(Topic ID: 200141)
JJP Pirates of the Caribbean Official Owners and Fan Club!
By goren1818
1 year ago
  • 11,911 posts
  • 449 Pinsiders participating
  • Latest reply 1 hour ago by vireland
  • Topic is favorited by 210 Pinsiders
There have been 2,130 images uploaded to this topic. (View topic image gallery).
20 key posts have been marked in this topic (Show topic index)
There are 11911 posts in this topic. You are on page 136 of 239.
#6751 4 months ago
OMG Guys ...
First attempt at adjusting the shooter plate/assesmbly/whatever ...
Snapped it like 3 times and NO vibration whatsoever ..
#6752 4 months ago
And got the topper going thanks to zaphx.
I opted to do it the "hard" way and actually connect those wires behind the speaker..
It was fun...but it's done!
#6753 4 months ago
zaphx
Well unfortunately...
My black pearl is no longer running.
So I managed to fix a couple things and break something else.
All I did essentially was lift the playfield straight up and rest against the back box to get to the shooter assembly and when reseating .. I no longer have a rocking black pearl ..
#6754 4 months ago
Quoted from joseph5185:
zaphx
Wow! Sorry to hear that! Hope you get it going again. Such a shame JJP’s customers have to be fixing all these issues right out of the box!
#6755 4 months ago
Quoted from KornFreak28:
So it's kinda odd right.
I can see the sort of rectangular slot where the ship sinks down on the left side. When I try to push down on the left side I basically can't get the ship to budge. It's almost as if something is blocking the movement..
#6756 4 months ago
Quoted from zaphX:
Based on all the machines I’ve seen, I’d say the left/right is intentional.
I concur, the ship rocks more to the left than the right. Otherwise all the balls would go overboard Arrrrrr.
#6757 4 months ago
Sorry to everyone who recently got NIB games with so many unacceptable issues out of the box. If I were you, I would raise a stink with JJP (and also let your distributor know). Reversed flippers? Light boards not plugged in or connected properly? No excuse for that.
Just as a reference, I am feeling pretty lucky and have not had any major issues with my machine. I've owned it for 3 weeks now with a manufactured date of 02/07/2019. I had a couple minor adjustments to make (like bending up the spotlight by the extra ball shot because the ball was getting stuck there), but that is the extent of it (*knock on wood*).
Hope those of you having issues get a proper and gratifying response from JJP. QC is clearly an issue right now, but it seems like from most of the threads I've read JJP takes care of their customers. Not excusing them, but hopefully they make it right.
Game is amazing! Hope the NIB issues don't spoil it for anyone in the long run!
#6758 4 months ago
Quoted from Pinzzz:
This Marco item will resolve that issue.. your balls are magnetized, and get hung up in the metal trough. I had the same issue, and this resolved it.
https://www.marcospecialties.com/pinball-parts/03-16809
Appreciate the help, thanks....
Why do we think so many of us out experiencing this magnetization issue?
I’ve had other games and I don’t think I’ve ever heard of this problem to such an extent.
#6759 4 months ago
Quoted from GnarLee:
Fixing to go balls deep in this manual and figure some of this shit out
Not only a candidate for post of the month but this sentence alone could summarize 75% of this thread unfortunately.
#6760 4 months ago
Quoted from ngg:
I believe the culprit is the Star Map/Character select magnet. that magnet fires too long and makes the ball bounce around for an extended period of time. that is what I think is causing magnetization more easily... the Black Pearl loading magnet only fires for a second compared to the Star Map magnet.
I am trying these balls from Marco:
https://www.marcospecialties.com/pinball-parts/PB116-5
They are supposedly less likely to magnetize.
I’ve only have them in for a few days...so far, so good...I will report back in a couple of weeks. 4 dollars a ball is pricey...they come in a 5 pack for 19.99
#6761 4 months ago
I never even opened the JJP balls and instead went with these from Marco. I use them in all my pins without any magnetization issues.
Edit: just realized these are the same as Pinzzz recommended.
#6762 4 months ago
Back at it..
So "basically" the pin is stock at the top:
zaphx
I saw in your guide where you have to loosen some screws and this pin should never touch the top or bottom so that the ship can move freely.
All I had to do was take the playfield out once and put it back in to mess this up.
Seems really weird that I would have tightened the screws by doing this unless I didn't quite get the pf in right even though it locked in place and everything.
I can take a picture from underneath as well if it helps.
#6763 4 months ago
Back at it..
zaphx
Is the motor that rocks the Pearl fully secured? Tightened down properly?
#6764 4 months ago
Quoted from wheels:
Never mind. In testing that motor, make sure the post to which the Pearl attaches doesn't hit the top or bottom of the slot. If it does, adjust appropriately.
#6765 4 months ago
Quoted from wheels:
Does the black pearl "sail" when the game is idle ... before a game?
I thought it did rock when it was idle .. mine is not doing this.
#6766 4 months ago
I don't own one, but during the DeadFlip stream it didn't start listing back and forth until a game was started.
#6767 4 months ago
I'm using stock balls. No issues.
#6768 4 months ago
So okay..
When i boot it up, the black pearl is lit. It even tilts side to side.
I *THINK* that's a pretty good sign.
Isn't there some sort of ship calibration test that I can run or something?
If only not rocking during gameplay, then I'm concerned I'm doing something wrong when I insert or something.
Also, I found this in the back of the game on the cabinet floor:
#6769 4 months ago
Actually, now that I have had sleep, let’s do this..
Let’s turn off.
Put the play field back.
See if I get the same action on the black pearl when it starts up.
If I do, then theoretically I should be “good.”
I’ll report back.
#6770 4 months ago
So okay..
Also, I found this in the back of the game on the cabinet floor:[quoted image]
It’s not uncommon to find a bonus screw now and then. Throw it in your coin box. You may find a use for it one day, you may not.
#6771 4 months ago
Quoted from zaphX:
Haha .. Fair enough! =)
#6772 4 months ago
A note regarding issues with balls becoming magnetized. The plastic trough shim will help prevent magnetism issues in the ball trough. However, the interior of the chest ball lock where the balls rest on is metal which can be prone to magnetism. I wonder if putting down some mylar in the chest would help?
I'm using Pinball Life Super Shiny balls and they are becoming magnetized in the chest lock. I need to check the level of the game as well as I'm sure if it's lower on the right back side that it will impact how easily balls drop out of the chest.
Other then that my 2/4 built game is playing perfectly (knock on wood). Once I got the game leveled I was amazed at well it plays. The spinning disk also grabs the ball a good amount and throws it around much better then the triple disk mech did on a prototype game I played.
#6774 4 months ago
Quoted from PanzerFreak:
I found a new topper
amazon.com link »
#6775 4 months ago
amazon.com link »
Has anyone tried a demagnetizer with pinballs?
#6776 4 months ago
Looks like it is moving good. You can go into system test and find the ship test and calibrate it. I am pulling up the manual now on it.
#6777 4 months ago
Regarding playfield 'tightness' and 'fit', ensure the game is leveled and also check to make sure the legs aren't bent (from shipping?).
#6778 4 months ago
Quoted from Reznnate:
I do need to make a slight adjustment to the leveling. It seemed like sort of rocking side to side as I was pushing in/down on the playfield got it to go in easily enough.
I see these two pieces of mylar for the lock bar. What exactly does this do again?
Also, I have two longer rounded ish pieces of mylar. Not sure about that either.
I just noticed this game doesn't have art blades.
Kinda assumed the CE would.
#6779 4 months ago
#6780 4 months ago
Quoted from heni1977:
Let's give it a shot and see what happens...
#6781 4 months ago
The mylar for the lock bar keeps your rails from scratching.
I believe the rounded mylar is for the chapter start area.
#6782 4 months ago
I just went though the ship leveling process. Do the full range test and make sure its not hitting the slot anywhere. Stop Motion Move Home and see where its at. If its leaning left and not pretty close to level it still needs adjusting. once you get home close to level do the move left and move right and make sure they look good as well (leaning a bit left on move left and a smidge right on move right) Then check full motion again. After that I did the force recalibration and everythign has been good since
#6783 4 months ago
Got it!
So I did the "full run" for the ship diagnositcs and it just rocked back and forth.
It said the slowest motor speed = 5.
I wasn't sure it was going to stop running so I decided to end it.
It seems happy...
#6784 4 months ago
(ive become quite familiar with them rebuilding a F-14
I am working on my restore of F-14 too. Just waiting on my PF to come back from clear coating.
#6785 4 months ago
Got it!
It seems happy...
Got the same results when I ran the ship calibration, slowest motor speed = 5. The test does eventually timeout and stop.
#6786 4 months ago
Quoted from arzoo:
Good to know.
I'm BLOWN away with this owner's manual that comes with CE btw.
My gosh!
Trying to apply these mylars now and then maybe actually play a game or 2. =)
#6787 4 months ago
Quoted from Demwyn:
Sure... Same mylars and same way as attached on my DI LE lockbar
[quoted image][quoted image]
Is this not the outside of the lock bar?
I would think the mylar would be attached on the inside.
#6788 4 months ago
This is a post on Facebook from Buffalo Pinball.
Tonight on "Bro, do you even pinball?", we're doing a Bro Battle Royale on Jersey Jack's Pirates of the Caribbean! Extensive tutorial by Jay Fairbrother. 8pm Eastern. www.twitch.tv/buffalopinball
#6789 4 months ago
Quoted from FryDaddy:
What time/time zone?
#6790 4 months ago
Quick question. I see the ball hits the playfield rather hard when it comes out of the shooter rail. Is there a good amount of mylar put down at the factory to protector that area? Also, any concerns of damage on the playfield or plastic when the ball falls off the Pearl?
#6791 4 months ago
Shooter drop area is mylar. Man overboard area is a sticker on top of metal over the wood rail, so ball falls onto a metal area.
#6792 4 months ago
Quoted from AUKraut:
Awesome, thanks! Still trying to get the cannon shot down on the Pearl, what a tough shot!
#6793 4 months ago
If it's not too much to ask..
Can I get a quick recap of where you have used mylar to include the two squares as well as the two "odd-shaped" pieces?
Again, I LOVE it and first time owner here.
Just trying to be "kinda" careful
Thanks!!
#6794 4 months ago
When putting key posts at the beginning of the thread, does this need to be done by the op?
We could definitely use some more key posts since this thread is becoming longer by the minute!!
#6795 4 months ago
Quoted from zaphX:
It is in the post 8pm Eastern
#6796 4 months ago
I'd say not to start an "owners club" thread if you're not going to help manage the key posts. Maybe if a "owner" is one of the moderators, they could help with that. ???
#6797 4 months ago
Derp. Clearly I haven’t had my coffee yet.
#6798 4 months ago
The key post thing is something I have been shouting about for some time. I wish robin would make a “suggest key post” system.
There are some key posts in this thread, most of them is a head scratcher how they became a key post.
#6799 4 months ago
Pretty sure the curved Mylar is for up on the pearl where it comes out of vuk, it fits there perfectly. I’m assuming this is the one your talking about. I cut my own for the chapter start since I didn’t see a piece big enough supplied.
#6800 4 months ago
Mine came with two half-circle mylar pieces which I placed in front of the slings.
$ 42.00
The MOD Couple
14,775 (Firm)
El Segundo, CA
Pinball Photos
$ 399.95
$ 87.95
