I picked up a MM Pac-man that was partially working. It has an Alltek MPU and the others look original. I replaced one molex connector on the MPU which got the game up and running except for the 2 saucers. Both work in test, but not during a game. Contacts are clean and adjusted correctly. I researched and found the suggested ground modification for the solenoid board. I instead decided to install a new rottendog replacement board. Still no luck getting them to work. All wires are connected at the coils and the diodes are also in place. Where do I go from here?
Thanks,
Steve
