(Topic ID: 200141)
JJP Pirates of the Caribbean Official Owners and Fan Club!
By goren1818
2 years ago
  • 12,953 posts
  • 476 Pinsiders participating
  • Latest reply 16 hours ago by Munsters
  • Topic is favorited by 221 Pinsiders
There have been 2,274 images uploaded to this topic. (View topic image gallery).
20 key posts have been marked in this topic (Show topic index)
There are 12953 posts in this topic. You are on page 240 of 260.
#11951 78 days ago
Quoted from Heater:
All this time I've been playing my game with the volume loud and sub woofer turned way up (and my wife really loves me for that). This weekend I finally decided to try using headphones just to see what it was like. What a difference! I had no idea the small little background sounds and the quality of it! Just the complete sound of the cannons firing is incredible! And the best part is I can't hear my wife yelling at me to take the trash out!!! If you haven't done it yet, try it!!!!
The soundscape on this game is absolutely superb. It is a crime that the TWIPY went to Iron Maiden, as it really should have gone to POTC.
#11952 78 days ago
Quoted from Heater:
What brand/model headphones?
A while back, I tried to purchase a set for DI, but none would work properly. I bought/returned 7 sets in one day. Best Buy threatened to ban me from the store. haha.
#11953 78 days ago
Quoted from Heater:
Unfortunately you are going to need to remove the BP. Once you do that you can easily remove the nuts that hold the plastic. While there you might as well do a good cleaning and check the mylar in the starmap. After you remove it a few times, it will be second nature and not a big deal.
Quoted from koops:
(If I am asking this in the wrong thread please let me know!)
I’ve been reading through all the old posts and saw the yelobird lantern fix.
I can’t remove the left side of the black pearl plastic due to the rear of the ship holding it down. Am I supposed to brute force it over the top?
Are you talking about the black railing on the left side of the upper playfield in your picture (with the nut in the middle of it) or the clear plastic under the upper playfield and above the star map area? If you mean the black railing in your picture, can you remove the back of the Pearl so you can lift that plastic off? The left side top rear of the ship above the cannon door can be easily removed by three nuts behind that section near the coil on the back of the ship (between the upper playfield and the back board of the cabinet). Maybe you can lift that section up so you can remove the railing plastic?
If you’re referring to the clear plastic over the star map then go with what Heater suggests.
#11954 78 days ago
Quoted from EaglePin:
The black plastic that has the lanterns on them. I couldn’t see any screws that held in that rear plastic and I feared that it was held in from the underside. I need to adjust the left “load” switch anyway. It leans left under the gate so most shots don’t register.
#11955 78 days ago
Quoted from koops:
Yep, here's a link to a post with a picture of what it looks like with that rear plastic off, and the three screws that fasten it from the back.
https://pinside.com/pinball/forum/topic/jjpirates-of-the-caribbean-troubleshooting-tips-issues/page/40#post-5154002
#11956 78 days ago
Backboard lighting is finally done, so anyone who ordered will start getting some ship notifications. I think it came out pretty good.
#11957 77 days ago
I need to check my Sub now after hearing that
#11958 74 days ago
It's bit a moment but we're ready to ship our spinning pop bumper upgrade. Works for all versions of the game, a great upgrade for a matching set of interactive barrels on your LE/CE and CE's can upgrade to the Davy Jones model.
Only a few of each character in stock. Jack's might be able to be found still, but Davy's are hard to come by.
SE is a plug and play install, no complex wiring or soldering. Only need a ratchet and a screw driver. Should take about 20 minutes for a mechanical person, maybe an hour if you are meticulous.
Install video is being produced. Thanks for the patient waiting while we perfected this. 10 different prototype sets were created, finishing techniques tested and lighting toppers custom finished for best light transmission. The interactive lighting looks awesome. Videos will be posted to the product thread and website shortly, waiting on processing the uploads.
https://pinside.com/pinball/forum/topic/jjpotc-spinning-pop-bumpers-upgrade
#11959 72 days ago
Issue with too many balls being put into play after 2 have been locked in the chest. Played 2 games this evening as 3 player games with friends and both times the game kept spitting out 3 balls into the plunge lane for each turn. Anyone experience this and know a solution?
#11960 72 days ago
Quoted from Buellxb12r:
Adjust the chest release coil timing up or down until it’s doing the right thing. Easy fix, no tools needed!
#11961 72 days ago
Quoted from zaphX:
Why would the timing of the chest release have anything to do with how many balls are spit in to the shooter lane?
If I recall correctly, POTC like WOZ knows how many balls are locked up and adjusts when it knows a locked ball is missing.
Sounds like the shooter lane switch or trough optos might have some issue, no?
#11962 72 days ago
Quoted from harryhoudini:
Ah I misread. Thought he was talking about the chest spitting out too many balls at once. Mea culpa.
#11963 72 days ago
Quoted from zaphX:
Has anyone had to trim the foam in the chest? At first my game was fine, then the chest release wasn't opening enough so I bent it some. Now the balls aren't rolling, I think due to the foam. I was going to trim a little off with a scalpel or razor blade
#11964 72 days ago
Appreciate the feedback but I don't think it's any switches at all. Tested them and have no problems, turned on virtual lock for the chest and no longer have the issue. But it seems like when 1 player gets 1 locked and it remains in the chest, then another player gets their first chest lock, it thinks another lock is a multiball or something. Seems like a coding issue.
#11965 72 days ago
And now while we have been playing it randomly has the flippers go dead while playing a ball. No apparent reason or consistency. Totally random. I love this game but I've had to put so much work into it. More and more random problems that show up.
#11966 72 days ago
It thinks the ball has drained. So you likely have a loose connection in your ball trough or a bad opto.
Go into switch test mode and see if the optos for the trough all are ok. Then smack your open palm on the playfield firmly and see if any change.
#11967 71 days ago
Quoted from PinballTilt:
I experienced the same problem after a few games with the chest not releasing balls. I learned that the pulsing of the star map magnetized one or two of the balls rapidly. I observed the chest mech opening and the ball struggling to get out or not rolling due to them sticking together coupled with the chest being on a ever so slight incline. It wouldn't do it all the time depending on which balls was in the chest. I changed the balls and the problem would go away for a while until one got magnetized again. The long term fix is carbon steel balls. I have had no problems since. The easiest way to adjust the release is slightly bend the bracket that holds the coil. The sweet spot is when it opens enough to let a ball out but on a 1st locked ball doesn't roll right through it. I wouldn't recommend trimming the foam as it guides the ball through the release arm.
Good luck hope you fix it.
#11968 71 days ago
don't have this issue.
have another : no choices in preinstall modes, like 3balls, 5 balls, or easy normal etc.., screen is blank...
And strange that is no official music theme of POTC no ?
#11969 71 days ago
Quoted from Thot:
Normal normal and normal. Music was supposedly too expensive or some shit. And presets are still not in the programming. Why when people start bitching about code updates I always mention the most basic thing (presets) are still not in game.
#11970 71 days ago
Just sent deposit in to join this club. Decision to purchase was 100% based on Pinside positive reaction to this game. I've done this sort of thing before and have never been led astray. Hopefully will get either next weekend or the following. Hurricane Dorian might push back getting this bad boy a bit.
Very exciting.
#11971 71 days ago
Quoted from VolunteerPin:
Very exciting.
nice job!
#11972 71 days ago
Very exciting.
Welcome! Never a dull moment owning a POTC.
#11973 71 days ago
Quoted from MurphyPeoples:
Because of fun or the tweaks needed? Maybe both?
#11974 71 days ago
Definitely both.
#11975 71 days ago
VERY fun game to play!!! Tweaks haven't been too crazy. Welcome aboard!!!
#11976 71 days ago
Quoted from vireland:
FYI, adding to my previous post, the issue was ocurring in 1 player mode as well. As soon as 2 balls were locked in the chest, it would feed three balls into the shooter lane every single time. So I don't know why it only occurs when there are 2 locked balls in the chest. Appreciate the suggestion, prior to reading your suggestion I went and tested all the switches and optos in the menu. Manually put one ball in the trough at a time and they all tested fine. I went and "force calibrated" the ship, checked optos in the chest trough, etc... Don't really know what fixed it, but it seems to be working properly now even though everything checked ok in the first place. Further diagnoses will have to wait until October when I get back from a work trip to Alaska.
#11977 71 days ago
I don't think it has so much to do with how many are in the chest, but how many are left in the ball trough. That's where I would concentrate (the 4th and 3rd ball positions) if it reappears (and it probably will).
#11978 71 days ago
Makes sense, thanks for your input. I'll check in October when I get back.
#11979 71 days ago
Yup, the code knows what it is in the chest. As long as the chest optos are reporting correctly the game seems to properly adjust based on that. Usually with the shooter lane ball load issues it's the lane switch or the trough switch.
#11980 69 days ago
Not a big issue, but has been doing it since I've had it in January, but seems odd and no one even notices it but me.
Sometimes in gameplay I'll hear the sound that it makes when you boot it up and it tells you that there is a switch error. It seems software related and will probably be fixed when the next update comes out, but was wondering if anyone else has heard it.
#11981 69 days ago
How heavy is Pirates? Will a 300lb (max load) bar stool be able to support Pirates while I install the rear legs? I plan on installing the front legs first then lift the rear end and rest it on this bar stool. The machine is still in the box. Thanks!
#11982 69 days ago
Quoted from KornFreak28:
IIRC the box was listed as 330lbs. It's gonna be close.
I would strongly recommend you build the Harbor Freight pinball lift with the bimini cap mod. It's game changing for this!
#11983 69 days ago
It should be fine. Pretty much what I did. I’m with Zaphx though less than 100 bucks for a good lift table from harbor freight makes things so much easier.
#11984 69 days ago
Thanks guys! I got the HF lift cart, but I find it difficult to wedge it under the cab when the front legs are on the ground. I do plan on immediately putting it to use as soon as it’s resting on the stool to help support the load. I just hope the stool can withstand that minute or so while I get the cart in place
#11985 69 days ago
God it’s heavy. But I am pretty sure DI is heavier. Between 325 and 350
#11986 69 days ago
Quoted from Rdoyle1978:
I have no frame of reference but if DI is heavier than pirates my mind would melt. They are both packed but I would expect the widebody to be appreciably heavier.
Pirates is the only game I have had a hard time tipping on my dolly. I needed help.
#11987 69 days ago
Fwiw I believe ‘weight rated’ items usually bake in a little wiggle room when it comes to maximum loads. So I would imagine an extra 30lbs for a few minutes would be just fine. Especially if you had an extra set of hands helping out for those couple minutes.
Caveat emptor and all that jazz
#11988 69 days ago
Quoted from anathematize:
I agree with you. Only problem is, only the wife can lend a helping hand atm and the stool is from HF
#11989 69 days ago
Here's a fun little video I made of the spinning pop bumper upgrade.
#11990 68 days ago
Also keep in mind that the weight of the pin is shared between the front legs and the stool, so you should be fine. At least I think that's how gravity works
#11991 68 days ago
Quick question.
A ball gets stuck occasionally and i have to trap up, open the coin door and remove the glass to retrieve the stuck ball. However whenever i do the flipper goes dead and drains my ball. Frustrating only seems to happen when i have a good game going. My buddy said its a setting. But i cant seem to find the setting.
#11992 68 days ago
Quoted from bgwilly31:
Quick question.
this is not a setting, this is the interlock switch on the coin door to disable the high voltage when you open the door.
where is the ball getting stuck?
#11993 68 days ago
Quoted from KingPinGames:
well my maelstrom Modcouple mod keeps falling into the hole.
But so theres no way to make it so the flippers dont lose power.
#11994 68 days ago
Feel free to send me a PM and I can try to help you.
#11995 68 days ago
Quick question.
You're better off shooting the ball into the MAP hole or The Depths or somewhere where it will need to be ejected, THEN opening the door because then the coil to kick it out won't work with the door open and the interlock switch off.
12
#11996 68 days ago
So I get a call today from Pinballsales.com.... Figured it is from back when I was looking for a POTCLE, voicemail is Jack and he wants to talk about my POTC. So I call back. Get this.... he is refunding my spare playfield purchase. Holy cow, I was not expecting this!!! I was happy to pay $550 for the playfield. He tells me that a couple people that he knows who replaced their playfields have not had any problems.
Stand-up guy that Jack!!!
#11997 68 days ago
Quoted from kcZ:
That’s fantastic news from a fantastic company! I recently reported chipping issues on my CE so hopefully I hear something as well.
#11998 68 days ago
Jack, JJP Jack? Or is this some other Jack?
#11999 68 days ago
Really ?
#12000 68 days ago
that is cool.
$ 41.25
The MOD Couple
Pinball Photos
Flagstaff, AZ
Gweem's Mods
Pinball Mod Co.
