Quoted from mrm_4:I’m clear coating a Space Mission playfield and I don’t want to put incandescents under the inserts afterwards because I don’t want the heat from the bulbs to cause issues with the clear coat. I plan on using incandescents for the GI but I hate the little flicker LEDs give in the controlled lights. Good to know the non-ghosting LEDs from comet help with this on EMs.
I've had no issue with Comet's LED's. I would also suggest looking at the out hole light mod that goes in the ball trough between the flippers. Adds a nice touch of light between the flippers and the brightness is adjustable too.
I just buy all non-ghosting, a touch more expensive but you never have issues anywhere and you don't have to worry about mixing up the normal and non-ghosting LED's. The warm whites are a little brighter than the old bulbs and not quite as yellow in temperature.
Old Bulb's
Comet
Comet and Out hole Mod
