Quoted from harryhoudini:I don't recall the size I used. But I think this seems to be the fix that might be the most engineered solution. However, I can't find the listing anymore on here so maybe it's available somewhere else. Trumpanche might be able to chime in..
Thank you for the responses! Yes, from that video...its here ->
www.etsy.com/shop/TrumpancheMods
looks like he makes similar gates for hobbit and wonka....but POTC is out of stock. I sent him an email for info on restock.
And thanks EaglePin ....will get a sleeve post to help protect that silicone...my corner was thrashed (I simply rotated the sling rubber for now).
And.......I fixed the red led already! The pin is new to me, and I said the light was inconsistent, but I hadn't noticed the pattern yet. I bet....it worked when I first turned on the pin, but...as soon as I did a right flipper, it stopped working. I can't test that out now though...
But here is why, and I bet lots of pearls could have potentially the same issue (with their bottom lanterns) ->
See the exposed wire?
Its from a flipper rubbing at full extension.
So....with the first flip, I bet it shorts the light as soon as it makes metal to metal contact.
So, I wrapped it in electrical tape, cut a some zipties, pulled some slack into the wires, and routed them to the side of the playfield. The left flipper wasn't hitting the wires yet, but I did the fix on both sides.
Next time you have your pearls off, check those wires!
