I'm installing a real knocker in my Iron Man that is generated through the ticket dispenser wire in the cab. I need 50V to drive the coil. Are there any 50V wires in the cab that are always on (when the coin door is closed)?
Quoted from Allibaster:I'm installing a real knocker in my Iron Man that is generated through the ticket dispenser wire in the cab. I need 50V to drive the coil. Are there any 50V wires in the cab that are always on (when the coin door is closed)?
I haven't had a chance to poke around in the SPIKE system software. Does it have an option to activate a real knocker signal like SAM system games have?
Quoted from DugFreez:I haven't had a chance to poke around in the SPIKE system software. Does it have an option to activate a real knocker signal like SAM system games have?
Not sure about SPIKE. Iron Man is a SAM system. It has a ticket dispenser signal in the cab that I'll use to drive a knocker whenever a credit is issued (high score, match, replay, special). I need 50V for it, though.
Anyone know if there's 50V in the cab?
Quoted from Allibaster:Not sure about SPIKE. Iron Man is a SAM system. It has a ticket dispenser signal in the cab that I'll use to drive a knocker whenever a credit is issued (high score, match, replay, special). I need 50V for it, though.
These links might help.
If you figure it out maybe you could help me when my Iron man VE arrives.
I would like to try this in the new spike system as well does any buddy know if it is even possible.
Pop Bumpers in SAM/Whitestar are technically 50VDC (actually closer to 70VDC ) and Spike PB are 48VDC.
These are what a few of us MODDER's have used to "borrow" Power from somewhere else - 3-M Quick Taps.
Quick Taps are pretty straight forward & easy to use - only minor downside is they are kind of like IDC Connectors in the context that by design they slice through the insulation but some times they can also slightly slice through a few of the Wires Strands:
http://solutions.3m.com/wps/portal/3M/en_US/EMDCI/Home/Products/ProductCatalog/~/3M-Scotchlok-Electrical-T-Tap-Connectors?N=5430181+3294245702&rt=rud
On an 18AWG Wire like the Pop Bumpers use it shouldn't a problem, however on 22AWG or smaller diameter Wires it may be an issue over time. (IMHO).
Pick the largest size Quick Tap that covers the Wire Gauge you are splicing into - i.e. use a Red Quick Tap (18AWG - 14AWG) for the Pop Bumper Wires (18AWG), while a Blue QT (22AWG-18AWG) would work DON'T-DO-IT.
Terry (PBL) uses these in his LOTR Backbox Flasher Kit - had 1 his Kits in our LOTR for over 4 years with no issues.
Kim
This page was printed from https://pinside.com/pinball/forum/topic/is-there-50v-in-sam-cabinet and we tried optimising it for printing. Some page elements may have been deliberately hidden.
