(Topic ID: 203201)
Is this Flipper Assembly alright? / Why does my game reboot?
By DrDrain
6 years ago
  • 7 posts
  • 4 Pinsiders participating
  • Latest reply 5 years ago by wayout440
#1 6 years ago
Hi dear Pinsiders,
My Starship Troopers is sometimes rebooting, when I press the mini-flipper at the same time with at least one other flipper. It has a third button to flip it.
The boards were all checked by a professional, so I want to check if it's a problem with the mini-flipper.
Strangely without the DMD the game works without any reboots (even with pressing of the mini-flipper).
The DMD and Power Supply Board were checked as well.
I notice that on the "End of Stroke switch" of the mini-flipper there are no wires. Is this the way it should be? Maybe somebody with a Starship Troopers or any other Whitestar game with a mini-flipper of this kind (for example a Rollercoaster-Tycoon) could check this for me.
Then I noticed, that the one cable on the coil seems to be smaller than it is on the other two flippers (Left cable on the picture).
I saw that on some of the other coils (for example the slingshot coils).
I thought that the diode (or the cables) on the coil might be reversed, so I took a look at the manual.
In my opinion it looks fine.
I can't figure out where the problem is.
Do you have any idea what could cause this to happen or what I should test?
Any help is greatly appreciated!
#2 6 years ago
You're good on connections. The problem is that you have a low 5 volts. Each board by itself will run fine on the bench, but with the "strain" of flippers, the voltage is dropping too low. There's a leg on the u218 chip on CPU board you can cut, if it isn't, to increase the amount the voltage can drop before it resets. There's also a pot on the power/driver board you can adjust (R116) to increase it. Or have your tech rebuild the 5v power part of your power/driver board. Usually the bridge goes, but there are other parts that can fail as well.
#3 6 years ago
Thank you for your reply!
R116 was already adjusted by my technician.
So I've cut leg 3 on the U218 (on the CPU Board) and leg 3 on U210 (on the Power Driver Board) as Sega service Bulletin Nr.112 says (I found it somewhere on the internet).
The game now works without any reboots. Thanks a lot CadillacMusic!
Thanks a lot to Pinside too, for getting the opportunity to solve this problem!
Finally I can play the game as it should be.
11 months later
#4 5 years ago
Hi everyone, read the thread above and I'm experiencing similar issues. Does anybody have more details about the Sega service bulletin Nr 112?
The game is 'freezing' often during heavy multi ball gameplay. All boards have been serviced, tested and repaired where necessary. Game also has a new DMD controller board.
The fault causes the game to 'freeze', its goes dead with nothing on except for GI. I've read about flipper diodes, BRDG21 possibly needing replacement, but I would perhaps like to try this Sega SB first.
Many thanks in advance.
#5 5 years ago
Quoted from swampy:
Most of the time this is caused by low or fluctuating line voltage that dips below 109 VAC. Thoroughly test your line voltage. If you want to try the mod, it increases watchdog tolerance from 5% to 10% by clipping pin 3 of the DS1232. Sega started performing this mod during production so some games may have the mod already. Details here: http://arcarc.xmission.com/Pinball/Stern%20Service%20Bulletins/sb/sb112.pdf
#6 5 years ago
Many thanks for the reply. Interesting that this game was set to 230V (came from the UK) on the jumper settings and we have now changed it to 218V (220V is the nominal voltage here in the UAE) and it appears (hopefully) that the reset issue has been resolved. Will continue to monitor.
Interestingly I inspected the machine to see if the above SB had been incorporated - the U218 chip on the CPU board hasn’t been clipped (although the board was sent away for service) but the U210 chip on the I/O board has......hmmmm.
Anyway - thanks again. Hopefully we have found and cleared the problem!
$ 17.00
Nordic Pinball Supply
$ 18.95
$ 54.99
$ 12.95
$ 54.99
Hudson, FL
$ 36.95
$ 54.99
4,750 (OBO)
Toronto, ON
$ 18.95
PinSound
$ 40.00
$ 23.95
Mitchell Lighting
$ 54.99
$ 54.99
arcade-cabinets.com
$ 18.95
This page was printed from https://pinside.com/pinball/forum/topic/is-this-flipper-assembly-alright and we tried optimising it for printing. Some page elements may have been deliberately hidden.
