(Topic ID: 200141)
JJP Pirates of the Caribbean Official Owners and Fan Club!
By goren1818
  • 17,125 posts
  • 574 Pinsiders participating
  • Latest reply 1 day ago by jsa
  • Topic is favorited by 274 Pinsiders
20 key posts have been marked in this topic, showing the first 10 items. (Show topic index)
There are 17125 posts in this topic. You are on page 272 of 343.
#13552 1 year ago
Can someone tell me where this came from. Playing game and looked like it came from the pearl not sure stopped play and shut down.
#13553 1 year ago
Quoted from FryDaddy:
Looks like the back of an opto thingy.
#13554 1 year ago
Quoted from LTG:
Where do I look. The only other thing i did was took off the wire stop by the glass to rebend. I heard something drop but could not find anything.
#13555 1 year ago
Where do I look.
At every one of the optos in the black plastic case in the game. From the spinning disc back.
Or see if it comes up in error. ( it may still work if stuck in it's hole )
#13556 1 year ago
Quoted from LTG:
Not the back of an opto thingy, too short.
#13557 1 year ago
Not sure but it looks like it is to stop a ball from drain to shooter rail. If you look the line stops where it might be.
#13558 1 year ago
I know it is hard to see but same line.
#13559 1 year ago
I know it is hard to see but same line.[quoted image]
Not plastic it's metal
#13560 1 year ago
Thanks for sharing this. I think mine has the same side to side play. I would assume they all do given the way the mech is. Maybe not...
Here's sort of my frustrating thing... when I try to move the plunger rod to be more centered within the auto forks (so moving the plunger tip/assembly to the right), it tends to collide horribly with the auto forks where basically every manual plunge is crashing into the auto forks.
You can't theoretically have the plunger assembly (that is the 3 screws) any lower than the lowest screw on the bottom so I'll continue to mess with this. Oh... I also noticed .. as I was tightening that bottom screw it was sorta raising the elevation of the other two screws (the plunger assembly) which is no good so maybe I can only tighten so much, test, add the other top screws and then finish tightening the bottom.I thought I raised the playfield enough, but it looks like that plunger washer still just wants to rub against that auto plunger mech...sometimes.
On a completely separate thought - I wouldn't be surprised if my wireworms aren't perfect.
Has anyone ever manually rode a ball all the way up the shooter lane - like with their hand? It's not smooth..
In this photo, that horizontal bar underneath the wireform right above where I have the ball positioned, there is a very noticeable bump. I have highlighted the suspect area:
#13561 1 year ago
Quoted from joseph5185:
You could loosen all 3 screws in the shooter housing, then place a washer between the housing and the front of the cabinet (at the bottom of the housing) and tighten accordingly. This will cause the top of the housing (and therefore the tip of the plunger) to point down slightly.
#13562 1 year ago
I was sent a new wireform as mine was not formed properly. There was a flat spot that the ball collided with and caused a loss of a lot of momentum.
#13563 1 year ago
Quoted from KingPinGames:
I may just do this. I just don't really want to raise the playfield anymore. Ever since doing so, that yellow lockdown bar goes nowhere near back where it used to. In fact, it basically just hangs down and won't budge.
Also, I feel silly for this... but I just realized that I can adjust the shooter assembly while actually having the playfield down and a ball in place going through the coin door. I definitely think this would help as I wouldn't be completely blind if you will when adjusting.
#13564 1 year ago
I'll move this conversation over to the Tech Thread... but I think this is part of the issue.
https://pinside.com/pinball/forum/topic/jjpirates-of-the-caribbean-troubleshooting-tips-issues/page/3#post-4941271
"Third, see if the ball moves freely through the metal ball guide that goes up and over onto the playfield. It may be making contact with a weld instead of riding only on the rail guides, robbing the ball of power.
#13565 1 year ago
Quoted from BC_Gambit:
I MAY have this exact issue.
Did it sound anything like this?
https://drive.google.com/open?id=1WMXja4uYKU3QZ8EuAcn7-_4pquc_-cA9
#13566 1 year ago
Is it the ball catch for when you lift the PF?
#13567 1 year ago
Basicallly, if you move the ball through the wireform by hand (I discovered this when I removed the wireform from the game, but this should not be necessary) does the ball hit that piece of metal rather than move over it?
My old wireform hit hard, my new one not at all.
#13568 1 year ago
Can someone tell me where this came from. Playing game and looked like it came from the pearl not sure stopped play and shut down.[quoted image]
Found the same part in the bottom of my cabinet. Couldn’t find where it’s from and everything is working so just stored. Doesn’t look like a typical pinball part. Hopefully someone knows.
#13569 1 year ago
This is from the manual can you look and see if that piece is in place. Trying to find a better pic but at work.
#13570 1 year ago
So there it is...
A faulty shooter lane from day 1 that I didn't notice and I guess? quality control didn't check. The list grows with issues. I just feel like it's not "okay" after spending near $13,000 on a... game.
Surely, I can't be the only one that feels this way, but I'll take my disappointment and thoughts elsewhere.
#13571 1 year ago
Got same problem wich i had two months ago. The right flipper on the boat is not aligned well. Looks like an easy fix but not if i must do this every two months
37923A40-A45C-410E-825E-DBCB4E3A8F46 (resized).jpeg6062C038-6F57-49EB-8CD3-7FD50DC22C12 (resized).jpeg
#13572 1 year ago
Quoted from heni1977:
My ball catch is chrome plated - but good guess. Its about the same size.
#13573 1 year ago
Quoted from Munsters:
Got same problem wich i had two months ago. The right flipper on the boat is not aligned well. Looks like an easy fix but not if i must do this every two months [quoted image][quoted image]
Yea. Had this issue from the beginning. I think many did and assumed it was "supposed" to be that way. Not symmetrical flippers? Not in my world...
Anyways, perhaps you can tighten the flipper more than last time and/or use loctite to better ensure it doesn't happen again.
Sorry to hear...
#13574 1 year ago
For sure that looks like a hole for an Opto - and you can see an outline of where an opto might have been plugged in... but I've not see this part...And I've had the BP out.
#13575 1 year ago
So there it is...
I don’t think you’re the only one, there’s nothing wrong with feeling disappointed about it, and I don’t think there should be any need to take your thoughts elsewhere. You’re a pirate same as the rest of us and we’re all in it together to help, as evidenced by the great support and suggestions people have been providing on this issue for you.
There’s nothing wrong with getting frustrated or disappointed with build, service, code or any other issues. It’s a great design and great game to play but that doesn’t mean there can’t be valid criticisms too. This game has required a lot of tinkering. I don’t know how it compares in that regard to other recent new games but it doesn’t really matter because each person has his/her own view of how much is acceptable vs reaching the point of feeling like things should have be been done better by the manufacturer.
#13576 1 year ago
I appreciate it.
Without this community, many would be lost...
I personally feel like my experience has been 50/50 as far as being better done by the manufacturer. Some things are blatantly obvious and some things are not. You just don't want to think that the company knew about some of these issues and were like "F it, ship it anyways!" We'll never know I guess and I'm trying to not sound like I am insinuating this, but I really hope that simply isn't the truth.
Anyways, the shooter lanes aren't currently available for replacement so it just stings that much more now because I don't know how long I will have to deal with the lackluster plunger issues. Perhaps forever?
I sincerely hope not...
EDIT:
I have put in a tremendous amount of work on this machine as so many others have and I can confidently and proudly say that it's probably around 98/99% as far as playability and functionality. Once I get over this current disappointment I'm in, I do look forward to continue playing and hopefully putting many games on this awesome game.
I don't mean to sound unappreciative in the slightest if it feels like it comes off that way. My girlfriend is over it considerably more than I am understandably for the issues that we have had and fixed. I still think it's great, but the taste becomes a bit bitter as the issues elongate.
#13577 1 year ago
Is it binding from the playfield protector? Does the flipper move higher if you move it by hand? Is there a little vertical play in it if you lift it up and down?
#13578 1 year ago
As you (or someone) had to remove the stock assembled flippers to install that upper playfield protector my guess is you simply need to tighten the flipper pawls a bit more. Once aligned and tightened correctly I suspect you won't have any further issues. I like the mirror blades you installed.
#13579 1 year ago
Quoted from Yelobird:
Exactly this! Just remove the BP and tighten them and they won’t/shouldn’t move on you.
#13580 1 year ago
Had time to set down and look through the manual and is item 5 part # 10-100011-00 it is there to put a bump in the road so it is a little harder for the ball to go back to the shooter lane.
#13581 1 year ago
Quoted from EaglePin:
Well said.
#13582 1 year ago
So I did a little searching but couldn’t find what I’m looking for.
I’m helping a friend open the last LE out of Australia and a little worried about the unboxing and tuning (mine was used and already tuned). Anyone have a best practices list or flowchart for setting up a new potc? I assume this was built later in the run but I don’t know that for sure. Should I be worried about QC and having to fix a bunch of stuff right away? I have a set of cliffys. Are all of them 100% necessary? Are they hard to install? Etc.
Advice please.
#13583 1 year ago
Quoted from paynemic:
Advice please.
Step one, order the conversion kit direct from JJP that converts from Aussie power back to US power. DO NOT plug the machine in in without doing the full conversion FIRST.
Step two, check out the technical thread here:
There's an index in post one to almost everything you could need to know to tweak and fix the machine.
Step three, enjoy one of the best pins ever made!
#13584 1 year ago
Quoted from PinMonk:
Thanks! I have the kit already. That will happen. I will definitely check out the tech thread...
19
#13585 1 year ago
CE 146 is in the house!
#13586 1 year ago
where is the bottle?
#13587 1 year ago
Quoted from Ballypinball:
Probably removed for shipping
#13588 1 year ago
Does anyone sell shorter standup posts shorter than the factory ones ? My ship never aligned with the cannon so I can never make the shot,I read the fix is to use shorter posts to bring the ship back some to the backbox which would fix my issue
#13589 1 year ago
#13590 1 year ago
Quoted from zaphX:
There's the bottle!
In your... theatre room no less?
If you have audio popping, I know EXACTLY how to fix it!
#13591 1 year ago
There's the bottle!
Media room and pin room. It doesn't hold many pins, 3 currently.
#13592 1 year ago
Quoted from zaphX:
Every media room should have his and hers Pirates!!!! Love it!! Everyone should own 2!!!
#13593 1 year ago
That's a tall order since they are unobtainium!
#13594 1 year ago
Quoted from zaphX:
Remove that sofa and you can likely fit 3-4 more, lol!
#13595 1 year ago
Quoted from mtp78:
Topic index links on the top of this page: post #6315
I had the same issue, I wasn’t even close. I ordered the parts and changed the spacers. Overall easy job to replace them. It’s perfect now, I can hit it every time with good timing.
#13596 1 year ago
Too funny....Between the two of you guys(Yelobird Zaphx) you own four Pirates...Share the wealth man
#13597 1 year ago
zaphX nice man! We have similar tastes in movie room setup.
#13598 1 year ago
Fellow pirates.
I need help.
I've been spending the last 2 days reliving all my POTC history...doing all the tweaks and bulletproofing steps we all know and love to my new CE.
Cleaning, rubbers, wireloom, waxing, Cliffys, spinner leveling, shooter lane adjustments, spotlight replacements and bulletproofing, Tortuga scoop aiming, Chest fork tweaking, you name it I've done it over the last 2 nights.
It is almost where I want it, save for one issue...and the LE has the same issue.
The damn Depths VUK.
Frequently, the ball shoots out of the VUK - seemingly harder than usual - and it seems to hit the one way gate at the I lane like it's a wall, then drains.
When this happens it makes you want to quit pinball.
And both of my machines are doing it, so I am stumped.
I considered, maybe the Depths Cliffy is the cause and is putting some kind of spin on the ball? That one is a clip-on so I removed it - it did not make an appreciable difference.
Of all the issues we've troubleshot together, surely someone has come up with a fix for this one?
I would truly love to solve this on both machines.
#13599 1 year ago
Quoted from zaphX:
Fellow pirates.
I need help.
The Depths cliffy did not affect that here. Have you slo-mo'ed the eject of the ball to see what's different about the times when the ball comes screaming out? I'm thinking maybe the angle of the scoop curve is a little too high or too low?
I know that if it fails to eject, it will increase power and try again, so maybe there's a failed eject you're not seeing/hearing and the fast ones are the second try?
#13600 1 year ago
Quoted from zaphX:
Fellow pirates.
I need help.
I hated that about the game when I had mine. The fix I found was to lower the power of the vuk as low as it would possibly go. I agree, when that would happen I would shut the machine off and walk away. I had no cliffy in mine and it was happening. Another thing you could try is loosening the inlanes and messing with the geometry slightly before tightening again
