(Topic ID: 269777)
And... Is there a tool for this ? (Another question for a tool)
By undrdog
  • 18 posts
  • 9 Pinsiders participating
  • Latest reply 3 years ago by GSones
#1 3 years ago
I'm trying to clean this advance unit. It runs the thermometer on Heat Wave. The band of steel that is the "mercury" in the thermometer runs along the white reel, which is kind of a pulley.
I cannot get the reel off. Also, the sprocket won't come off. After removing the hex nuts, I can wiggle it about 1/2" up the spindle, but that's it.
I sure don't want to bend these parts by forcing them off, but I've got to get them off so I can get it all cleaned.
Is there a tool for this? Some pinball mechanic trick that I don't know about?
Mike
IMG_6200 (resized).JPGIMG_6200 (resized).JPGIMG_6219 (resized).JPGIMG_6219 (resized).JPG
#2 3 years ago
I just got done cleaning that unit on my Heatwave Wave. I used a small rubber deadblow hammer to lightly drive the shaft through the disc. Left the nut with about two turns on the shaft to tap against to not damage threads. Support the chassis while tapping. Penetrating oil on the all the shafts and the rest comes apart. No need to pry on the disc.
#3 3 years ago
Just saw that Harbor freight has a gear pulling tool set for $20. Thinking I’ll try that on the sprocket side of the unit & use the penetrating oil.
#4 3 years ago
Quoted from gottliebgreg:
Did you repaint the thermometer band?
#5 3 years ago
Mine has a weird cloth ribbon. Doesn't appear to be homemade so I'm living with it for now. I might make a new one in the future.
#6 3 years ago
The gear puller didn’t work. Ended up getting the sprocket loose by working it back and forth with a large needle nose.
This time I removed the switches and coils and left them hanging, but I had to cut the 13 Bakelite connections. After reassembling the unit in the back box, I think it is easier to cut all the wires and just resolder them all.
The unit works great, only I lost the thermometer spring, so that's not back on yet. I put it someplace safe a few days ago, so I wouldn’t lose it.
The funny thing is, the special and Blow Your Top now only light when they are supposed to. No idea why they were always on before or what fixed it. One less thing to worry about.
Big decision time: break down & clean the match unit on GPs, or just let it be. It’s sluggish, but it works.
Tomorrow I’m taking everything off the playfield but the pop bumpers, for a good cleaning & waxing. New rubbers, and I can finally see how it plays.
Other owners- do you have one or two bands around your flippers? This one came with two on each.
#7 3 years ago
Quoted from undrdog:
Often, two rubber rings are used on the rounded top two inch flippers.
This had to do with the advent of the flipper during the time when the standard pinball was 1/16" larger in diameter. The flipper was not changed when the standard ball size was reduced, and to compensate, double rings were recommended on the flippers. When the flat top flipper was introduced, it was designed for the smaller ball, and so only a single rubber was needed.
#8 3 years ago
jrpinball does that mean that my 1964 machine will never really play as intended, because it was designed & configured for larger balls?
#9 3 years ago
Absolutely not. The game was designed for the smaller ball. It's only the flipper die which was never modified for the smaller ball. It doesn't make much of a difference, but I do double the rubbers on the round top 2" flippers.
#10 3 years ago
And... is there a tool for getting lamps out of these holes? The socket won’t flex from behind. My fingers are too big and I don’t have a rug rat to ask for help.
E4179CDF-3AE7-4168-928D-7E555A9DA227 (resized).jpegE4179CDF-3AE7-4168-928D-7E555A9DA227 (resized).jpeg
#11 3 years ago
http://www.pbresource.com/tools.html
See rubber lightbulb remover
#12 3 years ago
And I just ordered from them! Hate paying multiple postage’s. Maybe it’s not too late to add on.
#13 3 years ago
Heat shrink. Do you have any? Take a bulb that is already out and shrink some tubing around the glass. Leave rest unshrunk. Now you have a tool.
#14 3 years ago
Bally included a bulb removal tool in the instruction manual/schematic envelope with all of their Flipper Games. It's a 3/8" wooden dowel 2 1/2" long with a piece of rubber hose on the end to grip on the bulb dome.
#15 3 years ago
use an old shooter rod rubber tip
#16 3 years ago
Quoted from luch:
I have one of those!
#17 3 years ago
Neopream gas line.
#18 3 years ago
This page was printed from https://pinside.com/pinball/forum/topic/is-there-a-tool-for-this- and we tried optimising it for printing. Some page elements may have been deliberately hidden.
