I did reseat the sd card and reseated all the Ethernet cables. The screen shows the normal startup but it gets to a point where the insider connected scanner light comes on, then goes off for about 4 seconds. It comes on and does the same thing a few times. Hear some type of thump, like from the shaker motor, 4 times as well. It’s trying t do something but can’t. Then the startup finishes. The screen has the normal stuff, but there are no playfield lights and I can’t use any buttons. Can’t start a game.
I reformatted the sd and the same startup issue occurs. When it asks for info, I can’t use any buttons to select. It also says the insider connected adapter is not present. Even if that went bad, I would think the game would still work. Not getting power for some reason.
