Quoted from Psw757:White lithium is one of the highest regarded greases for gears in the Rc world. Doesn’t soften plastics or rubber and doesn’t break down like most dry lubes, Teflon lube and other ptfe lubes.
I will report back once I lightly apply.
I used to restore antique (1930's-1950) Wulitzer and RockOla jukeboxes and an old mechanic told me to use white lithium grease on the moving parts of the mechanisms. I did that and after a couple of years the white lube turned into a gummy compound that caused the mechs to freeze up. I had to tear down all of the mechs where I had used it, remove the offending grease, and relube with gun oil which worked like a charm. I guess I could do the same (gun oil) on my pinball gears but I am going to try the dry lube approach and see how it works. But, I will never use white lithium grease again. I know many swear by white grease; I swear at it. Best of luck to you.
