Quoted from KingVidiot:Well, it’s an exposed metal post, for one. Narrows the shot unnecessarily for two, and it’s an obvious cause of airballs for three obvious problems.
If I hammered a nail in the center of the play field, I could also just say “just shoot to the right of it and it’s fine”. I want to know the reason why this metal rail is directly in the shot path.
It just seems like a strange oversight.
I'm guessing it's there to keep you from smashing into the the reel arbor, which may not be able to sustain a direct hit like that. It you moved it as you suggest it would be exposed.
Quoted from Laserbeak21:So, my original gearbox for the fin motor failed. I received a replacement from stern and it is working well, not grinding like before. However, now I have a failed switch at a certain position of the fin movement. So, now am I dealing with an optical switch or other switch problem as well? Does this require a complete replacement as some have suggested or is it something I can fix on my own? I know there have been problems with this for others as well, looking for suggestions. Thanks all. [quoted image]
Switch 61 is stuck open or stuck closed? If it failed you need a new opto board.
