(Topic ID: 259555)
ISO Stern Lightning VSU-100 Roms
By 72Devilz
  • 6 posts
  • 4 Pinsiders participating
  • Latest reply 4 years ago by Roverius
#1 4 years ago
I have a client machine (Stern Lightning) I've been working on that suffered a display high voltage short on the lower body power board, the 200 volt display pin shorted out and burned a hole through the board and arced across the neighboring pins. I offered to buy the machine from her knowing that it was going to be an expensive repair but she agreed to my estimated repair costs. The short damaged the Power / Solenoid board which I repaired and damaged the MPU which was replaced along with the lower body power board.
When I first booted the machine with the new MPU everything worked without issue however the voices were present but distorted and after a short time the voices got progressively worse and they are pretty much long static patterns now. Sound pitch is present when the board is triggered and works as expected according to game action so I assume the voice chip is working. U10 was generating excessive heat on the right side and removal did not improve the issue. I have removed both U9 and U10 to silence the VSU-100 for the time being and the machine is working and playing sans voices after a 10+ year sleep.
My client is so happy to have the machine back and running in its current playing condition that the missing voices aren't much of an issue for her but wouldn't mind having the voices working if the cost is reasonable considering she has spent quite a bit on me getting this machine back up and running. After a bit of internet searching I have not found any source for the sound Roms so figured I'd ping the forum to see if I can find any sources.
#2 4 years ago
The ROM files are on IPDB: https://www.ipdb.org/machine.cgi?id=1441
Can you burn EPROMs, or were you looking to order the EPROMs with the code on them from somewhere?
#3 4 years ago
Quoted from ForceFlow:
I was looking to purchase the coded ROMs. I don’t have an EPROM burner but I might know somebody who does. Would you happen to know the size of blank EPROMs needed for this machine?
#4 4 years ago
Looking at the size of the files, a 27c256 would do.
#5 4 years ago
Quoted from Roverius:
Wrong eprom.... all the chips (stock) on lightning are 2716's.
#6 4 years ago
Quoted from slochar:
Ok, had no idea, those 2716 are bit shorter, but not to hard to come by and fairly cheap.
$ 5.95
The Pinball Scientist
$ 69.00
$ 3.00
Cabinet Parts
20eyes
$ 125.00
$ 12.00
Third Coast Pinball
3,000 (Firm)
Malboro, NJ
Great pinball charity
Pinball Edu
This page was printed from https://pinside.com/pinball/forum/topic/iso-stern-lightning-vsu-100-roms and we tried optimising it for printing. Some page elements may have been deliberately hidden.
