I’m in for ramps as well
My elite topper arrived today. Anyone have one installed yet? I’m 50/50 if I’m keeping mine or considering trades for it.
If it's still possible I would like to join the club for a ramp-set as well
So far everything ok but who knows
Anyone have any suggestions for the button? I've had this issue with multiple JJP games where after several plays the button just no longer seems to reach or be aligned correctly to hit the metal piece under it consistently without smashing it down. Only been an issue with JJP.
Quoted from heartbrand:Anyone have any suggestions for the button? I've had this issue with multiple JJP games where after several plays the button just no longer seems to reach or be aligned correctly to hit the metal piece under it consistently without smashing it down. Only been an issue with JJP.
I replaced mine with a stern button from pinball life and it works perfectly.
Have you tried bending the metal leaf switch that the button pushes so it's better aligned with the bottom of the button? If you stand in the playing position and lean forward getting your nose closer to the playfield glass you can look upside down through the gap between the top edge of the lockbar and the bottom edge of the mini LCD to view underneath the lockbar at how the button is lining up with the metal leaf switch. Maybe take a look at it this way and press the button while looking through that gap to see how it's missing the switch and then adjust the switch accordingly.
Blob of hot glue on the end of the button.
Quoted from LTG:Blob of hot glue on the end of the button.
ohhhhh that’s a great idea
Quoted from Mrsiyufy:ohhhhh that’s a great idea
Works and lasts too. I put it on Hobbit when I first got it years ago, in commercial use. And still works.
Doesn't slip off the switch blade, long enough to reach, and a little flexible and doesn't hurt anything.
Hi guys, got an issue on my potc le, the sound volume control (on the coin door) only work upward, i the down press doesnt regiester.
Any idea how i could fix this?
Quoted from skwal:Any idea how i could fix this?
Start by reseating connectors by coin door and in the backbox. Be sure they are in tight. No wire sticking out.
Quoted from LTG:Start by reseating connectors by coin door and in the backbox. Be sure they are in tight. No wire sticking out.
Do you know where they connect in the blackbox? Could u send me a photo? Thanks
Quoted from skwal:Do you know where they connect in the blackbox? Could u send me a photo? Thanks
Quoted from skwal:Where is j604 located?
Check the manual
https://marketing.jerseyjackpinball.com/potc/POTC_Manual%202_0%20November%202018.pdf
Page D-80 has a diagram of the board and Page D-83 lists the wiring going into J604
Quoted from EaglePin:Check the manual
Thanks i managed to found it now, reseated and working again
Just if someone has a similar issue here where it is in this pic
Ok now another issue, the volume button works perfectly but i dont have audio from the headphones when i plug it in. It detect the headphone is plugged but nothing comes from the headphones (yes i played with the volume)
Any idea where it connect in the blackbox?
Hi guys,
Sorry another issue.. i replaced the cmos battery with another one, everything was fine (with power on)
I then switched off my machine waited a few seconds, now when i switch it on again, the power supply inside the blackbox does not turn on.
The led on the power board do turn on.
Any idea where i can go from here?
Quoted from skwal:Hi guys,
Hi mate,
So this technic worked, my game start as usual! BUT if i power it down, i need to do that AGAIN to bring it up? do you know if i have to change a setting in the bios or something?
Quoted from skwal:Hi mate,
Yes. In the BIOS you change Power on after power fail to yes or enable. This tells the motherboard to power itself on after the game is off. BIOS password is qmodem (all lower case).
Quoted from Pinballomatic:Yes. In the BIOS you change Power on after power fail to yes or enable. This tells the motherboard to power itself on after the game is off. BIOS password is qmodem (all lower case).
Does the bios have a password?
Quoted from skwal:Does the bios have a password?
yes as I said qmodem all lower case
Quoted from Pinballomatic:yes as I said qmodem all lower case
Ok it seems it s ACBACK. always on as on the picture
is that correct?
Quoted from skwal:Ok it seems it s ACBACK. always on as on the picture
is that correct?
yes okay
Quoted from Pinballomatic:yes okay
Fantastic! issue resolved!
Thanks a lot!
Now i still have the headphone issue.
It s plugged in (tried the headphone in my dialed in no pb)
The machine detect that a headphone was plugged in because when i change the volume control it mention headphone volume.
I have resettle the headphone side on the coin door.
Any idea with this one?
Anyone out there have the large coin Aztec gold lockdown-bar topper around the action button available ?
Quoted from bbble:Anyone out there have the large coin Aztec gold lockdown-bar topper around the action button available ?
Looking for the one arround the compass from lior, if anyone is selling one thx
Quoted from skwal:Looking for the one arround the compass from lior, if anyone is selling one thx
Initially, I read his post and wanted to respond w/ the same link, but I think he's referring to the Lior Scupted LCD cover:
https://www.instagram.com/p/CAJO-v1lJH5/?hl=en
Are you referring to this?
Quoted from bbble:Yes sir
I encourage you to look at all the mods they have for it. They are great!
Ah hah. mountaingamer made and offered these larger coin beauties a few years ago, but he doesn't appear to have been active on Pinside for quite a while.
I actually gave mine away to another Pinsider a few months ago after I had replaced it with Lior's action button surround mod.
You can probably create your own without too much effort if you can find similar plastic coins. Good luck!
Quoted from Heater:https://themodcouplepinball.com/collections/jjp-pirates-of-the-caribbean-custom-mods-collection/products/jjp-pirates-of-the-caribbean-gold-lock-button-custom-mod
Except they stopped responding to customers a few weeks ago and scammed several ppl... there is a long thread about it on here somewhere
The real must have mod for this game is that opening/closing lighted chest from Pinball Mod Co. It not only restores one of the scrapped toys from the prototypes, it improves upon it. I can't believe there are still games out there without this.
Quoted from jake35:Except they stopped responding to customers a few weeks ago and scammed several ppl... there is a long thread about it on here somewhere
Quoted from Betelgeuse:The real must have mod for this game is that opening/closing lighted chest from Pinball Mod Co. It not only restores one of the scrapped toys from the prototypes, it improves upon it. I can't believe there are still games out there without this.
This page was printed from https://pinside.com/pinball/forum/topic/jjp-pirates-of-the-caribbean-official-owners-and-fan-club/page/355 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
