(Topic ID: 265950)
Issue with Black knight free play setting?
By Jimmyhonda
86 days ago
  • 2 posts
  • 2 Pinsiders participating
  • Latest reply 86 days ago by Black_Knight
#1 86 days ago
Hello, I’m having issues getting Black Knight into free play. I’m not sure if I have another problem going on either. From what I know, I’m supposed to go to adjustment setting 18 and use the start button to set this to zero. Then cycle through a few more adjustments and power cycle. First, sometimes going through the adjustment 18, the numbers skip around? Very strange. Also, if I get to adjustment 19, sometimes it gets stuck on adjustment 19 and won’t go up or down anymore? But if I cycle up or down the various adjustments fast, it flys right by 19 with no problem? Very strange things going on. Last, if I do manage to set adjustment 18 to zero and then power cycle, it doesn’t save that? I changed the batteries too. I’m wondering if there are other things going on? Thank you for any help.
#2 86 days ago
Sounds like your buttons are acting up is the scrolling problem through all the numbers? See if you can clean the up a bit or find replacements. Check that the wires are all connected well. The wires are small and more fragile than the others in the machine.
Is it a factory board or aftermarket? Standard battery holder or Factory? Clean any corrosion on the mount and check the voltage from the board.
There is also a way to check the ram chip to see if it’s getting power from the battery when the machine is off. There’s a thread around here somewhere.
