Hello, I have a problem with my jet spin pinball machine
After a good cleaning and reassembly it is still in tilt I looked at AX but the contacts are good I also welded the wires together of the tilt
When I turn on the game:
-"1rst ball relay" is glued
-"Game over relay" is pasted
-AX is unlocked
I start a game: during the first sequence of the engine (i.e. 1/3 turn) S sticks
-S glue R
-S AX lock
-S takes off at the end of the first sequence
-Locked AX and pasted R disables "game over relay"
-AX locked glue H
-Ax locked, R and H glued disable "1rst ball relay" NO and 1rst ball relay remains glued
-AX launches the raz YES
-AX unlocks at the end of the raz when the counters are at zero
Thank you for your help, sorry for the translation
https://drive.google.com/file/d/1bTJm_iLKTNoOQURgBy9W2G5GnuyXkOTE/view?usp=drivesdk
F3E88CAC-FA23-41E7-A466-B663FA73E825 (resized).jpeg942A85B0-BC87-40EF-BF4D-7FE5E8E97D10 (resized).jpegA8B384DC-726F-4582-A161-B1E9E5E1E4A0 (resized).jpeg43F55F5B-16CC-457E-BEBF-39363A0E3E34 (resized).jpeg
