New! Dark mode!
(Topic ID: 200141)
JJP Pirates of the Caribbean Official Owners and Fan Club!
By goren1818
2 years ago
  • 15,638 posts
  • 529 Pinsiders participating
  • Latest reply 6 hours ago by GnarLee
  • Topic is favorited by 255 Pinsiders
There have been 2,684 images uploaded to this topic. (View topic image gallery).
20 key posts have been marked in this topic, showing the first 10 items. (Show topic index)
There are 15638 posts in this topic. You are on page 215 of 313.
#10701 1 year ago
Quoted from Soulrider911:
Got the shine back after some deep cleaning[quoted image]
Oooh nice work! Crazy how much crud can build up, and then be cleaned off so well. What did ya use?
#10702 1 year ago
Can you show the after pic with the light shining on the PF the same as the before pic and at the same angle?
#10703 1 year ago
Wow!
What did this entail?
#10704 1 year ago
Basically degreaser, and then wax, buff, is some areas I used very light novus 2 - ya I know... - but after I cut with a finer compound and it got out some serious ball scuffing. Then wax
#10705 1 year ago
Degreaser...wait what?
#10706 1 year ago
Yep simple green or grease lighting works wonders and here is the pic u wanted f3honda4me
#10707 1 year ago
Yep simple green or grease lighting works wonders and here is the pic u wanted f3honda4me[quoted image]
There we go. Now we can see direct comparison. Looks fantastic. Nice work getting it shiny.
#10708 1 year ago
Method? All by hand? My WOZ looks like your before and I did the NOVUS 2 and wax and it still looks like it did. I can't imagine how much rubbing I need to do to get it like your POTC. My JP just got clear coated and it took a LOT of buffing with a wheel to get it looking so nice and some different compounds. I even have a small wheel for my drill and that is way too big and messy to do that with the PF in the game.
I was thinking of looking for something for my dremel. I have "programmers arms" (fucked up) so it's hard to buff by hand for too long.
** Just saw your post on method... I can't believe that is just wax and buffing, wow.
#10709 1 year ago
Jack sparrow is officially attached to the barrel
#10710 1 year ago
Jack sparrow is officially attached to the barrel[quoted image]
Looks like the 2nd hand market for Tom is looking quite buoyant....
#10711 1 year ago
Quoted from Yelobird:
Ok Buccaneers, how about a Friday How To tutorial on making your own Davy Jones! NOT for sale just a tutorial so please don't ask! lol Start with a not so easy to find but attainable if you keep an eye on Ebay Davy Jones Series 1 7" figure. Incredible detail and a perfect scale fit! Start with a simple nut cracker move and literally Crack him in half at the waist. While his mid section does have a plate of plastic it seemed a bit to thin for my long term liking so I added a printed solid plastic reenforcement plate and super glue. Center and match holes in removed barrel and Tom figure. Ok, this part is a bit more invasive but really Not that hard. As this figure does not have articulating elbows his arms would Not work in our spinning application with the ramps so he needed to be Persuaded to conform. Using a heat gun Slowly apply heat to his elbow. You'll know when you're there when you see a little smoke and they bend easy. To fare and you get fire. Bend both arms to 90 degrees and add rubber bands till they heat set to the correct shape. A few minutes. After mounting him its time to give that lovely cape a needed trim. I found just below the barrel top edge is perfect and still looks Flowey. (is that a word?) One detail that is IMPORTANT, after you dry fit him and make sure all spins perfect you Need to apply a small amount of super glue to All joints to lock them in place. He won't love it but he Can't move or raise his arms when spinning!! Also note how I arranged and glued his right hand tentacle to the barrel for a nice look. Spins great and other then some casual hobby time really not that hard to do. Plus on a CE this is simply Spot On! Hope this helps. Do let me know if there is anything I forgot to explain. Play on ye scurvy Pirates!!!!
The Mod Couple
[quoted image][quoted image][quoted image][quoted image][quoted image][quoted image][quoted image][quoted image]
Sorry for asking an obvious question. How do you access the two screws to reattach the barrel lid, once Davy Jones is mounted on top? I'm presuming you screw him on using the two screws underneath the barrel lid away from the machine, so once he's on, is it easy to reapply the lid to the bumper?
#10712 1 year ago
Quoted from DarthSinex:
Reattach using the allen screw through the hole in the side of the barrel.
#10713 1 year ago
Quoted from zaphX:
I have a hole in my barrel at the side but nothing in it. To take off the barrel I had to release the two screws in the top and it came off.
#10714 1 year ago
There's no reason to remove the screws on top to remove the barrel. The hole in the side leads to a small allen-head screw that locks the spinning barrel to the motor shaft. I don't recall the hex size.
#10715 1 year ago
Amazing how much coil dust had accumulated on this game. Replacing all flipper coil sleeves and cleaning mecks. Here is the Pearl.
#10716 1 year ago
Amazing how much coil dust had accumulated on this game. Replacing all flipper coil sleeves and cleaning mecks. Here is the Pearl.[quoted image][quoted image]
Wow that seems excessive for a new game. Could it be that things aren’t perfectly lined up or the mechanism has movement it shouldn’t creating extra friction on shaft and causing excess coil dust?
#10717 1 year ago
Is that a HOU game? And I guess the real question is how many plays. Some posters are playing for hours a day. Some maybe a play a week.
#10718 1 year ago
So this game came from a Home and yes its HUO as I know the distributor he bought it from.. .but i think this game was the neighborhood entertainment for all the kids... I would estimate 1400 plays.
#10719 1 year ago
Dirty Pirates! lol Great work thanks for sharing.
#10720 1 year ago
I don't know.. I was just never really a fan of the basic reddish stickers that were on the apron. I figure if I print these out for my own use probably not a big deal. Only spent a few minutes on this thrown together concept, didn't really think about the content. Anyone else think the apron got left out?
#10721 1 year ago
Quoted from harryhoudini:
I don't know.. I was just never really a fan of the basic reddish stickers that were on the apron. I figure if I print these out for my own use probably not a big deal. Only spent a few minutes on this thrown together concept, didn't really think about the content. Anyone else think the apron got left out?[quoted image]
I'm pretty happy with it!
#10722 1 year ago
Quoted from zaphX:
I'm pretty happy with it![quoted image]
Someone scribbled on yours?
#10723 1 year ago
Quoted from zaphX:
Can I have one of those!!!
Good alternative Harry. I know what you mean, but I will stick with the yellow. Your alternative will go nicely with the kraken blades. Have you contacted tilt with your idea? He does say he is happy to take on new artwork. Could be pretty cool to have a Kraken in your face.
#10724 1 year ago
Quoted from gumnut01:
Ah no, but I doubt anyone will produce it unless they somehow have license already? I figure I'll mess with it at some point in the future and see if I want to do anything. The blades do look awesome.
#10725 1 year ago
She is basically all back together! We underwent the mega clean, added new rubbers, some Chroma nuts, Cliffy's and Jack added, just need to do a few more things and should be ready to play!
Just a reminder of the before:
Ball trails and dirt EVERYWHERE
No more, clean as a whistle
Cliffys
New rubbers
Post kit and some Chroma Nuts
Jack
#10726 1 year ago
Looks clean!
Are those Titan GID rings?
Thanks for sharing. I think I have a cleaning session in the near future.
#10727 1 year ago
I'm not a fan of the red apron decals for the CE in particular. It's a shame. I've been hoping for better options.
I'd love to know why they changed the color scheme...
#10728 1 year ago
Had fun playing POTC with my daughters last night. My youngest got her personal best +150k. 100k from map skill shot after a couple inner loops using will Turner. That's a bigger skill shot than I've ever gotten!
#10729 1 year ago
Quoted from MarZ_78:
Had fun playing POTC with my daughters last night. My youngest got her personal best +150k. 100k from map skill shot after a couple inner loops using will Turner. That's a bigger skill shot than I've ever gotten![quoted image]
Is Daddy allowed to plunder? There are specific rules in our household!
#10730 1 year ago
Quoted from Reznnate:
I'd love to know why they changed the color scheme...[quoted image]
I was thinking of the CE specifically when wondering how this hasn't been mentioned before. Seems like a big cost cut. Same with my RR WOZ, one of the things I love about the ECLE. Well, I guess I can solve it for myself... I was actually thinking of making magnets so they could just be removed.
On another note.. anyone interested in a Maelstrom wave to hide the switch? I think it'd go well with a light blue LED strip under the Maelstrom.
#10731 1 year ago
I encourage them to plunder me as much as possible. I usually don't... but every once in a great while I do. Gotta keep em on their toes. Ill plunder a ball every time though.
#10732 1 year ago
Because everyone complained about it.
#10733 1 year ago
Cliffys
New rubbers
Jack
Looking great! Just love the feeling of a freshly cleaned pin.
Some owners amaze me at how far they let these things go. Spend $10.5k on a pin and don't even bother to take the glass off?
On a side note, thanks for hooking me up
#10734 1 year ago
On another note.. anyone interested in a Maelstrom wave to hide the switch? I think it'd go well with a light blue LED strip under the Maelstrom.[quoted image]
My own Personal mod.. I had so many balls jump the maelstrom I made this plastic and extended the rock into a Splash out section.
The kraken is now also in , cut away some material, before applying the final texture to make the rock match the devil triangle
E6890D89-083F-4F61-9851-669A63DC5541 (resized).jpeg1DF5E067-8D58-4A18-A21C-97553F262D48 (resized).jpeg212FB4E1-BA8A-4883-9365-8ED3430B4C00 (resized).jpegB7D46966-68FF-4FA4-929B-6CD9D536CEA1 (resized).jpeg
#10735 1 year ago
Quoted from steigerpijp:
The kraken is now also in , cut away some material, before applying the final texture to make the rock match the devil triangle[quoted image][quoted image][quoted image][quoted image]
What?!?!!! Did you document the process? Or you selling?
#10736 1 year ago
Fairly certain it wasn't a cost cut changing the apron sticker art. Sadly it was a majority complaining (if you look all the way back in the posts) that they didn't like the original art. SO wish they would have left the nice dark art as on the original. The bright orange just doesn't go in my opinion.
#10737 1 year ago
Not just your opinion, it's a fact. The original art actually matches.
#10738 1 year ago
If I can find a decent lightweigt and durable material to cast this I could ,but its a big ol’ lump of rock
Need to finalize it first , been using it for months without hang ups so at least thats something .
#10739 1 year ago
Quoted from vireland:
As I have the original I am planing to make a run of them as none of the art is licensed vs doing character art which would get you a call from Disney. lol
#10740 1 year ago
Why is your treasure chest closed?
#10741 1 year ago
Quoted from dts:
Well, It was broken for a long time but now its “ fixed”
https://www.icloud.com/sharedalbum/nl-nl/#B11JqstnBJF1jPF
#10742 1 year ago
I like the rockwork you did. First thing that came to mind was 2 led strips added a red one for maelstrom ramp and purple for DT all hidden by the rockwork.
#10743 1 year ago
Cool, when are you going to install the 3 spinning discs?
#10744 1 year ago
Oh, that’s great! Like a prototype. I’m assuming you modded a CE? I’d love to have the chest work.
Oh, I missed the other thread. Looks like some great progress on this.
#10745 1 year ago
Great job!
I too have the same Jack and I need to find the time to do a tear down with cliffys to install as well as a good shop job! And also get the T nut fix done.
#10746 1 year ago
I'd buy one of those clear plastic retainers to go around the maelstrom ...
#10747 1 year ago
Im sure this has come up... How does one adjust the map disk height/angle. I expected to find a similar attachment to the creature playfield window where it attaches with rubber bushings, and you can tighten/loosen to adjust ride height? Thank you
#10748 1 year ago
Quoted from KingBW:
Ditto.
#10749 1 year ago
These posts might help:
https://pinside.com/pinball/forum/topic/jjp-pirates-of-the-caribbean-official-owners-and-fan-club/page/84#post-4849012
https://pinside.com/pinball/forum/topic/jjp-pirates-of-the-caribbean-official-owners-and-fan-club/page/49#post-4757198
#10750 1 year ago
Very easy, unlock the big white nylon retainer nut under the disc, the. You can twist the inner assy up or down and then re-tighten the big retainer nut
Pinball Mod Co.
$ 5.00
Pin Monk
Pinball Mod Co.
22,000
Canyon Lake, CA
$ 23.00
The MOD Couple
$ 499.95
Pin Stadium Pinball Mods
Minneapolis, MN
