(Topic ID: 150110)
jd ball eject keeps shooting ball
By Zinzangzoom
5 years ago
  • 8 posts
  • 5 Pinsiders participating
  • Latest reply 4 years ago by Zinzangzoom
#1 5 years ago
I have a problem with my judge dredd. I replaced the transister and coil on my trough coil that ejects balls and it worked fine for a month. now every time I start a game the trough coil keeps ejecting balls like multiball. I cleaned the opto under the playfield. Checked all my connection in the back box took off the 2 opto boards and visually they look good. Any help or suggestions on what to try next would be appriciated. Thanks
#2 5 years ago
Look over your switch matrix in the manual, find the row and column the ball jam opto is on ( last opto on ball trough board the ball goes by going to the shooter lane ) check the other switches in the same row or column for a short to switch lugs/wiring.
LTG : )™
#3 5 years ago
I had a demolition man that just continuously fired balls over and over. There was a broken wire on the trough opto board. It might be something simple like that
#4 5 years ago
Zing, I'm still pretty much a beginner at pinball repair so you probably know more than me. You said the two opto boards "visually looked good". Is there a way to test them? My JD did the same thing so I replaced those boards and now it works.
#5 5 years ago
Thanks for all your replies, u really think people on pinside are awsome. Any way I been looking over and over and learned a lot so far. But I might just order the boards online ND try that. Here's my problem if anyone has any other ideas. Ball keeps going into multi ball and will be good for a while until it starts to look for a ball and when it does it starts ejecting balls like multi ball. I went into switch test and all are not active but for top trough (which is causing my problem), globe position 1 which goes to closed on switch matrix and switch 32 that is not used which I find weird. Also my ball captive 2 will not register on switch matrix which i also find weird and is on the same line as top trough. Any way I looked at trough boards and resoilder all the joints tested all resistors everything looked good and now I will replace the trough boards and see what happens. I will let you know when I get new trough boards. I hope it works because I'm starting to go crazy. Thanks for everyone's response and will update you.
#6 5 years ago
Zing,
I think the trough boards from GLM will fix the multiball problem. Good luck. Post how it goes.
#7 5 years ago
I had the same problem. Opted to just buy a new set of opto boards from GLM
1 month later
#8 4 years ago
Changed trough boards and my judge dredd is now fixed. Thanks everyone.
$ 159.99
