(Topic ID: 200141)
JJP Pirates of the Caribbean Official Owners and Fan Club!
By goren1818
2 years ago
  • 15,465 posts
  • 525 Pinsiders participating
  • Latest reply 4 hours ago by harryhoudini
  • Topic is favorited by 252 Pinsiders
There have been 2,663 images uploaded to this topic. (View topic image gallery).
20 key posts have been marked in this topic, showing the first 10 items. (Show topic index)
There are 15465 posts in this topic. You are on page 307 of 310.
#15301 43 days ago
Please,I don't know what the big flashing blue arrows correspond to?
#15302 42 days ago
Why this arrow blue?
#15303 42 days ago
Quoted from swampy:
100% my factory gear didn't have any grub screws. Surprisingly the factory gear simply prised off. Seems there's been a few 'factory anomalies' on my game. Upper left flipper had the wrong coil sleeve in it too.
Yes the rubber gear is included in the kit but the instructions suggest that it used to perhaps be an add-on? Was just curious as to how much this new gear quietens things down.
Without set screws your disk must be slipping a lot, which is part of the noise. I recently moved POTC from one room to another. My disk immediately started slipping again. It has two set screws. Time for some blue locktite.
#15304 42 days ago
Quoted from RobbyIRL5:
Hoping I can get some feedback on what the flipper power should be (or how it is on your all’s in comparison). I think I’m fine but just curious. I have all coil settings to default.
Maelstrom - can make it up the ramp no issue from a hold on the right flipper.
Right ramp (leading to black pearl) - can not make it up the ramp from a left flipper hold. Makes it about halfway. Ball needs a pretty good run down one of the lanes.
Chest (when ready to lock) - can’t do it from the left flipper (can run it through when not in lock mode no issue). From the right flipper (even when just holding) it has to be a perfect shot (and I find myself pushing the flipper button harder lol). Get some rejects when it’s off just a hair or maybe the shot isn’t powerful enough.
Those are the only shots that really require power. Is this how it should be or do I need to up the flipper coil values and/or consider rebuilding (assuming not the case, machine was very well maintained before I got it).
Your left flipper sounds weak. You should definitely be able to hit up the ramp to the black pearl from a left trap.
#15305 42 days ago
Quoted from TICTAC:
Are you in On Stranger Tides multiball when it's flashing blue? I know one of the times that arrow flashes blue is during that multiball because the chest/inner loop combo is one of the three jackpot shots for that multiball.
#15306 42 days ago
Quoted from LOTR_breath:
I've added the silencing kit to my disk and it's still so loud I can hear it spinning when someone is playing and I'm in another room. It's by far the most annoying issue with my pirates.
#15307 42 days ago
Quoted from EaglePin:
I would be interested in the blue arrow indication as well. Yes, it flashes during MB to indicate double and triple jackpots. But it is flashing blue in one ball play as well, sometimes The inner loop and sometimes the chest shot. I have no idea what the pin wants me to tell.
#15308 41 days ago
I’m having a little garage sale and I have a potc cabinet decal set. I used the right head decal to cover some shipping damage but the other four are brand new. Anyone have any need for those?
#15309 41 days ago
Quoted from paynemic:
I could. I'll shoot you a message.
#15310 41 days ago
Quoted from Zora:
When the game begin, the inner loop is flashing blue & red. After many multiball, I have seen there are two blue arrows without flash (Chest & right loop). But I don't know why?
#15311 41 days ago
How light an extra ball?
-With map awards- With Mystery awards- With constellation (10)- with liar's dice- But others???
#15312 41 days ago
Quoted from TICTAC:
...and with pirates lane award, I red here comes up after 5 finished pirates lanes.
#15313 41 days ago
Quoted from Zora:
Yes I forgot. Is there any other?
#15314 40 days ago
Quoted from TICTAC:
Special and/or Replay can be configured to award an extra ball if you like.
#15315 40 days ago
Woo hoo! I finally cashed in a good Shot X shot. So I had 6X playfield running from a Mystery award. Got Shot X lit and hit the 5x target. So my next shot will be 30X, but I'm not in a mode or multiball! I'm trapped on the right flipper so I just shoot the Devils Triangle spinner and BOOM! 1,800 points per spin. I didn't exactly see the total but it felt like a couple hundred thousand points. Great feeling!
#15316 40 days ago
Quoted from zaphX:
OK, but I prefer original setting.
I think there is something extra ball when you progress. But I don't where it is?
To bad!!!You haven't mission at this time! Devil's triangle spinner was a good idea!
#15317 36 days ago
Quoted from arzoo:
For me removing the hinge bolts was the most difficult part of the project - they were so tight the plywood veneer chipped on the inside
For my second set I went with PinGraffix blades which have larger holes, so no need to remove the hinge bolts.
Btw, wet method is absolutely the way to go.
I just got pingraffix potc blades and they don’t have holes for the knobs maybe I ordered the wrong ones ? Can u tell us which one u got ?
#15318 36 days ago
Quoted from Oneangrymo:
These are the one I purchased and they had large holes for the hinge bolts. As I recall the holes were cut but it wasn't obvious until I peeled the graphic from the backing.
#15319 36 days ago
Quoted from arzoo:
Hmm.. I see no holes at all, I guess Ill try peeling it and see what happens. I hope they are there because putting this thing on without those holes is going to be a pain, the Woz blades fit like a glove, it was quick and easy.
Thanks for the info.
Update, mine dont have holes, I will contact pingraffix see if they can do something.
Added 33 days ago:
Update update.. Pingraffix sending me new set. Awesome customer service, responded in like 1 day.
#15320 36 days ago
Anyone hear of any code updates?
#15321 36 days ago
Quoted from 3pinballs:
I hear it will come when he is ready to finish it. Pretty much up in the air it seems!
#15322 36 days ago
I initially misread BOOM as you scored 800M from the spinner. I need better glasses.
#15325 36 days ago
No news on when, but I did hear Eric on a recent Twitch stream mention that the new code will address the inner loop opto not registering some shots when the ball is moving too quickly. I had not heard that specific fix before.
I know several of us experience that so it’s great to hear that it’s something they can address with software.
#15326 35 days ago
Quoted from Galooch:
Hopefully additional callouts and other surprises would be Great plus the Wizard Mode
#15327 35 days ago
My son is learning the "He's a pirate" (the POTC main theme) on piano, and he plays it (pretty damn well, I must say) ALL the time. It occurred to me the other day that that song is not in the game! Or at least not in any noticeable place. Maybe it's time to get back to working out how to add assets to the game. I love this game quite a lot but I certainly would like to customize it like with Sterns and WPCs via PinBrowser/Pinsound
#15328 35 days ago
The main theme. I Believe they said was too expensive to get the asset (I don’t think Disney owns the rights). But seriously there needs to be some attract music put in
#15329 35 days ago
You can watch Eric play JJPOTC tonight and see some explanations of the game - it's a good format to learn from.
#15330 35 days ago
Arrr me buckos!
-1
#15331 35 days ago
Had an LE and sold/traded it for a reasonable price a few months ago. I miss it already.
Anyone have a SE or LE for sale or trade near St. Louis?
I would put BSD, MET, or WONKA on the chopping block for trades and add cash.
#15332 34 days ago
What makes the Super X timer go and what pauses it? I notice lots of times I have the Super X going and it's not counting down
#15333 34 days ago
Quoted from palmab03:
Well, it won't count down if it's in any scoop of course. But today I noticed it paused even while in the slingshots for a while. I wouldn't have expected that.
#15334 33 days ago
Quoted from Zora:
On the standard, the blue arrow represents the next constellation shot since it doesn't have a star map. I'm not sure if it does the same on the LE/CE.
#15335 32 days ago
Quoted from Vertzilla:
On the LE/CE, shooting the star map when no chapters are enabled will briefly flash the constellation shot white. I would have assumed this is the same on the standard.
#15336 32 days ago
Quoted from arzoo:
ya thats whats happening on the SE as well.
#15337 32 days ago
Interesting, seems to be that nowbody knows the sense of the blue arrows.
#15338 32 days ago
Quoted from Zora:
Maybe it's in the next code update?? oh... yeah... that's right...
#15339 32 days ago
Quoted from Rdoyle1978:
Then we will know in the next 1 or 2 years.
#15340 32 days ago
OMG! I had the problem where the ball hops over the rail and onto the apron last night. What a PITA! If you try to slide the glass down the ball just gets tighter and tighter. I finally got it pushed back into the shooter lane with a large piece of thin cardboard. I since have raised the rail on the apron as high as it will go. I hope that prevents this from happening again. I hope you never have this happen. It's a real stress inducer.
#15341 32 days ago
That sucks! But that's generally what you have to do. LTG told me
#15342 32 days ago
Flat plastic ruler, or paint stick works good for this.
#15343 32 days ago
Quoted from arzoo:
Oops you're right. I think I may have gotten a constellation shot when the arrow was flashing and thought that's what it meant. Just checked now and it was flashing blue on the inner loop with nothing on. I started and drained Stranger Tides and then it stayed on the chest. Making the chest lit the loop blue for a few seconds. Maybe it's a broken combo shot indicator.
#15344 32 days ago
Quoted from arzoo:
Thanks, I didn't know.
For the blue arrows???? It's a mystery!
#15345 30 days ago
We will be streaming JJPOTC LE tonight at 6PM EDT - https://twitch.tv/owlnonymous
#15346 26 days ago
I took pinball mod company’s spinning pop bumper barrel and motor. Added my own cursed pirate figure to it.
#15347 25 days ago
This will be my last night in the club. It has been a blast. I was lucky to have a game with no real issues. I've played the heck out of it and time to move on. Good luck!
#15348 25 days ago
Quoted from Crile1:
Can't wait to see your next post saying "I've made a huge mistake!"
#15349 24 days ago
When the profit runs out he will
#15350 23 days ago
So I wanted to see if I could add a mermaid somewhere on the playfield. This is all I could come up with. Haven't decided if I will keep as is or remove. Wish I could see the tail more. I might try to touch up the skin so it blends in more.
12,900 (OBO)
Sale Pending!
Canfield, OH
Plymouth, MN
$ 39.00
The MOD Couple
$ 53.00
Hookedonpinball.com
$ 41.25
The MOD Couple
$ 87.95
9,900 (Firm)
Sale Pending!
Calgary, AB
$ 87.95
