lol! an em "easter egg"...
thanks... once i chased the threads, it was pretty straightforward (fwiw, it was the plating that was gumming up the threads)... although as noted, getting that first screw in to attach the door took me awhile... generally i run into situations where i could use 3 hands, but i coulda used 4 in this case... you got a "pin-it trick" for making that easier? what i eventually did was put one through just the door and the nut strip to hold the nut strip in place, then put the top one through all 3 pieces, and rotated it up so i could remove the "holder" screw...
the only "problem" is that i'm gonna have to order a new shooter rod now, as it's dadgummed ugly next to all that shiny new metal...
yea, fun with wiring is next... to be honest, i'm tempted just to make a new harness from scratch, that way i "know" where everything is supposed to go, rather than trying to figure out the mess that is there now... i've got a boatload of thhn lying around here...
i think if i do that, i might keep the jones plug wired and take the wires coming out of there into a molex (or similar) connector... then build a harness with the mating connector to plug into that and mount the connector to the door... wouldn't be "original", but it would make unplugging the door easier... i'm also somewhat concerned that i may destroy the jones plug if i attempt to unwire/rewire it... dunno if you can get replacements for those or not, but i'm "guessing" you can't... i should drop jimmy an email to see...
at least i don't have to deal with the lockout assembly, as it's completely gone already...
i'm missing one coin chute as well... i've got spares from the "big" door they went to in 76... i'm wondering if they will work... the pictures in the catalog make it "look" like they are the same (see pages 69 and 78 in the 1978 parts catalog), but they are different part numbers... we shall see, it's easy enough to try...
