Hi Guys, Joined the club today with LE 197 thanks to some peer pressure from
KevInBuffalo
This is my first home pinball, have been an arcade guy in the past, so have some experience with wiring, pcbs, etc.
Having a couple of issues, and have a call in to the distributor, but figured Pinside might have some ideas?
1.) Have a Fork Malfunction/Device Broken error and balls wont lock in the chest
- Checked the suggested 2 screws to make sure they were tight
- Checked wiring under the play field for the fork mechanism and everything seems ok
- Individual coil tests will raise and lower the fork successfully
- The specific fork test itself will not work
- No balls will physically enter or lock in the chest, but screen animations show ball locks when hit through the middle chest shot
Anything else to check?
2.) Have a stuck closed switch #50 on the right high slingshot. It wont activate when depressed manually.
-Checked under playfield wiring and seems ok from a glance (no broken wires)
Read through every post in this thread in preparation. So far have done these checks/minor fixes:
- Cut some zip ties to give slack to the Black Pearl
- Subway post was there from the factory - Manufacture date was 1/21/2019
- Protected cabling behind dauntless
- Leveled to 6.5
