(Topic ID: 193950)
Is this right for wire continuity check?
By RonSS
2 years ago
  • 12 posts
  • 3 Pinsiders participating
  • Latest reply 2 years ago by jimy_speedt
    #1 2 years ago
    So I'm tracking down a short or issue with my #6 connector on my AGBGoaWT. I'm trying to test for continuity at this point.
    A few questions:
    #1 Is this OK to check for continuity or do I need to cut/cut into the wire?
    I'm using a clip at the coil where the wire is connected, the other end clipped to the dmm probe, and then testing with the other probe at the pin # associated with this wire.
    #2 If this is OK, and I get continuity through several pin positions, what does that tell me? Ground issue; touching wires; Aliens have landed???
    This is connector H6-3 if it helps.
    #2 2 years ago
    #1 yes, it is alright, your dmm set to ohms should indicates a value close to 0, and certainly not infinite.
    For wires touching each other, you should have continuity with 2 connector pins. But if the wires are not stripped, there is no reason for that.
    Not certain to understand your issue. Does the transistor blow ? What is your problem ?
    #3 2 years ago
    Fuse F17 blows after a few seconds of turning the machine on. I removed all of the connectors and replaced one at a time, leaving them in as I went. When I got to connector H6, BAM!. I removed that connector and continued to replace all other connectors. So I'm guessing that connector is the issue.
    #4 2 years ago
    I know H6-3 goes to F15, I just started with that particular coil because it was easy to get to. When I tested it showed continuity, but it also was showing for other pin #s as well, hence question #1. I was worried I wasn't testing correctly and getting false readings.
    #5 2 years ago
    If you remove all the connectors it is normal the fuse does not blow.
    You can see which coils are linked to f17. In test mode, check each of these coil, and you can identify which one is failing.
    Then check it with the dmm. Or check all the coils against rach other. In ohm mode, check the values between lugs and compare with similar coils.
    This is a first step. I doubt that there is a short between wires, but who knows
    #6 2 years ago
    Thanks for all your help, I'm completely new at almost all of this stuff.
    Yes, I removed all of the connectors to see if it was a board issue or connector issue. And then to identify which connector/wire to investigate.
    I do have some starting points to check from the TEST MODE so I guess I'll get to testing and comparing some of those values.
    Also, here is the matrix that came with my manual, it is a little different than the web version, some pin numbers are different as well.
    When I tested both h6-3 and h6-2 the resistance value for pins #10 and #11 shot up to around 80. I don't know if this means anything but thought I'd post it in case it does.
    OK, I'm off to run some tests, again, thank you!
    #7 2 years ago
    Your continuity check may be going across one coil to the common power line and then back through another coil to the next pin on the connector. The resistance to the correct connector pin should be <1 ohm, the resistance to the other pins should be probably >4 at least
    #8 2 years ago
    Yeah, that's along what I was thinking. They were all reading either close to 0, 1, or 80.
    I just thought that since those particular pin #s were showing very different values it might be indicative of something.
    Guess not.
    I'm trying to pry off my apron now so I can check the "Feedback". That was one of the test mode's issues.
    #9 2 years ago
    I think I should start a new thread specifying my coil issues as I gain more information.
    Thank you both for your help.
    #10 2 years ago
    When you're not sure if a reading is good, try to find some other place with the same stuff to compare. I assume there are other connectors for coils that don't blow the fuse you could compare readings on?
    #11 2 years ago
    I hadn't thought of that. Yes, all other connectors seem OK.
    #12 2 years ago
    If all connectors are ok, and you blow up the fuse, you have a coil short. Try to identify it, then check the transistor that might have blown up
    $ 84.95
    $ 5,599.00
    Classic Game Rooms
    $ 29.99
    $ 5,799.00
    Gulf Coast Pinball, LLC
    $ 22.50
    $ 76.00
    $ 129.00
    $ 16.95
    $ 7.65
    Cabinet Parts
    Third Coast Pinball
    $ 5,799.00
    Pinball Pro
    $ 7,499.00
    Classic Game Rooms
    $ 99.00
    Lighting - Under Cabinet
    $ 28.99
    Lee's Parts
    $ 5,899.99
    Pinball Pro
    $ 75.00
    $ 139.00
    $ 14.95
    $ 214.99
    $ 175.00
    Professor Pinball
