I have reviewed pinwiki and a previous post on this topic. There are 4 yellow / white wires and 3 solid yellow wires going to J115.
All my GI works except orange strand on back box. I finally found that the existing J115 connector only has an 11 pin connector with no wire going to pin 1. Pin 1 should be yellow / white. I will rebuild the connector with a correct 12 pin connector. Does it matter which yellow /white wire goes to pin 1?
When I rebuild I will fill in all pins as shown in pinwiki. Does it matter which wire goes where or should I use schematic to ensure fuse goes to pin shown for j115?
On j121 the brown wire also had a wire to the ground strip. I will remove this once I rebuild the j115 connector.
Thanks for your help.
Michael
