(Topic ID: 200141)
JJP Pirates of the Caribbean Official Owners and Fan Club!
By goren1818
6 years ago
  • 18,885 posts
  • 633 Pinsiders participating
  • Latest reply 2 days ago by Buzzie
  • Topic is favorited by 284 Pinsiders
20 key posts have been marked in this topic, showing the first 10 items. (Show topic index)
There are 18,885 posts in this topic. You are on page 132 of 378.
#6551 5 years ago
Quoted from BC_Gambit:
I just ordered one of these today; any summary of "must do" fixes on day one? (mylar, cliffy's, anything?).
I ordered the silicone washers from the Fix Guide, but not sure what else to get within reason. I expect some wear and tear, but I remember reading about concerns re: the map area where the balls bounce, scoop chipping etc; it sounded like some cliffy's came with recent versions of the game?
Any help is appreciated!
You don't get cliffies. You get mantis ripoff protectors that are not helpful at all for protecting the chippable surface of the playfield. I'd email cliff ASAP and get a set of his ordered, since it will probably be a month or 6 weeks before your order comes up to be shipped. There's some pictures of the cliffy map hole install, which is the most challenging one on jjPotC in the image gallery on this thread.
Edit: Here's the post for the map hole install - https://pinside.com/pinball/forum/topic/jjp-pirates-of-the-caribbean-official-owners-and-fan-club/page/123#post-4902185
#6552 5 years ago
Quoted from PinMonk:
Thank you for the heads up! I have emailed re the protectors. Open to other thoughts though. Not 100 percent sure these will be needed on a home game bit from what I read some have had worse luck than others with chipping.
#6553 5 years ago
After dialed in chipped in less than 50 plays, and with some jjPotC on location chipping already, it's not really the amount of play, it's the luck of the draw with the Mirco playfields JJP uses. I wouldn't run a JJP machine without cliffies as a result.
The game's pretty complete as-is, so I don't really have a recommendation for other must have things for it. I do like the Kraken mod because it looks cool, and maybe a 3D barrel top for the lower pop bumper because it will then match the other one next to it better, but that's about it. I'm working on a mod for the star map that will make the light look more star-like, but it's not quite done yet.
#6554 5 years ago
The game's pretty complete as-is, so I don't really have a recommendation for other must have things for it. I do like the Kracken mod because it looks cool, and maybe a 3D barrel top for the lower pop bumper because it will then match the other one next to it better, but that's about it. I'm working on a mod for the star map that will make the light look more star-like, but it's not quite done yet.
Nice! Thank you again. I think I saw your in progress star mod. Looking forward to your final result!
#6555 5 years ago
Is there a reason why the attract music would cut off after about 2-3 seconds of playing? I'll adjust the volume on the outside volume control, then it cuts off fairly quickly.
I also have a noticeable electric hum when play isn't active from the speakers in the head.
#6556 5 years ago
Quoted from wesman:
Ground loop isolator is what you need to get rid of the hum. Dirt cheap, but I think JJP will send you one if you call tech support.
#6557 5 years ago
Oh excellent! That sounds familiar from this thread! I'm missing a manual cd, and topper plugs and screws also. Should I contact my distributor for all of these or JJP tech support?
Would this be causing the attract audio cut out also?
#6558 5 years ago
Thanks so much for this - just ordered an LE and it's incredibly useful to have the most common issues and fixes in one document. Really appreciate you taking the time to put this together!
On another note - I think based upon stories I've heard re the clearcoat chipping on DI I'm going to go for the full set of cliffies. Does anyone have a recommendation re where to order, preferably in Europe?
#6559 5 years ago
Quoted from JustLikeMe:
Try pinball heaven in UK, he sells Cliffy protectors. or best of pinball.
http://www.passionforpinball.com/protectors.htm
#6560 5 years ago
Quoted from wesman:
Did JJP pack topper plugs and screws with some of the LEs? The one we got didn't have them, but I just dipped into my spare parts and made it work.
I'd call JJP tech support directly, you'll probably get faster resolution.
#6561 5 years ago
Quoted from wesman:
I'm at the point where I'm realizing pinball tables are organic beasts
I love seeing all the new faces to pinball, I have been in this hobby for a little while and still learning everyday. Having great teachers like LTG, Grumpy, HEP, and many others to learn from! Has made learning easy and fun. I never thought I would now how to test IC chips or solder on circuit boards. This hobby for me is greatly rewarding with watching friends and family play. And then I get to fix them when needed!
Quoted from wesman:
This volume adjustment is really only meant for volume control. To give you a brief sound of how loud it will be. It plays for a couple seconds then turns off. There is no really attract music, Though I am hoping for something to be coded in the next release.
#6562 5 years ago
It should have come with the game. Mine were missing as well, but just give them a call. They sent mine straight out.
Gerry
#6563 5 years ago
Pirates already has a ground loop isolator installed by the factory (unless it got missed). Go over the audio connections up there and make sure everything is plugged in tightly.
#6564 5 years ago
Out of curiosity, anyone know if the JJP rock tune still plays in the attract mode like in WOZ? Thanks!
#6565 5 years ago
Quoted from apinballwiz:
Yes
#6566 5 years ago
Quoted from zaphX:
I’m guessing the brass screws are too tight which is not allowing the yellow lockbar full travel.
Have to tinker with adjusting my lockdown bar screws as well as I've had to on all of my JJP pins. I wish JJP would switch to the latch style brackets used by Stern for their recent games. While it was likely designed to cut costs it also makes removing and installing the lockdown bar a much easier process.
Also, to anyone getting a new LE / CE be aware that the certificate for the game is now taped to the underside of the cardboard flap of the shipping box. Will be under the invisiglass cleaning instruction paperwork.
#6567 5 years ago
Is this in settings to turn on and off? Mine has never played that!!
#6568 5 years ago
Quoted from PanzerFreak:
That's good to know.....
thanks
#6569 5 years ago
Maelstrom mod is off to a new owner.
#6570 5 years ago
As a new POTC owner I have a couple of quick questions.
Shots to the chest seem to go in when lock is lit but then just bounce out. Only a really hard shot will cause the ball to go up and into the trunk. Is this normal behaviour?
Secondly, when the ball has gone into the cannon and there is a display on the mini screen, what exactly am I supposed to do with that to time the shot accurately. I'm being a bit obtuse, but can't work it out and am sinking the dauntless by simply watching the position of the physical canon rather than the screen but this can't be right. Is it?
#6571 5 years ago
Quoted from DarthSinex:
Yes you watch the physical position of the canon compared to the dauntless.
For the chest, your forks are probably loose. It's a quick and easy fix to just re-tighten the screws.
#6572 5 years ago
We're having the same problem here. Initially, the forks were bent to the right and it was slamming the ball into the side of the chest opening rather than into the chest. I bent them back to the left (they're tight, so that's not it) and now about 30% of the hits to the chest make it into the trunk, but I can't figure out how to get that number up so it's not rejecting so many. It's really the only major issue I have left to tweak to get it all working well.
#6573 5 years ago
What does it mean when you see one of the movie chapter lights flash white real quick?
I also notice that some shot will randomly quickly flash a different color. Does that have anything to do with the star map?
#6574 5 years ago
I finally installed a map cliffy last night. What a pain that was. There were 2 cliffys for the map. Was the 2nd, smaller one supposed to also be installed from the top? I assumed it was installed from under the playfield. But it also seems like a pain to get into. And those arent standard screws. Or did I mess up bigtime and was supposed to stack the 2 cliffys? Will probably leave that one uninstalled. STILL LOVIN' THE GAME THO!
#6575 5 years ago
Thank you! I know it's kind of an odd question but I like the way it starts off with EM sounds then sounds from Space Shuttle before the rock tune. I was curious if it was also in games after WOZ.
#6576 5 years ago
Quoted from heni1977:
There's a setting in there under system settings for attract mode music on or off - it's off by default. I assume if you turn it on it will play it.
#6577 5 years ago
Quoted from roddog:
This post shows the installation of both pieces:
#6578 5 years ago
haha yep i messed up by not stacking them. oh well! gonna leave it this way.
Also thanks for sharing. Maybe I can get those 2 screws out without removing the ship...
#6579 5 years ago
Is the disc silencer kit from mod couple still necessary on the new builds?
#6580 5 years ago
Quoted from estrader:
AFAIK the spinner design is unchanged. I would review Buffalo Pinball’s videos, they had one where they installed the silencer and you can hear it before/after to assess the impact.
#6581 5 years ago
The one we have from mid-feb is LOUD. Seems to have calmed down a little, but it's WAY louder than other games with spinning discs I've played.
#6582 5 years ago
The easy fix is to crank the volume up.
#6583 5 years ago
Quoted from gliebig:
Unfortunately, some locations don't want loud pins, so that's not an option there.
#6584 5 years ago
Don't think my forks are bent. Feels like the switch isn't triggering the forks, but I'll take a look again
#6585 5 years ago
REmove the fork mech (5 screws) and confirm the 2 screws that secure the fork are tight. The shot still requires a good solid hit, but if the fork is loose it rejects way more than it should.
#6586 5 years ago
You can take a slo-mo video with your phone to help diagnose what's happening. It helped get me from 0% to 30%.
#6587 5 years ago
Page B-25 in the manual. Attract mode sounds and attract mode music.
#6588 5 years ago
Just a small heads up for owners. The inside corners of the lockdown bar does not have mylar applied which if you are not careful can lead to scratching of the powder coat on the side rails. JJP was applying mylar to the corners of lockdown bars on some or all of their past games, not sure why they stopped with Pirates. I cut a few pieces of mylar and applied it to my lockdown bar today.
#6589 5 years ago
I will switch it on tonight!!!! Thanks!
#6590 5 years ago
Thanks again for the heads-up
#6591 5 years ago
Yeah, it's a weird omission.
#6592 5 years ago
Where is attract mode in the menu?
#6593 5 years ago
Nevermind. Mine was on. But I do t recall hearing it do anything.
#6594 5 years ago
Would you be able to take photos of where you applied mylar?
Yeah, I was just told up above there is no attract music. Weird.
#6595 5 years ago
if the 'white flash' happens after hitting the starmap/jack sparrow shot - that is the next constellation you need to collect.
basically the game is giving you a hint if you can't figure it out from the actual starmap itself.
#6596 5 years ago
Quoted from LTG:
So my attract sound and music is on. I do get the Gibbs speech every now and then when you push a flipper. Still no music though.
I am still running the .96 code so I am guessing I need to update a little!!!
So then is the music come on when the JJP logo comes on?
Is it the same music the is in the sound check in test mode?
#6597 5 years ago
So I figured it out from watching a YouTube video on woz.
It is the same attract song used in the sound test as in the short video of the jjp logo.
#6598 5 years ago
Any idea where this might have come from? Found it near the P in Pirates
#6599 5 years ago
I'm at .98, and had the JJP logo kick on once, but not a second time.
#6600 5 years ago
Side note, I found loosening this screw seemed to help the ball plunge go all the way around like it's supposed to
Pinball Mod Co.
$ 427.00
PinWoofer
$ 29.25
The MOD Couple
$ 29.00
The MOD Couple
Inclusive GameWerks
$ 26.50
The MOD Couple
$ 24.95
Hookedonpinball.com
20,000
San Diego, CA
Trade
Machine - For Trade
Vernon, BC
22,000
Smithtown, NY
$ 29.00
Pinball Photos LLC
Playfield - Plastics
Pinball Mod Co.
$ 100.00
Led Pinball
Pinball Mod Co.
$ 43.00
The MOD Couple
$ 38.75
The MOD Couple
Pinball Mod Co.
$ 18.95
Pinball Mod Co.
$ 110.00
Great pinball charity
Pinball Edu
This page was printed from https://pinside.com/pinball/forum/topic/jjp-pirates-of-the-caribbean-official-owners-and-fan-club/page/132 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
