Does anyone have the complete rules for this game ?
You should be able to get a copy of the owners manual from the Pinball Resource. The rules for the game are pretty simple though, just knock down all the drop targets!
When you do you will get the bonus of either 100 or 1000 points per target and either a special or an extra ball and will change the drop targets from 50 points to 500 points each (the yellow 500 points when lit light will come one).
If you get the extra ball, the switch near the top of the shooter lane will turn it off when you plunge the ball.
To increase the bonus from 100 to 1000 per drop target, you need to get the ball into the lit hole at the top of the play field. This will cause the white "10x bonus when lit" light to come on. The lit hole will also score 3,000 instead of 300 when its on.
Can you score an extra ball ? How ?
To Score an extra ball in the game you need to get all 10 drop targets down while the "Shoot Again" light is lit. That light should change when the score motor turns. It should alternate between "Shoot Again" and the "Special" light. There is plug you can adjust to make special award liberal or conservative.
And how should the top lights work ? On my machine always the left (red) lane and hole is lit.
During the game either yellow or red hole should be lit. You should never see both holes lit or both holes go dark (unless in tilt mode).
The two holes and the 50 / 500 roll overs to the right and left of the drop targets should alternate as you play (I think when you hit the pop bumpers). The AX relay in your game will control this feature. Move that relay carefully by hand and you should see the lights change.
Broken clown target: Been there done that! Always remove that ball! I put a sticker under the lock bar to remind me. You can get new targets from the pinball resource.
I am at work right now, so I can check more on on how the game works when I get home tonight if you have more questions.
