(Topic ID: 8164)
Is this too much battery acid on a board.
By the96stang
7 years ago
  • 20 posts
  • 10 Pinsiders participating
  • Latest reply 7 years ago by pinmike
#1 7 years ago
Im looking at my dragon and I am just wondering if this means repinning it will not work. I have a good amount of leakage.
#2 7 years ago
It's still savable, really not bad at all, but you need to get on it quick. That battery must come off ASAP before it gets down into the connectors and really starts to tear things up.
#3 7 years ago
I agree, not bad at all. Look everything over carefully, the corrosion can skip some areas and affect stuff in places you wouldn't suspect. You're probably fine and it will be very limited damage, but you never know.
#4 7 years ago
Can anyone send me a link of what I should replace it with?
#5 7 years ago
Looks quite salvageable, if that's the extent of damage. (BTW, it's not acid.)
#6 7 years ago
What is it? What do I do to salvage it?
#7 7 years ago
Do I put anything on the acid?
#8 7 years ago
You can wash it with white vinager and a toothbrush followed by a good alcohol cleaning.
#9 7 years ago
As StevenP correctly noted, it's not technically an acid...It's alkaline which is a base. Think back to your chemistry days...what do you neutralize a base with? Acid!
So, get you some vinegar (an acid) and slightly dilute it with water. Pour it in a cookie tray with enough depth and soak the board in it. Scrub any of the alkaline corrosion off with a toothbrush. Rinse thoroughly with water and then blow out with a compressor or air can and let air dry afterwards.
You want to make sure you get moisture out from between the pins and underneath the ICs.
Edit: D'oh beat to the punch by RWH
#10 7 years ago
what do I replace the battery with?
#11 7 years ago
Quoted from the96stang:
A remote battery holder, i.e. a 4 cell AA holder from Radio Shack with a blocking diode in the fourth (upper) spot.
#12 7 years ago
Can you show me a link?
#13 7 years ago
It sounds like you still haven't read clays guide yet. I would get on it. Has all of this info in detail. Here is a link to the battery section. Battery holder and diode are both available at the shack. Assuming you have a soldering iron as well
www.pinrepair.com/sys1/index.htm#battery
#14 7 years ago
This is from Clay's Repair doc. You can get them from Radio Shack. Don't forget the blocking Diode. They're tricky to solder in without melting the plastic holder - do it quickly. Solder the + (red) and - (black) leads directly to your circuit board.
#16 7 years ago
Where can I get a diode?
#17 7 years ago
Again read clays guide from the link I sent. Gives you the diode number. Also like I said EVERYTHING is available from RadioShack for that. Ground your boards while you have the soldering iron out too.
#18 7 years ago
They stopped selling diodes years ago. They were replaced by the much higher performance Biode, which are actually made of living tissue (grown from stem cells). They sell them at plant nurseries and drug stores that specialize in biotech. Google "rtfm" for a store near you.
#20 7 years ago
Radio Shack has diodes for a quick replacement if you don't want
to order online and wait.
$ 49.00
€ 8.40
$ 5.00
Allteksystems
$ 7.95
Various Novelties
Pinball Wheezer
Pinball Art Prints
$ 209.99
Metal-Mods
$ 89.99
$ 125.00
pinballmod
$ 235.00
RS Technologies
$ 59.95
Hookedonpinball.com
Pinball Photos
$ 150.00
Lighting - Under Cabinet
$ 159.99
$ 18.99
