Do all the rest of your coils work? If not, its likely a blown fuse. If all your other coils work then its most likely a broken wire on the coil lug.
I will turn it on tonight and check these things and post again. It starts up just doesnt eject a ball, but I will check again to give more specific answers tonight. Thanks for the start guys
You can test all solenoids easily in the test menu. If something doesn't work, it's probably one of the two things mentioned above.
Could use a wipe down while you're at it!
Go into solenoid test. Run the test close the coindoor to activate the high voltage while the test is running. Also run the switch test and see if the switches work in the ball trough.
Check the fuses.
Download the manual from the pinball database if you don't have a hardcopy.
If you are not sure how to use the test menu.
Are the batteries dead and it lost it's settings and it's no longer on free play?
Good luck. Hope it's an easy fix.
This page was printed from https://pinside.com/pinball/forum/topic/jackbot-will-not-eject-ball-into-shooter-lane and we tried optimising it for printing. Some page elements may have been deliberately hidden.
