Hi PinballFever +
I could not get to pinside.com the last 24 hours - maybe a server to Switzerland was broken down ?
It's a pity, somebody has taken away the Coin-Lockout-Coil (C-Lo-C). It is not a catastrophe - a pin can operate well without the C-Lo-C. I wanted to use the C-Lo-C as a "Test-Coil / Test-Relay". Well, we will use some other. Please write, do You have a chime like http://www.ipdb.org/showpic.pl?id=1277&picno=29335 (corner "Right-Bottom").
If You do not have a chime - well, we will use the "10-Point-Score-Reel of Player-4" - please write about the chime.
Your JitB looks quite dirty - do NOT work on the cabinet (paint etc.) etc. until we have some signs of life (maybe it is broken down and has to go to the graveyard).
This is the last time I write "Before working on the JitB: DO PULL THE LINE CORD, not only turn off the main switch !!!" (You do not want to make your wife a widow of any kind). Do pull the line cord, I mean it.
Look at my pic-1 (post-15) -> the green flashlight. This is my (simple) test-equipment for "Do I have connection from QQ to FG" ? I sneaked-in two wires into the flashlight (at the switch inside) -> If I put a piece of wire in between "Pic-1-H" and "Pic-1-J" and the flashlight lights up -> I know: That piece of wire is "good", the wire is not broken inside the insulation, I do have connection.
In a pin there are MANY connections - with a expensive meter You might get "false results" - showing: "there is connection from QQ to FG" - but actually the connection is "all the way around through the wiring (coil) of the transformer ..."
So when I want to make tests for to "test just that piece of wire": I either unsolder that wire off "one solder-lug" - or I cut the wire about 2 inches away of the solder-lug.
In the "Automotive Departement" of a store / supermarket You can buy "Male-Female-Plugs" for "Car-Electric". Very handy - with a pair of pliers You can "squeeze on" the plug onto the (bare) wire. With a "Cigarette-Lighter" I burn away a bit of the insulation of my wire and then sqeeze-on the plug. I do the same on the other end of the "cut wire". When I have done my tests: I simply plug "Male" into "Female" -> I again have my original wire / connection (with that male-female-plug in the wire, I don't mind). Look at Pic-1-F: The "Male" mounted on a cut wire. To the right of letter "E" You see the "Female" - and (hard to see): above letter "E" a "Gator-Clip" clipped on the "Female". On the "Gator-Clip" there is the wire "D" going to the cabinet (to do some tests).
The schema says: Transformer -> wire "Red" -> "Left side" of 15 Amp Fuse -> through the Fuse -> "Right side" of the Fuse -> wire "Red-Black" -> Bounce Switch -> wire "Red-White" -> to and through the Anti-Cheat-Switch. (This is plenty to test).
Your Post-16-Pic-2: Cut the "Red" wire (or unsolder the wire). The end of the wire (the side "into the machine") is Your starting Point (QQ). Your Post-16-Pic-1: The wire "Red" (25 Volt Fuse, bottom of the picture) is the other Point (FG). Please answer: Do You have "Connection QQ-FG ? (This is your first test).
The second test: Do You have connection "QQ -> the OTHER side of the fuse (with the "Red-Black-Wire" soldered on) ? Well, If not: the Fuse is blown or the holder of the fuse has broken. Please report.
On Your pics I do not see a "Bounce-Switch" on the Mech-Panel on the bottom of the cabinet.
Look Post-15-Pic-2-"L": This would be the candidate for my next tests (QQ->One-Side-of-Bounce-Switch / QQ->the-other-side-of-bounce-Switch).
And then (next candidate) Post-15-Pic-1-"C": The "Anti-Cheat-Switch" (QQ->one side / QQ->the other side). Greetings Rolf
P.S.: Post-15-Pic-1-"D" and Post-15-Pic-2-"P" is a connection with a jumper cable i made to connect Post-15-Pic-2-"O" (the "safe-Side-of-the-15-Amp-Fuse") connected with the coin-Lockout-Coil (Post-15-Pic-1-"A". I wanted to test "Does my Coin-Lockout-Coil works" ? (and to make a realistic test: I had to cut the wire leading to the coil).
