Quoted from herbertbsharp:If I remember correctly you can loosen the set screws on the diverter post (under the playfield) and pull the diverters up. That should allow you to unscrew and remove the ramps. It's been a about 2 years since I tore mine apart but I'm pretty sure that would work.
EDIT: oh you mean without touching the set screws? yeah can't see how that could be possible
Thanks, you were correct, I removed them last night. What I did was:
Unplug the wires at the bottom.
Loosen the two allen key screws underneath.
Pulled out the diverter
Unscrewed the ramps.
I didn't have to remove the bolts/assembly/solenoides underneath. Thanks again for your help.
