(Topic ID: 200141)
JJP Pirates of the Caribbean Official Owners and Fan Club!
By goren1818
1 year ago
  • 11,913 posts
  • 449 Pinsiders participating
  • Latest reply 16 minutes ago by kidchrisso
  • Topic is favorited by 210 Pinsiders
There have been 2,130 images uploaded to this topic. (View topic image gallery).
20 key posts have been marked in this topic (Show topic index)
There are 11913 posts in this topic. You are on page 145 of 239.
#7201 4 months ago
Quoted from zaphX:
A couple of maintenance items for tonight.
1. I was getting the shooter catching the autoplunger, and no attempt to move the shooter would fix it. I examined the playfield hooks and they did not appear to be bent. I ended up putting some thick weatherstripping underneath each hook, and that resolved the issue by raising the playfield enough that the shooter clears. I did have to re-level the game after this, of course.
2. To combat the chipping on the slingshot posts, I replaced all 3 posts on both slings with the star posts, and the silicone washers underneath them to keep the stars from creating new chips. This did hide the damaged areas and I am optimistic that the squishy washer will prevent more pressure damage. However, after doing this, the sling sensitivity is much lower. It only kicks when there is a very solid hit. I attribute this to the higher position of the sling rubber due to the washer. I haven’t tried to fix it yet, I will either adjust the leafs to restore the sensitivity or remove the washers.
3. I put some wire loom on the wires under the Pearl to avoid chafing and hopefully prevent balls from catching here.[quoted image][quoted image][quoted image][quoted image]
On Item #2 I suspect the issue is the Star posts you added are a larger diameter then the straight posts JJP originally installed which moved the rubber out further which is seen in your photo from the blades.
#7202 4 months ago
Quoted from Yelobird:
Yeah you could be right. Wider not taller. Either way the fix is the same; adjust the leafs.
As a side note, post passing seems easier with the star posts.
#7203 4 months ago
Quoted from PanzerFreak:
Currently have the ship off to install the map Cliffy protectors, going well. With the mini playfield off I was wondering if it would be worth it to mylar the chapter select magnet area? Think its needed?
Yes. I installed fake mylar.
#7204 4 months ago
Weeeeeeee..... Not fun. Or solving anything.
I think I quit for now.
Pirates, you are a nice looking paperweight, but I'm beginning to not like you. A lot.
20190410_011305 (resized).jpg20190410_014758 (resized).jpg20190410_014808 (resized).jpg20190410_014958 (resized).jpg
#7205 4 months ago
Quoted from wheels:
What is fake mylar? I have some vinyl static cling stuff I may try but don't think it will hold up... Free to try and pretty low risk though.
#7206 4 months ago
Quoted from wesman:
I will try to take some pics of my game tomorrow. Also no shame in asking jjp to have a look at your pics.
#7207 4 months ago
Quoted from BC_Gambit:
I contacted Frank late today. I will definitely send some pics. Mostly of me weeping, but also of the game.
Thank you for the concern! I will vicariously live via your functional games.
#7208 4 months ago
Quoted from wesman:
#7209 4 months ago
Quoted from zaphX:
AWESOME job on everything, but especially the wire loom underneath the BP. Was that difficult?
#7210 4 months ago
Quoted from NightTrain:
So I had my switch #48 error last night when I opened the machine. I tried to move the ship and it was stuck really good. I hit and sink the ship through the hole all the time, so I was confused. Well the ship wasn't moving. After messing around, I finally found that the bracket behind the backboard was binding against the wire loom coming from the head. It was a quick fix with a dremel. I just ground down a little of the bracket and everything is moving smoothly.
Just wanted to post this in case others come across this issue and they are scratching their head. It had me puzzled for a moment because I couldn't see anything binding. When I'd pull the play field out to inspect, it wouldn't bind anymore. That's when the light bulb in my head went off.
THIS should be a key post!
IDK what a dremel is, BUT ... I'm pretty sure this is my issue. Let me see if I can do anything hasty tonight to manipulate this wire loom on the back left.
#7211 4 months ago
Quoted from joseph5185:
And............fixed! =)
It had enough give to bend to the right (vs the normal bend to the left)
So I felt pretty confident when I moved the loom because I knew it wouldn't be interfering with the wire loom at that point.
And the switch works perfectly.
I notice that the dauntless sometimes hands up on the malestrom and doesn't come back...
The game is getting a little better every day.. =)
#7212 4 months ago
I believe this is it. Years ago, I bought some Avery vinyl sheets. They've worked well for me, but I don't ever apply them over playfield inserts as I recall reading about at least 1 person having issues with the decals/graphics on top of inserts lifting with the vinyl.
#7213 4 months ago
Man..I'm TRYING really hard to enjoy this game...
Looks like the right flipper on the BP is only going up about half as much as the left flipper.
Maybe just a loose flipper?
I'll have to investigate tomorrow.
Night all...
#7214 4 months ago
I removed everything from the receiver bar, pushed the main bar a bit towards the left and finally got it seated with some consistency. Though to do so I needed to leave the three smaller screws out....
Tomorrow I'll put the bar back together. Just too tired now.
Small victories.
#7215 4 months ago
Night all...
Might not be a problem. Mine don’t travel equally either and have read others may be similar. As long as you have good control (can you cradle with left flipper a bit) and can make the shots it should be ok. I don’t think the right flipper needs to travel as much as the left.
LTG.... thought?
#7216 4 months ago
Quoted from DrDQ:
LTG.... thought?
Mine is the same. Maybe it’s intentional to make loading the cannon easier.
#7217 4 months ago
Is the BP flipper issue really intentional?
I feel like it was fine from the beginning.
Interesting.
#7218 4 months ago
Unknown. I noticed my BP flippers were mismatched and was going to adjust them but decided to keep it because the higher left flipper backhands the cannon shot better.
Your mileage may vary.
#7219 4 months ago
Interesting.
It's normal.
#7220 4 months ago
Quoted from wesman:
I'm not sure I understand what I'm looking for in these pictures. I don't see anything abnormal?
#7221 4 months ago
Quoted from f3honda4me:
I agree... when taking pictures: maybe use a pencil as pointer or small blue tape tabs, as indicators, where the issues are.
#7222 4 months ago
Turned my game back on after installing the map Cliffys last night. Thankfully everything plays great! The map hole shot is slightly more difficult to hit now but I think this is a good thing as it results in the map awards occurring a bit less often.
Overall just super impressed with this game. What a beautiful, deep, and rich pinball experience. I was playing this morning and noticed after playing a multiball or mode that the ship movment had sped up. Seeing things like that and then being able to slow the ship down with the character Cotton is pretty cool.
#7223 4 months ago
Quoted from heni1977:
Anyone else turn there shaker motor all the way up?
I turned the shaker motor all the way up and played a few games with it on 'Extreme Mode'. It felt like holding a jackhammer in your hands. Not sure on how this will affect the connections over time so I turned it back down to High and play on that setting.
#7224 4 months ago
Quoted from Tuna_Delight:
Sure would be nice if there was a separate JJP POTC tech issues thread. This club thread seems to be dominated by repeated issues - many of them from owners new to the hobby.
Doesn't make for lively gameplay/strategy discussions and leaves others with the impression that JJP POTC is nothing but problems.
Just sayin'.
I couldn’t agree more. I always get excited when I see there a 50 new posts. I’m thinking maybe the new code drop. Then I read through and find the same questions and issues repeated. I wish there was a way to not allow a post without reading the whole thread first.
#7225 4 months ago
Quoted from zaphX:
Fair enough.
Yes. The left flipper is “normal” and the right is like “half.” Simple comparison.
Alright. One less thing to worry about!
#7226 4 months ago
I am absolutely game for moving tech support to a POTC problems and issues thread. The hope with the potcfixes doc was to centralize the info, help people find answers faster and reduce the noise in here.
#7227 4 months ago
Quoted from Kerry_Richard:
Oh I agree about using an indicator. It was more taking the apron off and trying to see how the hanger tabs looked, the one's that have been giving me issues since day one.
That was also on about two hours sleep from the prior night working on this machine...
I understand things can get frustrating on a forum thread based for a game, but it's also as or more frustrating for a new owner when issues pop up, and there's no tech hovering around to help them first-hand. If this were a $10 product, I'd feel far more like that myself, but it's greatly distressing for new owners, and lingers on our minds until these issues are corrected with the help of thread and game vets.
For a month or more prior to ownership I bookmarked and read this thread's history thoroughly, and yet still situations unfamiliar pop up. For me I often still search this or other threads first, or PM some folks directly as well.
Code update versus all day panic.
#7228 4 months ago
FWIW...
I plugged in headphones and had absolutely 0 audio clipping.
So I'm not sure if it's a wire or the speaker itself.
#7229 4 months ago
This is normal?
I figured a quick snap wouldn't hurt.
#7230 4 months ago
This is normal?
Yes - mine is exactly the same. It's that way intentionally so that you can make the canon shot with either flipper.
#7231 4 months ago
Nice! Okay! =)
Here am I to know? =P
#7232 4 months ago
This is normal?
It’s not normal. Read posts after mine. The fix is simple, loosen the pawl nut, re-position the flipper and retighten. And no, you don’t need to remove the upper playfield.
https://pinside.com/pinball/forum/topic/jjp-pirates-of-the-caribbean-official-owners-and-fan-club/page/27#post-4714691
#7233 4 months ago
Quoted from evh347:
Hmm interesting. Would be nice to know for sure. I have no problems hitting all targets on the ship with the right flipper.
#7234 4 months ago
I’ve suggested this fix to Derek some time ago and Eric himself upvoted the post. If I was wrong, someone would have said so.
https://pinside.com/pinball/forum/topic/jjp-pirates-of-the-caribbean-official-owners-and-fan-club/page/55#post-4775553
#7235 4 months ago
Night all...
Yes, lose flipper. Both of mine were lose out of box....
#7236 4 months ago
Quoted from evh347:
https://pinside.com/pinball/forum/topic/jjp-pirates-of-the-caribbean-official-owners-and-fan-club/page/27#post-4714691[quoted image]
Quoted from DerGoetz:
Awesome guys!
I THOUGHT it was the same before ...
#7237 4 months ago
The audio clipping seems minimal...or better.
And what I mean by that is just a hint of static here and there.
Is no one really experiencing this whatsoever?
#7238 4 months ago
Quoted from evh347:
Thanks! I’ll fix mine when I pull the ship to do cliffy install.
#7239 4 months ago
I'll fix mine when I get nut drivers =P ... tomorrow.
#7240 4 months ago
Yes, a few of us as posted earlier in this thread. If you unplug the headphone cable inside the backbox and it goes away, try to route it away from the green and white power wires in the base cabinet.
#7241 4 months ago
I also get the clipping sound from time to time.
#7242 4 months ago
Quoted from KingBW:
Does that actually fix it?
It's 100% worthwhile if it does...
Edit: Pretty sure that is the little black wire near the bottom of the cabinet on the left. Man I tried to disconnect that molex connector or whatever and failed. Was NOT easy...
#7243 4 months ago
#7244 4 months ago
Quoted from evh347:
Your original fix is now a key post FYI. Thanks for the info and details!
#7245 4 months ago
Quoted from zaphX:
I added 3/4 clear washers under the standard posts which raised up the sling rubber just slightly. That combined with Titans on the flippers makes post passing pretty much impossible
I also was able to bump the post on the right and get the ball to the end of the flipper for a back-flip into Tortuga - can't seem to do that any longer either. But a harder game is just a bigger challenge
#7246 4 months ago
Oh Wow...
So I used Will Turner (Random select)
I hit the 3rd skill shot to get a spin of the map and to my surprise I was awarded 25,000 on ball 1.
That's a neat trick!
#7247 4 months ago
This is absolutely not true. Per Frank@JJP and the various streams from Eric they should be the same and parallel to the gate/rails behind flipper. The cannon shot is still achievable from both flippers.
Play it however you like though.
#7248 4 months ago
Quoted from Psw757:
Yep already corrected. https://pinside.com/pinball/forum/topic/jjp-pirates-of-the-caribbean-official-owners-and-fan-club/page/145#post-4932643
#7249 4 months ago
Twitch video showing how to remove the pearl is a key post now. Any other posts that should be key post anyone can think of recently? Stuff not covered in the zaphx fix link that is.
#7250 4 months ago
Oh Wow...
I suggest the Buffalo Pinball tutorial. @22:15 they explain why Will has this benefit. They actually go through all the characters pretty good. The big takeaway is that the main benefit listed at the character select screen is NOT always the only benefit you get from picking a character. Of course there are negatives too, but unfortunately, right now in .98 code you have to pick a character and then hold the right flipper for about 3 seconds until you get into the status info.
Watch the video:
$ 239.99
Tilttopper
$ 399.95
14,775 (Firm)
$ 28.00
The MOD Couple
Playfield - Plastics
Pinball Mod Co.
15,750
Sale Pending!
Highland Park, IL
$ 42.00
The MOD Couple
Pinball Photos
