You can almost always feel a slight difference in elevation when you rub your hand on it. Just depends on how much it’s actually raised. In your case appears to be about normal.
So the inserts lettering showed up too? For that to show up so pronounced too makes me wonder if the whole effect on the paper is kinda exaggerated.
Frame those up, $100 each!!
It’s tough to tell how raised they are with that method of showing however.
Wait till the dimples set in then do it again and see.
But I actually think it is fine.
Quoted from DNO:Frame those up, $100 each!!
The dimples can make a grown man cry
You’re missing half of the tablet. I think I might know where it is. I’ll need my dads diary though.
Quoted from chuckwurt:You’re missing half of the tablet. I think I might know where it is. I’ll need my dads diary though.
HA! Harrison Ford knows what you did there!
Okay, Thanks for the input people.
It's hard to photograph hence the rub and I can feel it quite easily, but if seems okay to the more experienced I'm happy with it then. It only really effects the ball on slow rolls at times and my biggest concern was the possibility of future chipping.
The Last Crusade reference was hilarious, so thanks for that. It's one of my favorite movies!
You could put down some mylar or a playfield protector to give yourself piece of mind to prevent wear or chipping.
Quoted from Hammer3246:Okay, Thanks for the input people.
Affecting ball travel is NOT normal. Get with your distributor and get the issue documented. If the playfield gets damaged you’ll need the issue documented so that you can get a replacement populated playfield.
Quoted from chuckwurt:Affecting ball travel is NOT normal. Get with your distributor and get the issue documented.
Well, I have heard people say that dimples can have influence on ball travel.
I think we need to see pictures or proof before trusting a pencil rub for ringing up a distributor.
Quoted from chuckwurt:We don’t need to see anything. It’s something to work out with stern and their distributor
I guess I’m not into wasting everyone’s time like some. Show some PROOF.
As far as I see, the ink on the inserts is just as raised as the edge of the inserts with this method of showing.
This page was printed from https://pinside.com/pinball/forum/topic/is-this-common-with-playfields and we tried optimising it for printing. Some page elements may have been deliberately hidden.
