My Stellar Wars does not work (only GI, no sound, no display, no blinking CPU led, blows F2) and after getting all boards fixed and shorts resolved I looking at the transformer but I am not sure if I measured it correctly.
For AC I measured between two wires of the same color, I did that on the 12 pin connector.
For AC I used my multimeter with one probe on the metal plate in the back box (ground).
1 Violet Lamps (+18 VDC) I measured 14VAC to ground but no DC
2 Orange (+28VDC) I measured 8VAC to ground but no DC
4 White 90 VAC I measured 97VAC
9 White 90 VAC I measured 97VAC
10 Gray 18.7VAC I measured 19VAC
11 Gray 18.7VAC I measured 19VAC
12 Gray-White 18.7VAC C.T I measured 20VAC to ground and 9.7 to either White (what does C.T. mean?)
I disconnected the Red and Blue wires from the rectifiers, and tested both the rectifiers with my DMM as good.
Between the Blue wires (Lamp 13.5VAC) I measured 11VAC
Between the Red wires (Solonoid 25.5VAC) I measured 30VAC
Is it broken and do I need a new one or did I just measure it incorrectly?
