(Topic ID: 200141)
JJP Pirates of the Caribbean Official Owners and Fan Club!
By goren1818
2 years ago
  • 15,429 posts
  • 525 Pinsiders participating
  • Latest reply 2 days ago by Rdoyle1978
  • Topic is favorited by 252 Pinsiders
There have been 2,657 images uploaded to this topic. (View topic image gallery).
20 key posts have been marked in this topic, showing the first 10 items. (Show topic index)
There are 15429 posts in this topic. You are on page 210 of 309.
#10451 1 year ago
Quoted from Psw757:
So the t-nut issue is only in the back left corner?
Yes. My approach was to simply keep the ball off of the t-nut. Pulling it out and grinding it may bring a new set of problems.
#10452 1 year ago
Quoted from Psw757:
Hey no offense but nobody is forcing you to read the other thread.
Let it go - I never said that anyways.
#10453 1 year ago
I’m pissed!
#10454 1 year ago
Quoted from Skyemont:
I’m pissed!
You don't have to advertise your day drinking.
#10455 1 year ago
Quoted from mountaingamer:
Sorry for the sarcasm.
#10456 1 year ago
Quoted from vireland:
It’s always 5’o clock somewhere
#10457 1 year ago
Quoted from Psw757:
It’s all good man! I’m just in the honeymoon phase still
#10458 1 year ago
Quoted from statsdoc:
This is what I used. It is a firm rubber piece that is kind of a protective footer. It has self-adhesive on the back. Seems to be doing the trick for now as it at least covers up in the initial contact with the t-nut.
[quoted image][quoted image]
great idea!!!! No bounce outs?
#10459 1 year ago
Who wants a Congo in trade for a Pirates? Never said even so dont jump on my ass.
#10460 1 year ago
Decals I have been working on..
BP standup targets:
Ignore left one, early sample
BP Load Cannon standups:
BP Spinners
The Depths spinner
Waiting on some production samples and will have them available for order soon. Going to coincide with the standup target window & vuk armor piece being developed. Also working on the starmap plastic replacement still.
https://pinside.com/pinball/forum/topic/jjpotc-black-pearl-center-spinner-stand-up-target-cover-
#10461 1 year ago
Check your plastics for backing paper when doing any sort of maintenance.
#10462 1 year ago
Quoted from harryhoudini:
Check your plastics for backing paper when doing any sort of maintenance.[quoted image]
Wow u mean to say they “forgot” to remove that from the factory?
#10463 1 year ago
Quoted from Soulrider911:
Yup. 3 plastics so far.
Not to mention all of the loose screws I've come across. Nothing about the spinners on the BP was screwed down all the way. The chest wasn't screwed down all the way (caused the bracket to break). It's a bit of a game now to me, what else can I see that isn't quite right.
#10464 1 year ago
"Blued out" ... too much OCD so I'm matching nut colors to plastics.
It really fucks with my brain that I can't find colored washers. I have some more narrow nylon ones coming so they won't be seen.
#10465 1 year ago
So I emailed JJP today about buying some of the toys for the SE...I was told only LE/CE customers are allowed to buy any upgraded parts from those machines. Quite sad about it..I only wanted the Devil’s Triangle and the Spinning Tom LoL. The good news is they did sell me the shaker motor!
#10466 1 year ago
My game is missing the target boat hole by striking to the right of the hole. A little shim to the cannon launch ramp with metallic tape worked better—but is the better solution to take the boat apart and move the cannon ramp? Otherwise, flawless game with no other adjustments. I did increase the flipper and sling power, moved the post rubber to bounce into escape the locker better, and added a couple of tilt warnings.
#10467 1 year ago
Quoted from dts:
My game is missing the target boat hole by striking to the right of the hole. A little shim to the cannon launch ramp with metallic tape worked better—but is the better solution to take the boat apart and move the cannon ramp? Otherwise, flawless game with no other adjustments. I did increase the flipper and sling power, moved the post rubber to bounce into escape the locker better, and added a couple of tilt warnings.[quoted image]
Check the troubleshooting thread. I followed a post to put shorter hex posts on the dauntless, bringing it closer to the back of the playfield. I just used the thinner Marco ones.
#10468 1 year ago
Quoted from Trooper11040:
Why dont you just say you have the le and the toy broke when you polished it?
#10469 1 year ago
Quoted from dts:
Sorry it’s in this thread.
https://pinside.com/pinball/forum/topic/jjp-pirates-of-the-caribbean-official-owners-and-fan-club/page/127#post-4908546
I think a few of us just used the thinner ones with the m-f.
Check out 02-4825-20 from Marco.
#10470 1 year ago
Quoted from gumnut01:
Totally forgot about the troubleshooting thread, thanks!
#10471 1 year ago
Quoted from Dr-pin:
They know by your serial #
#10472 1 year ago
Quoted from dts:
I had the same issue, make sure the shooter lane rails are parallel. Check my post in the troubleshooting index for more details - they’ve got to be even and hugging the channel. If really bad the ball wont plunge without smacking the post. Another symptom is auto plunge failures.
#10473 1 year ago
Why has no pinside staff rated this game? It looks like they rated the prototype only? Just can’t understand. The game has now been in the top 10 for months, yet nothing.
Just Saying!
#10474 1 year ago
Quoted from dts:
dts For the issue with the ball bouncing off the Escape the Locker Room post, take a close look at your shooter lane wire ramp. It's surprising how bad of an issue this small deformity caused me. Here's the post that contains a video of the issue symptoms and images of my wire ramp before and after.
https://pinside.com/pinball/forum/topic/jjpirates-of-the-caribbean-troubleshooting-tips-issues/page/21#post-4991721
#10475 1 year ago
Anyone have a good idea of how to block the ball from getting off the pf after it drops from the ship? Doesn't happen often but the ball can actually bounce up and over and rest on the back right plastic.
#10476 1 year ago
Quoted from delt31:
Not sure I understand but I think I do. Do you mean after bailing off of the right of the bp the ball sometimes gets stuck between the man overboard and the shooter wireform. I added another rubber bumper to the man overboard area to make it more difficult for it to happen. Have not got one ball stuck there since. Oh and if it is man overboard we are talking about that is actually a metal plate with sticker on it not plastic.
#10477 1 year ago
Ok this machine is heavy. Whats the easiest way for me to lift it to adjust the feet on the legs. I think the incline needs adjustments. Any tips ?
#10479 1 year ago
Quoted from MarZ_78:
Thank you! My autolaunch is actually perfect. I just wanted to escape the locker into the shooter lane more easily, so I moved the post rubber to the other post, which was bare for some reason. I'm guessing on purpose for owners to adjust the ease of saving the ball.
#10480 1 year ago
Quoted from dts:
My mistake here, I didn't read your post and focused on the screenshot. Yes, the rubber is optional, as shipped it's bare on the left rubber on the right. Many people move it to the left as you did, and some install it on both (there is a spare in the goodie bag for this.)
I've been running both and I'm happy with the challenge/reward level.
#10481 1 year ago
Quoted from dts:
Eric had all of the original prototypes without any rubbers on the out lane posts. At the time he had said it would ship with a rubber on the right side mostly for the purpose of location pins, but he preferred it without any. That's the way we setup ours - the way the game designer liked it. Right side - too hard to save. Left side - maybe a little too easy to save. None - just right.
#10482 1 year ago
Is anyone else seeing Arr Frenzy as a somewhat unbalanced part of scoring? My kids are racking up scores where the Arr Frenzy mode is contributing more than 60% of their points for the game. Now the whole family is just aiming for it and ignoring the rest of the game. It is making the game less interesting in some ways.
#10483 1 year ago
Well, it's kind of hard to launch it...and when it's up, it's hard to hit the spinners to maximize it. I think it's balanced well!
One of the cool things about the game is the multiple ways to attack. Maybe you want to maximize multiballs and jackpots, maybe you want to go for chapters and wizards, maybe you want to try for Argh Frenzy and spin your way to the high score list.
One thing I have found over time is that focusing on one approach only gets you so far - eventually people start looking at the other ways to attack. It'll work itself out!
#10484 1 year ago
I've been playing with Pintel the past few days to try stacking Arrg Frenzy with multiballs. Had some good success with it. But my highest score has come with Angelica, at around 1.3M.
#10485 1 year ago
We changed the Arrrr Frenzy setting so it doesn't become available until the fifth round of Pirate lanes (by default it's available in the third).
#10486 1 year ago
Quoted from KingBW:
That's great to know, I'll remove the rubber--after some more practice!
#10487 1 year ago
Quoted from Dr-pin:
Yeah, they'd never fall for that.
JJP tries hard to help. Please don't abuse it.
#10488 1 year ago
Here is the bashing the VUK does on the ship if it is turned up too high. The right opto is broken (cracked in half, wires broken off) and the lower screw is bashed all to crap. It was perilous removing it, thought I might have to grind it. Reminds me of the screws on the WOZ Castle doors, had to dremel two of those in my life so far. You can see it is also bashing the lower metal support. If that was just a bit taller it probably would have prevented the broken opto.
#10489 1 year ago
Quoted from zaphX:
I did not change the settings, and the scores are going up by thousands+ with each hit of the bumpers in the star map area and the pop bumpers. Watched two games today where Argh Frenzy contributed 500,000 points or more by itself, not including other points in the round.
#10490 1 year ago
Wow! I think my best Argh was ~260k. Was it combined with a playfield multiplier?
#10491 1 year ago
Quoted from zaphX:
Likely, and run with multi-balls, but ... the score Argh Frenzy contributed was outsized as you can tell. Total scores were around 800,000 and 1,000,000. You can see what I meant when I said out of balance.
#10492 1 year ago
This was also accomplished by two kids who are not skilled players ... not that I am either for that matter.
They just managed to pick up the mode and off the score ran almost by itself as they started one multiball. The whole family is convinced that Carina and Argh Frenzy are the way to beat the machine.
#10493 1 year ago
Until v1.0 ... Barbossa is king
#10494 1 year ago
Quoted from Troz:
Dude is that 5 ball? I can't even crack a million.
#10495 1 year ago
Quoted from bigdaddy07:
Amen. But, if we have to go to the bathroom we know the next break isn't far away
#10496 1 year ago
3 ball, no extras. Game around 15-20 minutes.
#10497 1 year ago
Quoted from Troz:
Until v1.0 ... Barbossa is king [quoted image]
I thought..."how in the world?!?!?" then saw your username. Daaaaaaamn. And I thought your scores in your stream, like half this, were good.
#10498 1 year ago
Quoted from wesman:
Yeah - Karl (Troz) is a fairly good player.
#10499 1 year ago
Quoted from wesman:
I've been meaning to stream this strategy before v1.0 comes. Maybe I'll get the equipment setup this week for a stream.
#10500 1 year ago
Quoted from Oneangrymo:
Well I had this same issue. I was too impatient to wait for help. I had to adjust the rear legs. So........I got on all fours.......went under the machine then lifted with my shoulders / back then adjusted one leg at a time. I'm pretty sure there are better methods.
$ 399.95
Pin Stadium Pinball LEDs
$ 349.95
Pinball Mod Co.
Pin Monk
$ 28.75
The MOD Couple
$ 87.95
$ 239.99
Tilttopper
