looks like it should... 2 coin slot wiring harness from the looks of things... doesn't come from an "older" machines, since the parts are zinc...
unless i'm missing something however, it's missing some parts from the coin lockout...
Quoted from Dawson:My QD had its coin door guts removed , all of them ... And was looking to purchase a used coin door with the guts to put in my quick draw
Found this on craigs in Colorado,
will they work ?
The frame and slots for the coin mechs will work. The harness may or may not depending on the era the door came from. 60's doors had simpler harnesses than 70's doors.
Quoted from MikeO:The frame and slots for the coin mechs will work. The harness may or may not depending on the era the door came from. 60's doors had simpler harnesses than 70's doors.
yup, might have to re-use the existing harness and/or move some jones plug wiring....
i beat my head up against the wall on a very similar situation, and i really should have mentioned it in my first post... thanks for clarifying that mike..
as noted the wiring is not always the same but very easy to resolder to work if the other harness has been hacked up
This page was printed from https://pinside.com/pinball/forum/topic/is-the-coin-door-on-a-gottlieb-drop-a-ball-compatable-with-a-qd and we tried optimising it for printing. Some page elements may have been deliberately hidden.
