerns in the least...however I can say without reservation, this is my favorite pinball machine ever. I really look forward to Eric’s next machine as this one is a masterpiece IMHO. I can’t wait for the next reveal.
And that’s where the problem for me is (I’m trying to see your posts in here) $15k AUD is Houdini plus something or deadpool pro plus whitewater. The problem factor, the topper not being centred (that’s so simple but seriously how do you stuff that up), wear etc etc adds up to hmmm
I'm with VillaThrills. This game is spectacular. I wouldn't trade mine for 2 classic Williams. The problems are annoying, but will be forgotten long before the game gets old.
Quoted from Ilushka85:Jjp did not include leg levers
Borrow some from one of your other games so you can play your new pin. I am sorry it happened.
We can’t stop playing the pin. It’s just that good. Worth every penny. Whole family is playing hours every day!
