Quoted from Mikespinball:Bought a Pinwoofer speaker/sub-woofer set, the Art of Pinball sculptured LCD cover and my ivory shooter.
Quoted from Mikespinball:Started with Pinwoofer system. Printed out the detailed instructions for each section. They are very clear what to do along with pictures to help in the process.
Quoted from Mikespinball:R&R the cabinet lower speaker. Easy to remove and replace. They also included any extra hardware that is needed.
Quoted from Mikespinball:Next install is the tweeters. You have to remove the bracket that holds them in and also holds the lock for the back glass.
Again great instructions helping you through each step.
Quoted from PinWoofer:Greetings Mikespinball - delighted to see that you are enjoying our electronic instructions!
There is also a detailed instructional video from HurryUpPinball (Craig is quite brilliant):
Quoted from Mikespinball:Well, just finished the installation. The amplifier was a bit more/longer install do to that I took the time to reroute wires to the speakers and new power board supplied by the kit. I cut old zip ties and attached the new wire runs so that it looks factory installed. This includes the black wire loom that the main wire harness runs from the head to the lower cabinet and fed the wires along the left side of the cabinet.
At this time I am leaving the amplifier loose so that I can play with the different volume settings to find what I like.
The kit wasn't too difficult to install and the instructions were very clear and helpful to install Pinwoofer's kit for POTC. Overall very happy with their product and the sound it produces.
Why do I feel like I just watched an infomercial for overpriced electronics?
