(Topic ID: 265779)
Is there a how to guide on regraining metal?
By fossmin
1 year ago
  • 15 posts
  • 12 Pinsiders participating
  • Latest reply 1 year ago by yellowghost
  • Topic is favorited by 9 Pinsiders
    #1 1 year ago
    Did a search but didn't see anything. Are there any instructions posted anywhere?
    #2 1 year ago
    There's a bunch of info out there on regraining metal.
    #3 1 year ago
    Steve at PBR says just use 200 grit sandpaper in the direction you want the grain.
    #4 1 year ago
    It's not as hard as you might think.
    Trick is to only make straight strokes when sanding. Don't make an arc... try to avoid working side to side... straight long ways strokes. Use a sanding block.. even if only a small piece to move around curves, etc.
    The grit needed depends on what you are trying to clean up. Basically go lower grit to work out heavy grooves/scratches... then move up in steps to bring up the polish level you want. I find 600 grit is a nice finishing level if I want a factory grained look. I'll start as low as 150 or so if I have a really heavy groove to clean up. Just experiment and see what you need. No hard and fast rules here... because you can always move up. Just always keep working in the same straight lines.. you don't want to have to clean up extra marks.. that includes when you 'change directions'!
    Those who want a polished look will go beyond that.. even using green compound, or finishing with white on a buffer wheel. With higher grit levels and that polishing you can mirror polish if you wanted.
    The flap sanding disks are popular to speed things up (kinda expensive IMO).
    #5 1 year ago
    I used one of these and had good results.
    As with anything try a spot and see if it gives you the results you are looking for.
    https://www.harborfreight.com/4-in-400-grit-abrasive-ball-61183.html
    #6 1 year ago
    I’ve always used red scotchbrite pads. Trim to an easy to use size, work with the grain of the steel, and change out when it gets soft.
    #7 1 year ago
    Quoted from PNBLWZD:
    I second this method. Work very good and is super easy.
    #8 1 year ago
    Try this video, may be a good starting point.
    #9 1 year ago
    There was a really good video on how to specifically do playfield ball guides. Can’t find the exact one again.
    #10 1 year ago
    That's what I am working on, are ball guides. Would love to see that video if any has it.
    #11 1 year ago
    Quoted from fossmin:
    Google is your best friend
    #12 1 year ago
    Get the coarse and fine of these 3M drill attachments - amazon.com link »
    For each pair you should be able to do at least 4 games. Well worth the money.
    I bring all the ball guides to the vice in my garage and secure them, go over all of them with coarse, then switch out to fine, then wipe down and wax.
    #13 1 year ago
    Quoted from dudah:
    Is the "coarse" the medium one? couldn't find any other...?
    amazon.com link »
    #14 1 year ago
    Since i had some off today...
    Normally i just use a pass on the buffer wheel with green compound to get the light stuff out. But if you have some deeper stuff yiu can just use sandpaper and follow up with more levels as needed.
    This piece still showed some finish variation after the buffer...
    About 10 seconds of 400 grit sandpaper by hand... Gives
    These are not cleaned... just as i an sitting at the bench
    After
    You can follow up with 600 if you want.. or just use as is
    For deeper grooves... just go heavier and then back up to remove the deeper scratches
    #15 1 year ago
    Quoted from eyeamred2u:
    That lockdown bar looks like 80% of the lockdown bars I've seen. He is worried about not being able to "save" it?!
