(Topic ID: 233251)
Is there a trick to these rubber things?
By Aniraf
3 months ago
  • 9 posts
  • 8 Pinsiders participating
  • Latest reply 3 months ago by underlord
    #1 3 months ago
    How do you install these rubber bumpers into the flipper bracket? I assume there is some kind of trick because pressure just makes them expand further.
    #2 3 months ago
    A little dish soap works wonders
    #3 3 months ago
    Quoted from Aniraf:
    I use a small flat head screwdriver to get a part of the lip through then keep pressure on it and do the side to the 90 deg. That's usually enough for it to pop in.
    #4 3 months ago
    Quoted from Jarbyjibbo:
    #5 3 months ago
    I use a combination of both a small flathead screwdriver and a little dish soap.
    #6 3 months ago
    If that's for your firepower you don't use those. They come in the kit but you leave them out. They will decrease the angle of the flippers so much it's hard to catch and hold the ball.
    #7 3 months ago
    That flipper base does not use rubber grommets.
    Terry.
    #8 3 months ago
    These are for my pinbot. It does use this . I’ll try the flathead tomorrow. Thanks!
    #9 3 months ago
    Tiny spray of light silicone directly on rubber. Boom. Pushes right in.
    $ 18.99
    $ 3.00
    Doc's Pinball Shop
    $ 49.99
    $ 68.00
    $ 218.00
    Bright Lights Pinball
    $ 1,099.00
    $ 63.00
    $ 22.00
    $ 22.00
    $ 24.25
    The MOD Couple
    € 8.10
    Buthamburg
    Pinball Z
    Pinball Pimp
    £ 49.00
    PinballToys
    $ 48.00
    $ 229.99
    $ 99.99
    $ 29.99
