Quoted from Ollulanus:Part of my issue is the shooter rod being misaligned too, but when I tried loosening the housing up there was basically no play to adjust it. Not sure if there's another way to tweak the position than that?
There are three screw going from the back to front and two wood screws just going from the back to the wood. Did you loosen all 5 of these fasteners? Sorry, if that sounds like I'm being strange, but I can't imagine it has no play. Do you mean it is already all the way in the direction you are trying to move it? Or do you mean it won't move at all? If it doesn't have play for some reason or if it can't move enough then you can try two things. Basically both give you the same effect. First thing flatten out that plate piece in the backside. I've seen in the past a game that had this piece installed over the top of the lock down bracket there right next to it. Also I've seen one that bent all out of shape. Second you can try to stuff something under the assembly. Use the opposite side of which direction you want the plunger to shoot.
