I've talked about this for a while. I have not come up with a slimline, cheaper solution yet but I am offering up my current solution. It's a bit pricey because it involves a few separate components which should be eventually combined in to a single PCB but I am not sure the demand is there yet. This is specific to JJP games at this time because I haven't made other harnesses yet. If you want it for other games I can sell without a harness and give instructions on what needs to be hooked up.
Are you sick of hearing the loud "POP" when you turn on your JJP games? It's not damaging but it sure is annoying.
What if there was a simple plug and play option to get rid of that popping sound all together? In fact, any whining or other noise from the speakers on startup can be dialed away with this handy device.
Installation is really easy. Simply remove the backglass, unplug and re-plug a few connectors and you are ready to go. Digital readout of the settings on the device tell you how it is performing and lets you configure delay parameters to set the mute timeout for any amount that fits your game's needs.
Right now this device is only plug and play for JJP games as we investigate and make harnesses for other manufacturers.
*Note this will not solve any sort of audio issues during game play. If you have whining, buzzing or other issues you may want to look in to a change out of your ground loop isolator. This are installed from the factory at JJP but seem to be inferior or otherwise not always protect from that DC whine/feedback. A search on Amazon for these will return a top result which has proven to help with whining issues on other games.
