Quoted from Zora:
I plan to remove the chest for a special mod. Has anybody removed the chest already? Was it difficult? How is it fixed on the playfield and which cables do I have to separate?
Any information is highly welcome.
Pretty simple.
0. Just unplug everything under the playfield that comes through the hole. It's all easily found right there. Make sure your opto cables are color coded already (most on mine did not have the color marks on the connectors)
1. There is a wood screw into the playfield that is hard to see. If you look down behind the coil that controls the ball release between the chest and the coil you'll see the screw. You need a long phillips bit, magnetic.
2. The right mounting plate is under the chapter select plastic. Just remove the center nut holding the chest bracket to the plate.
Pretty straightforward as long as you can get to that #1 screw.
