We're back!
After a disaster in our datacenter took down our server, we are now running Pinside on a brand new server. However, things may not work as expected as we are still polishing the playfield and adjusting some switches! We might be switching to maintenance mode a few times. Please see this forum topic for more info.
(Topic ID: 239518)
Is This Normal?
By PinballGurus
2 years ago
  • 10 posts
  • 7 Pinsiders participating
  • Latest reply 2 years ago by PinballGurus
#1 2 years ago
I’m pretty new to EM... simple question. Is it normal for a open switch to read continuity? I wouldn’t think so but???
#2 2 years ago
Not uncommon. The continuity you are reading isn't the switch you are probing; it's somewhere upstream of the switch. Look at the other switches in the circuit.
#3 2 years ago
Yeah- continuity on an EM is typically not as simple as what you might think. I basically dont ever use it unless I am looking at two ends of a wire and want to know if everything in between is good.
You did not ask- but if your looking at switches- your eyes will work better. Just watch the stationry blade. Adjust such that when the moving contact is at its max deflection- the stationary blade moves a bit. This will give you the natural contact/slide you want to self clean switches.
#5 2 years ago
If you do want to verify a contact via continuity you'll have to desolder one of the wires on it first to cut out the rest of the circuit
#6 2 years ago
Don't use continuity check on your meter as it will beep when the resistance is below a set threshold IIRC about 40ohms on a Fluke.
Check using ohms and measure the resistance. What you may be reading as continuity across the contacts maybe because of a path back through the transformer (which is low resistance).
#7 2 years ago
All of the above... and you shouldn't measure resistance in an energized circuit. Best case - the voltages will mess up the measurement, worst case - you could blow out your meter or create a short with the probes.
Nice video, btw...
#8 2 years ago
Blow the meter is not the worst case. You're definitely new to EM. The average human, healthy heart can withstand up to 60 milliamps of AC current before it goes into fibrillation. Depending on where you're poking your fingers and metal probes, one in each hand, in an energized pin -- like the way you did in your video -- you risk up to 1000 times that amount of energy in a neat pathway right through your upper torso. It would only happen once. Be careful, man!
#9 2 years ago
lol... been shocked worse washing my clothes, but true.
#10 2 years ago
Yes, I usually have the game off. lol
