Hi Enaud +
HowardR shows the snippet "relays making the motor to run" - I guess in Your pin the "O-Ball-Return-Relay" is constantly pulling and the fault is "the Coin-Unit is faulty not stepped down" - so the Q-Game-Over-Relay cannot pull-in. Or then, maybe the Coin-Unit is stepped down and just the activation of Q-Relay does not work (?).
Please find in Your pin the BX-Last-Ball-Relay - in an 1,2,3,4 player game: The last ball on last player is played, lost - enters the Outhole - bonus is counted down , the O-Relay pulls-in - NOW the BX-Relay does actuate (in Your pin ?), the Coin-Unit is stepped down (single steps) (in Your pin ?) - then the Q-Relay actuates - well, should actuate.
I like http://www.pinwiki.com/wiki/index.php?title=EM_Repair and I like http://www.pinrepair.com/em/index.htm --- in there is a great video about the AX- etc. Interlock-Type Relays - AND something that puzzled me every time I watched the video - a hint to make me look-up in the schematics of "Jet Spin". Watch in the video http://www.pinrepair.com/em/index3.htm#axrelayvideo - (time) 1:04 --- a bit of "July 1977 Jungle Queen" --- 1:15 to 1:27 he steps up and down on the COIN-UNIT - SINGLE STEPS - 1:26-1:27 he steps DOWN, SINGLE steps. This always puzzled me as I am a "rather a Williams guy used to TOTAL-Resetting the Coin-Unit".
Want to try (?) - wear rubber-gloves and/or do not touch electrical stuff, solder-lugs --- when Your pin starts doing the fault: MANUALLY step down the Coin-Unit (I believe there is an Zero-Position on the Unit so in a One-Player-Game You should be able to step down a step).
Maybe the pin gets to "Game-Over" --- well, the O-Relay must be pulling and closing its switch with wires-soldered-on "Black-Yellow" / "Brown-White-Red". Also the BX-Relay must have actuated and therefore have closed the switch with wires soldered-on "Brown-White-Red (((connecting wire from O-Relay)))" / "Maroon-mingled-with-Yellow". Greetings Rolf
