(Topic ID: 226539)
Insert cracking on brand new PF. Is this normal, or are CPR playfields crapola?
By PACMAN
5 years ago
  • 31 posts
  • 20 Pinsiders participating
  • Latest reply 5 years ago by Darkwing
#1 5 years ago
Doing a PF swap on my Medusa with a CPR gold PF. Its had several months if not years to cure.
Had the PF upside down for about 3 days installing the ground wire, and other stuff.
Flip it over today and notice a bunch of cracking around the inserts.
Is this expected to happen? And if so, so soon?
IMG_4523 (resized).jpgIMG_4523 (resized).jpgIMG_4524 (resized).jpgIMG_4524 (resized).jpgIMG_4525 (resized).jpgIMG_4525 (resized).jpgIMG_4526 (resized).jpgIMG_4526 (resized).jpgIMG_4527 (resized).jpgIMG_4527 (resized).jpg
#2 5 years ago
Nothing?
#4 5 years ago
With a thread title like this I'm surprised CPR's customer service team hasn't jumped in yet
#5 5 years ago
Not trying to stir things up, just want to know if this is now considered the norm.
#6 5 years ago
Lol. Really?
Quoted from tomdrum:
I don't see it.
#7 5 years ago
I don't see it.
How can you not see it? It doesn't look normal to me.
#8 5 years ago
Quoted from PACMAN:
If you do a bit of pounding and stapling near the inserts it can happen.
It can also happen anyway regardless of that but if you didn’t notice before you started building only after it could be from the building process.
I have seen it right out of the box and also not until after assembly so it can go either way. One of the many reasons I have gotten away from stapled braid on playfields.
#9 5 years ago
Is it possible that the adhesion sanding before clear coating the pf is the reason for this and if so harmless in that case, meaning not cracked clear just scratched insert plastic?
-2
#10 5 years ago
Were they there before you put the t-nuts in? Hammering the pf can do that.
CPR isnt crap, best playfields Ive swapped, buthamberg being next. Only ones that are crap is mirco, clear coat cracks and peels so easy its a joke.
#11 5 years ago
God forbid an airball comes down on a insert and knocks it into the cabinet
#12 5 years ago
If you look at some of High End Pins posts, you will see that this isn't that far out of the norm unfortunately...
#13 5 years ago
Crud. So how do you go about attaching the braid and pounding the t-nuts?
Quoted from High_End_Pins:
#14 5 years ago
I’m really uneducated “learning “ so please don’t mind my question. But is that the clear coat separating from the play field or actual play field damage?
#15 5 years ago
Thanks i'll go check them out. Still learning about restoring pins, much harder than vids.
Quoted from Wmsfan-GAP:
#16 5 years ago
Quoted from PACMAN:
I use a t nut tool to pull those in and I use two lead sockets so I don’t have to use bare stapled wire.
This might highlight that but it has been a while on Medusa specifically.
https://pinside.com/pinball/forum/topic/hep-medusa-restore
#17 5 years ago
Quoted from PACMAN:
Chris I'm not sure if you have posted in your threads, but I know from watching you that McCune? turned you on to a tool he made to insert the T-Nuts? Would you be willing to show what parts the tool consists of and how you instal them without a hammer? Might help save a few playfields?
-1
#18 5 years ago
OP
Quoted from PACMAN:
Damn your good Chris you beat me to it!!!
#19 5 years ago
"I use two lead sockets so I don’t have to use bare stapled wire."
Fascinating. I went thought your Medusa restoration thread but i couldn't find this.
-12
#20 5 years ago
Quoted from PACMAN:
Ever think of emailing CPR to discuss the issue before you make such a moronic, idiotic post?
Just asking, I'm not trying to stir anything up.
QSS
#21 5 years ago
There was just the exact type thread recently.
Consensus was its normal and your screwed. If you wanted perfect you should have sent it out for a reclear before starting. (not my words)
Read here. Small cut and paste directly from Kevin.
"OK guys, let's just call it official and finally move onto the electron microscope as a standard here...
This has to be the most close-up photo analysis I have ever seen on our playfield inserts, to date. To the point that if CPR is going to be called out, I have to now demand galleries posted of 1-inch inserts as dinner-plate sized pix, of ALL current playfields being sold today. Stern. Jersey Jack. Chicago Gaming. Mirco. All of them."
Full thread here.
https://pinside.com/pinball/forum/topic/classic-playfield-reproductions-bad-quality
#22 5 years ago
Quoted from QuickSilverShelby:
QSS
Geez, inflammatory much? He’s just inquiring if insert cracking is normal. Christ on a Cracker man.
#24 5 years ago
QSS
Lol, all this early snow is really getting to us AB guys.
#25 5 years ago
Something to think about. Wood will give/bend a little when hammering on it. It it's close to an insert there is a good chance of this happening. Also if the glue for any reason is a little weak in that are it wont help much.
#26 5 years ago
My Bad Cats PF says neither.
#27 5 years ago
Is this due to the epa making the clear formulations different? If so what a pita
#28 5 years ago
Quoted from PACMAN:
I had numerous disappointing issues with my CPR gold Medusa play field. My first suggestion is you make sure if the play field is even the right size... They had some frustrating issues with Medusa.
#29 5 years ago
Chris, I don’t want to sound like an idiot but want to make sure I understand, you use 2 lead sockets and run a loose ground wire from socket to socket? If that is so, are there any issues that arise that I have not thought about yet?
Thanks for the info, if I am thinking this correctly it might make changing the SS Playfields more user friendly for me!
#30 5 years ago
Quoted from indy5mike:
Yes
No issues the main thing is about mapping it out so the leads don’t touch or get in the way of other parts.
I have probably detailed it in a few Restoration threads.
Can also be done with single lead sockets using screw terminals
https://pinside.com/pinball/forum/topic/hep-firepower-2018/page/2
#31 5 years ago
Quoted from underlord:
Actually the title screamed “False dilemma” to me.
West Point, UT
$ 90.00
£ 195.00
$ 139.00
Pinball Pimp
$ 22.95
$ 69.00
Pinball Pimp
$ 69.00
Playfield - Plastics
Pinball Shark
$ 18.95
7,000 (Firm)
Reno, NV
This page was printed from https://pinside.com/pinball/forum/topic/is-this-normal-or-are-cpr-playfields-crapola and we tried optimising it for printing. Some page elements may have been deliberately hidden.
